follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Member's Car Journals
Old 06-11-2012, 12:29 PM   #45
Crashoverride
here, there, any where
Drives: FR-S SOON!!!
Originally Posted by Ishii Motors View Post
I'm going to deny that number for control factors of repetition.
run file 003 was a 4th gear the others were 5th gear.
The top speed sample was 5th and 6th gear.
Ishii
How did you break in the motor to get the excellent results? PM me because I will want to mirror your power results thus far.
Crashoverride is offline   Reply With Quote
Old 06-11-2012, 12:45 PM   #46
mines13
FT86Club Official Vendor
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
That won't be a problem, just visit a poorly calibrated inertial dynomometer. Inertial dynos sure is optimistic, but then again anything that accelerates a fixed mass drum would be. One should only trust an eddy current brake dyno for anything but comparing the delta on the same vehicle under the same conditions after a change. In real life your engine and drive train are loaded, on an inertial they are not.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere." -Colin Chapman
My build thread
mines13 is offline   Reply With Quote
Old 06-11-2012, 12:57 PM   #47
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
The Dyno was a Dynojet 424LCX with Twin Eddy's.
Break in? Lots of acceleration and LOTS of Deceleration.
Ishii
Ishii Motors is offline   Reply With Quote
Old 06-11-2012, 01:46 PM   #48
mines13
mines13's Avatar
Ishii
Interesting, that model must have very small PAUs. I guess the number would be left to calibration and/or the fact that they did not apply a correction factor as is specified in the graph. Was it having tach signal drop out issues? It would appear that it was having said issue on a few of those graphs.
My build thread
Old 06-11-2012, 02:03 PM   #49
Ishii Motors
Drives: Scion FRS
It may be our clean green air up here, another car dynoed on a similar dynojet locally and put out 171hp in 4th gear. Ours did 175hp in 4th.
Ishii
Old 06-11-2012, 02:48 PM   #50
mines13
mines13's Avatar
Ishii
I could see it on a cool day with decent humidity and no correction factor, much like what is written on the detail portion of the graph. Corrected number will be a bit lower with out a doubt, more in line with the corrected numbers we have been seeing.
My build thread
Old 06-13-2012, 07:50 PM   #51
Ishii Motors
Drives: Scion FRS
Pacific Raceways
Took the FR-S out to Pacific Raceways in Kent Washington Today.
Car handled great, real steady and predictable.
We ran the car with the stock tires. This and the brake pads was our major bottle neck. The tires... well, do I really need to say anything?
The brake pads were fading quite badly and wearing out quickly.
After a few laps we reduced compression on the fronts by one click curing a bit of harshness that was upsetting balance.
Fastest time of the day was min1:45.25
All in all quite impressed. Will now need tires and a sway bar matching then Brakes deffinately.
So the set up of the car today was:
lighter battery
KW V3 Coilovers lowered 1.25 inches
Dot 5 brake fluid
no spare tire
no radio in dash (lap timer installed instead)
K&N Drop in Air Filter
HKS oil filter
Mobil 1 0w/40 oil
Ishii
Old 06-13-2012, 07:51 PM   #52
Ishii Motors
Drives: Scion FRS
Vancouver FR-S Demo Day? XIIIth CANADA 33 05-31-2012 08:00 PM
DEMO DAY FRS MISSISSAUGA Ad8707 CANADA 4 05-04-2012 10:01 PM
Demo cars preetham Southwest 0 03-15-2012 03:59 PM
Demo car in IL The_Doctor Great Lakes 1 03-07-2012 10:02 PM
GT5 Demo GT Off-Topic Lounge 43 01-16-2010 07:00 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
