03-17-2016, 01:01 PM | #995 | |
I'd request more info on why they think it's PCV and not something else before tearing everything apart. If I had a dollar for everytime a tuner asked me about PCV leaks, including Delicious I could buy an FI kit by now.
03-17-2016, 02:25 PM | #996 | |
Drives: 2015 Raven FRS
03-17-2016, 02:26 PM | #997 |
Anyone that has personally installed the Edelbrock supercharger on a automatic car will you please pm me.
03-17-2016, 03:13 PM | #998 | |
Drives: 2013 FRS
My MAP shows .32 bar at warm idle, the throttle being at 13.7% and accelerator at 0%, and RPM at about 850. On cold start I get: .45 bar, throttle 15.3%, accelerator 0%, and about 950 RPM. Did you measure that with a warm engine or cold? and what was the RPM/throttle% at that time? I assume you were in neutral? I have a manual, but I bet the values will be similar at the same RPM/throttle. |
03-17-2016, 03:27 PM | #999 | |
Drives: 2013 SWP BRZ Limited
I know for sure 300whp is where the fueling and clutch fall off, because that's about where I'm at right now. I figured there was still some room before a built motor was needed. |
The Following User Says Thank You to jwvand02 For This Useful Post: | CSG Mike (03-17-2016) |
03-17-2016, 03:40 PM | #1000 |
Drives: 2014 Porsche Cayman S
So, I went for it and got the Edelbrock installed by Neal at The Racer's Line this week and the install went perfectly. No issues to report and a 630 mile road trip the next day.
Note this is a stock vehicle and so the install was not complicated by other factors. Some have asked for driving impressions, so here goes... It does drive like stock with a bigger engine...that description is very apt. The power comes in with a surge and not a thump, but plenty there. The idle does act a little weird when cold, but no stalls and it calms down fairly quickly. There is a little dead zone on accelerator travel, but nothing my brain cannot figure out and just give a little more gas. Overall, I am very pleased as it matches my expectations and is a blast to drive. The issues mentioned above are small...very small. I agree with comments that this is the one to get for the money...incredibly professional kit, easy install and I foresee little maintenance, which for me (trust me) is a blessing.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
The Following 6 Users Say Thank You to paiceyfan For This Useful Post: | 86 South Africa (03-20-2016), BigFatFlip (03-17-2016), MicheleAbbate (03-17-2016), Nitro22 (03-17-2016), The Racers Line (03-17-2016), TOLM (12-27-2017) |
03-17-2016, 03:44 PM | #1001 | |
03-17-2016, 04:14 PM | #1002 |
Drives: anything you let me
03-17-2016, 04:17 PM | #1003 |
Drives: Scion FR-S 10 Series #2263
The Following User Says Thank You to aegisdrgn For This Useful Post: | Uplink (03-17-2016) |
03-17-2016, 04:40 PM | #1004 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Put car on "Acc", press the gas pedal to the floor about 5 time, start car and let idle for a few mins. The nice thing with this kit, my freeway gas mileage is roughly the same as stock (29-30 mpgs, used to be ~32 mpg). Wish I could say the same for city driving |
03-17-2016, 04:43 PM | #1005 | |
Drives: 2013 FRS
Looks like the same as my manual car at 950 RPMs, around .45 bar. I would think something like the fuel trims would be abnormal, since it would have extra air at idle if there was a leak and have to compensate by adding fuel. The bouncing idle certainly is a very common air leak issue, I've had it many times in other cars due to leaks. Maybe the manifold pressure isn't the best way to determine if you have a leak... |
03-17-2016, 04:56 PM | #1006 |
Also my milage has gone to shit. Everyday driving 12 mpg.
03-17-2016, 05:52 PM | #1007 |
03-17-2016, 06:20 PM | #1008 |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
