| Engine, Exhaust, Transmission, ECU Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: '13 WRB BRZ
Any (easy) way to stiffen up the feel of the clutch?
I love my new BRZ, but with the soft clutch its hard to know when the tranny couples with the engine. Is there some way I can adjust the clutch so I get more feel out of it?
#2 |
I'm different, yeah I'm..
Drives: Attitude
Check if there's a clutch delay valve; unhooking that will give you more direct and less dampened clutch feel.
#3 |
Drives: white 2013 Scion FR-S
Make sure to post if you find an answer because I definitely would like a little more clutch feel....
#4 | |
Drives: 2013 Scion FR-S 6MT
Love the car not the clutch do much
I don't always drift every corner, but when I do, I drift FRS
. Stay drifty my friends ![]() 2013 Scion FRS Whiteout 6MT |
#5 |
Drives: WRB BRZ, STI on order
Honestly, when I just got the car I thought that it was needed too, but after roughly 500 miles I got used to it and don't think this is needed.
#6 | |
#8 | |
Drives: '13 WRB BRZ
is kinda a joke. |
#9 | |
#11 |
Rocket Surgeon
Drives: PSM GGA OMG
That depends on what you consider "easy". The easiest solution would be to wait for some aftermarket clutch company to make a more heavily sprung clutch, buy it and pay someone else to install it for you. Alternatively, find out the bore of the stock clutch master cylinder (it should be stamped into the side of the MC), then get a larger bore clutch master cylinder for some other Subaru and hope it fits.
#12 | |
Drives: BRZ!
(I don't have the car yet...) If it is like my previous IS300, there could be a tiny damper between the master and the slave in the engine, you just unscrew it, put a fitting to connecter the two ends together, and boom 100% more clutch feel.
#13 |
Re-member
Drives: Toyota Sorara
Is that line fluid filled or is it a vacuum line? What does the damper do? how does it change the feel exactly and are there any drawbacks?
Nothing decays like progress, and nothing preserves like neglect.
#14 | |
Rocket Surgeon
Drives: PSM GGA OMG
That's the hydraulic line for the clutch, the damper is mounted inline with the master and slave cylinders and effects the flow of fluid between the two.
Torque pulses from the crankshaft cause vibrations in the flywheel that are transferred through the clutch release mechanism during clutch (dis)engagement. These vibrations travel through the clutch hydraulic line, through the master cylinder and into the pedal where they can be felt and sometimes heard by the driver. The damper gets rid of these vibrations. It doesn't change the pedal effort, it just disconnects you a little from the clutch. It's a bit like steering rack bushings; the car turns the same with soft bushings but you don't get the same direct feedback/response feeling you would have with stiffer bushings. On some cars, they are also set up to restrict the maximum flow rate of fluid from the slave cylinder to the master cylinder as a sort of anti-clutch-drop measure to help keep transmissions in one piece. A prime example is the WRX: 2002 = no damper, 2003 = damper. Last edited by old greg; 06-03-2012 at 01:38 AM. |
#15 |
Lightness is a sickness
Drives: 03 Acura CL-S6 & 13 Scion FR-S 6MT
I hate the feel - or lack thereof - from the stock clutch. I removed the damping device and the check valve that was in my CL, and it made a huge difference. Ill be seeing if this car has the same thing.
2003 NBP Acura CL-S 6MT, very very sleepy, 1 of 480
2013 FR-S 6MT, Asphalt, First 86 |
#16 |
Drives: 07 STI, 03 WRX, 13 BRZ
Wait until you get back into a car with a normal clutch. When I stepped on the clutch to start my STI I had to double check to make sure I wasn't stepping on the brake pedal.
| The Following User Says Thank You to Draco-REX For This Useful Post: | civicdrivr (06-03-2012) |
#17 |
I'll try to remember to see if it's easily found/removed like this. The usual Subaru delay valve is a bit harder to get to.
#18 |
Drives: '13 WRB BRZ
If you guys find it, and mess with it, let me know how it turns out. Haha not saying I want ya to be guinea pigs though
#19 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
The light clutch was one of my complaints as well. Looked under the hood today. There is only about 15 inches of clutch line in total. About half hardline, half rubber. The connection between the hardline and rubber appeared to just be a standard fitting, vs a delay valve. I don't think we are gonna find any improvement there.
The hardline is mostly arranged in a large loop. Probably to act sort of like a damper. You could probably regain a *tiny* bit of feel with a braided line straight from the master cylinder to the slave. |
| The Following User Says Thank You to FrX For This Useful Post: | MindtheGap (06-03-2012) |
#20 |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
Evidently I'm in the minority. Although a bit more 'feel' might be nice for some people, strengthening the clutch would just end up aggravating my knee injury. I was already worried that it would be too hard, but the clutch feel was predictable and obvious to me. I haven't even come close to stalling it even without having driven a manual in almost 12 years, and the shifts are always crisp and smooth.
#21 |
Loves the Smell of Track
Drives: '13 86
Is there a pedal return spring?
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O http://www.ft86club.com/forums/showthread.php?t=7934 |
#22 |
N7 Spectre
Drives: 2013 Scion FR-S (Firestorm - 6MT)
There is, under the steering column; it's in plain view attached to the pedal; I beleive removing this spring & just leaving the pedal to work only against the master cylinder would do the trick
I just didn't want to mess with it yet; one thing I did modify was the clutch grab point by screwing in the master cylinder threads into the clutch pedal bracket. Lowered physical pedal height & now my clutch grab point is super close to the floor without any gear grinds/ hesitation shifting back & forth between 1st and Reverse
GT5 PSN: Koji_Online
XBoxLive ID: KojiOnline4 |
| The Following User Says Thank You to Koji_Online For This Useful Post: | normancw (06-09-2012) |
| Clutch/brake smell | mr2lor | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-24-2012 12:45 PM |
| Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission, ECU | 102 | 04-12-2012 06:21 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission, ECU | 42 | 02-27-2012 02:48 PM |
| Steering Wheel Feel | ap5512 | Subaru BRZ General Forum | 8 | 12-08-2011 10:16 AM |
| Feel like a Post Whore. | Siriusly.Andrew | Off-Topic Lounge | 60 | 03-14-2010 04:42 PM |
