| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Whiteout FR-S
Subaru or Toyota drain plug?
I have a very strong feeling that its Subarus drain plug, but for those who have changed their oil (if any), do you know if its Toyotas drain plug, or the more likely Subaru?
My main reason for asking, I plan on buying a magnetic drain plug, and would be very disappointed to buy one for Subaru, only to find out it for some reason has Toyotas oil pan. |
#2 |
Subaru drain plug # 807016160, used on 2010 and up Outback/Legacy, 2012 Impreza, and BRZ. Uses gasket 803916010.
| The Following 4 Users Say Thank You to sparks For This Useful Post: | Fly Guy (06-08-2012), lordtakuban (06-25-2012), Sportsguy83 (06-11-2012), yayforaddison (06-07-2012) |
#3 | |
Drives: 07 STI, 03 WRX, 13 BRZ
http://www.quickoildrainvalve.com/Se...lts.asp?Cat=40
#4 | |
![]() http://www.shopgreddy.com/accessorie...ug-subaru.html |
#5 |
Señor Member
Drives: 2013 SSM DZE BRZ
#6 |
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
I'm pretty sure it's a Subaru drain plug. If you would like I'll order one on Monday and comepair it to the Toyota one see what the difference is. I know the dpg is completely different it uses a metal crush type that is slighty larger that a Toyota 12157-10010 normal Toyota engines use a 90430-12031 composite metal fiber type. So I'm guessing if it is at all close to a Toyota plug it's gonna be a differential drain or fill plug.
#7 | |
#9 |
Ok, did my oil the other day. The Fumoto valves for the new Outback and Impreza work (16mm thread). One note, however. I got one of the valves with the nipple to make oil changes even cleaner. Unfortunately, the end of the nipple is just flush with the skid pan. If I were to run over something I risk tearing the valve out of the oil pan. So for my next oil change I'm going to put in one without the hose nipple.
#10 |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
How reliable are those Fumoto valves?
I'm mostly concerned about the valve being sheared off because the skid pan doesn't cover the drain bolt. The other concern with the quick drain valve is leaking. I'm trying to decide between this and a magnetic drain plug. |
#11 | |
If you get the valve without the nipple you don't have to worry about clearance issues. There would be about an inch of clearance between the bottom of the skid plate and the valve. So if you were to hit something hard enough to take out the valve, you've got other issues to worry about, like high-siding the entire car.
| The Following User Says Thank You to Draco-REX For This Useful Post: | F1point4 (06-25-2012) |
#12 |
Drives: Silver AT Limited
Draco-Rex - do you have a picture of the fumoto valve with a nipple being flush to the skid pad? I ordered one last week and I wonder if I should return it to get the one without the nipple
#13 |
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S, '09 BMW 135i
Why haven't I bought these ball valves since I've started driving??? Thanks guys!
~Matt
Efimia (asphalt FRS) |
#14 |
Photo Specialist
I'm strongly considering the fumoto, but is there a major improvement in using a magnetic drain bolt? I don't mind some mess if it means a cleaner engine.
#15 | |
A filter magnet will capture more metal than just a magnetic drain plug. And you can cut the filter open and inspect it if you want.
| The Following User Says Thank You to Draco-REX For This Useful Post: | MattR (06-28-2012) |
#16 |
I'll try to get under there and take a picture. And hopefully I'll remember to use a straight edge to compare.
#17 | |
SE Region Moderator
Drives: Limited BRZ
Draco, how did you lift the car? Jack with 2X4? |
#18 | |
| The Following User Says Thank You to Draco-REX For This Useful Post: | Sportsguy83 (06-27-2012) |
#19 |
Pictures.
The F-108N doesn't hang below: ![]() But it's very close:
#20 |
Drives: Whiteout FR-S MT
I thought the drain plug size was M12X1.25, someone correct me, i want to get a Magnetic drain plug for my FR-S.
#21 |
Drives: '13 Argento FR-S
Received my nipple-less Fumoto valve yesterday (havent installed it yet) but it came with a nice removable plastic nipple perfectly sized for the tubing. with the plastic nipple on it looks like the pics of the nippled valves. just saying.
2013 Argento FR-S -> UNIChip Custom Tune with Flux2 interface, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
| Servicing: BRZ at Toyota / 86 at Subaru | celicajim | AUSTRALIA / NEW ZEALAND | 8 | 12-14-2011 03:37 PM |
| Honda to show off EV plug in concepts at Tokyo Auto Show | Dark | Other Vehicles & General Automotive Discussions | 4 | 11-10-2011 07:34 PM |
| Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling | Hachiroku | Photos, Videos, Wallpapers, Gallery Forum | 112 | 09-17-2011 09:51 AM |
| Toyota FR-86 vs. Subaru BRZ | Levi | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 08-30-2011 05:04 PM |
| Subaru/Toyota Coupe spotted in Socal with Subaru Plates | owsiu | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 05-25-2011 09:27 PM |
