follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Marketplace > Commercial Classifieds > Brakes, Suspension, Chassis
Old 05-18-2012, 11:11 AM   #1
ImportImage
FT86Club Official Vendor
Drives: 2012 Nissan GTR, 1993 Lexus SC300
Send a message via AIM to ImportImage
BC racing coilovers @ Import Image Racing
CALL 941-257-9618 and mention BILLY to receive special pricing ON FT86club!!!!!
**Remember with Import Image you make YOUR OWN package deal! The more you buy the even great your discount gets **
Price: $995 Delivered! WE WILL NOT BE BEAT! If you find it lower anywhere else we'll beat it!
Click below to order right off our website!
BC racing coilovers!
We are the #1 Vendor in the nation for BC Racing coilovers!
BC Racing BR series Coilovers!! Free Custom Spring Rates as well!!
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
BC Racing RAM type (Inverted)!!!
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- One year warranty
- Rebuildable
BC Racing ER series!!
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- One year warranty
- Rebuildable
Disclaimer- Ad specials not valid on website, only valid by calling 239-540-6385 visa/mc or paypal/googlecheckout.com shipped pricing refers to the 48 states. If you send a payment and live in FL and do not add 6% sales tax, your item will not ship. All returns subject to 35% restocking fee so make sure you want the part before you buy it! if received after 7 days, store credit will be given. after 2 weeks, returns will not be accepted. price subject to change due to manufacturer changing prices.
Regards,
Billy@importimageracing.com
AIM: ImportImageBilly
ImportImageRacing | Discount Performance Parts | Subaru, Mitsubishi, Nissan, Mazda Import Image Racing
Shop Line: 941-257-9618
Visa/Mastercard/Discover/Paypal and (amex) Google checkout!
Import Image Racing - Automobiles and Parts - Cape Coral | Facebook
ImportImage is offline   Reply With Quote
Old 05-18-2012, 02:07 PM   #2
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
Do they actually have coilovers made for the frs/brz yet?
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-21-2012, 09:20 AM   #3
ImportImage
They will as soon as it's released!
Old 05-21-2012, 09:27 AM   #4
ESBjiujitsu
its released but im very excited i like BC products....and their price!!!
Old 05-30-2012, 11:19 AM   #5
ImportImage
Wednesday Bump!
Regards,
www.importimageracing.com
Phone#: 239-540-6385
www.facebook.com/officialimportimageracing
Old 05-31-2012, 12:49 PM   #6
ImportImage
Thursday Bump!
Regards,
Old 05-31-2012, 02:23 PM   #7
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
availability date for the FRS/BRZ?
Enigmus is offline   Reply With Quote
The Following User Says Thank You to Enigmus For This Useful Post:
ESBjiujitsu (05-31-2012)
Old 05-31-2012, 02:39 PM   #8
ESBjiujitsu
yeah bumping a product thats not even available yet for the platform of the forum your positing on is kinda funny.
The Following User Says Thank You to ESBjiujitsu For This Useful Post:
fatoni (05-31-2012)
Old 06-05-2012, 01:45 PM   #9
ImportImage
Any day now
It will be available very soon. So we're taking pre-orders for people that want them. I don't see any harm in that
The Following User Says Thank You to ImportImage For This Useful Post:
ESBjiujitsu (06-05-2012)
Old 06-05-2012, 02:12 PM   #10
ESBjiujitsu
Originally Posted by ImportImage View Post
Any day now
Wasn't trying to sound like a ****.... just was saying it looked funny! Love me some BC products! always priced well!
Old 06-06-2012, 02:20 PM   #11
ImportImage
No worries :P
Owner over @ BC says Mid June !
ESBjiujitsu (06-06-2012)
Old 06-14-2012, 12:10 PM   #12
ImportImage
Thursday Bump!
Regards,
Old 06-21-2012, 01:57 PM   #13
ImportImage
Thursay Bump!
Regards,
Old 06-21-2012, 02:36 PM   #14
leej
Drives: 86 GTS
hi, quote me: BC coilovers shipped to sydney australia
leej is offline   Reply With Quote
Old 06-22-2012, 08:43 AM   #15
ImportImage
Sorry but due to BC contracts you must buy BC's from an Australian Dealer.
Here's a little update I just got from BC!!
Regards,
Old 06-26-2012, 11:02 AM   #16
ImportImage
Tuesday Bump!
Regards,
Old 06-27-2012, 04:52 PM   #17
OldSkool86
Drives: Corolla
BC said their coilovers will be ready to ship in 2 weeks.
OldSkool86 is offline   Reply With Quote
Old 06-28-2012, 11:57 AM   #18
ImportImage
Taking preorders now!
Old 06-29-2012, 02:03 AM   #19
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
price?
xclusive_brett is online now   Reply With Quote
Old 06-29-2012, 02:48 AM   #20
GUYVER116
GT86
GUYVER116's Avatar
Drives: Whiteout FR-S:(5/14/12)
Add to the preorder list for your FR-S coilover please.
Can you pm me pricing..
Thanks
FR-S Whiteout
GUYVER116 is online now   Reply With Quote
Old 06-29-2012, 02:49 AM   #21
V1B
V1B's Avatar
Drives: Scion FRS
Originally Posted by xclusive_brett View Post
price?
X2
V1B is offline   Reply With Quote
Old 06-29-2012, 08:56 AM   #22
Enigmus
Enigmus's Avatar
so preorders get delivered when?
BC Racing coilovers installed KAB-FRS Suspension | Chassis | Brakes 30 04-04-2013 06:56 PM
BC Racing BR Coilovers Blaster Suspension | Chassis | Brakes 19 07-22-2012 05:11 AM
Megan Racing Coilovers for your BRZ/FRS IslandImportPerformance Brakes, Suspension, Chassis 3 07-21-2012 10:14 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
