| Subaru BRZ General Forum All discussions about the Subaru BRZ coupe |
Drives: Honda Fit
2 rubber grommets in the glove box
Finally took delivery of my car last night but found 2 rubber grommets in the glove box still in the bag. The bag says it's for pre-inspector to place them in the sill. Not sure what that is for, anyone?
#2 |
Reverse Burnouts
Drives: 2013 Argento FRS
Door stils?
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S |
#3 |
Drives: Honda Fit
I forgot what it said exactly on the bag, I'll look again when I get home from work.
#4 |
There are two holes in the rear sub-frame just in front of the wheels. Look in the area of the rear jack points. The plugs go there. Your Dealers should have done this on their PDI (Pre-Delivery Inspection)
| The Following User Says Thank You to sparks For This Useful Post: | GregV (08-23-2012) |
#5 |
Drives: Honda Fit
Okay thanks, I'll take a look tonight.
#6 | |
Drives: 2013 Subaru BRZ
If you look under the body right before the rear wheels you will see 2 holes. One per side. They pop in. I installed mine. No lifting of the vehicle required. Takes 2 mins at the most. |
| The Following User Says Thank You to Mavrik For This Useful Post: | GregV (08-23-2012) |
#7 |
Drives: Honda Fit
Wonder what it's for and why dealership didn't install them.
#8 |
Drives: AW11 MR2 20v, E30 BMW 318is
#9 |
Re-member
Drives: Toyota Sorara
Those rubber grommets are essentially plugs to prevent stuff (animals/ road crud) from getting in the frame. There are holes in the frame from manufacturing. Dealers often forget to install these, but it does show that your dealer did not do the pre-inspection completely. I wouldn't worry but its annoying at the same time.
Nothing decays like progress, and nothing preserves like neglect.
| The Following User Says Thank You to ahausheer For This Useful Post: | Hanzo (05-30-2012) |
#10 | |
But on topic. I printed out the PDI inspection form for the BRZ. Its about a 30 page document lol. Appears as though those holes are used for tie down used during transportation. |
#11 |
Drives: Silver AT Limited
Happened to me as well when I took delivery of teh BRZ. Good thing I caught it while I was picking up the car, the dealership installed it in 2 minutes.
#12 |
Any chance you could upload this somewhere for us? I'd love to see what the list consists of!
#13 |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
#14 | |
And we can only see it in HTML format. Hard part is SOA has legal control of their web stuff. It's not like the current STIS system where you pay for access to download the PDF files. We should get the PDF stuff soon, the cars are on the ground! |
#15 |
where did you get that form?
#16 |
Vindictive S.O.B. Member
Drives: '13 FR-S
#17 |
you should be able to save the html.
#18 | |
Seasoned Spirit
Drives: 2013 DGM BRZ Premium #00084
edit:
#19 |
I'll see what I can do
It was passed on to me from someone else. I used to work for a subaru dealership but I don't have STIS access anymore either.
#20 | |
| The Following User Says Thank You to sparks For This Useful Post: | Zgrinch (05-30-2012) |
#21 |
Drives: Honda Fit
Installed them last night. It was very easy, thanks guys!
#22 |
As Seen On The Internet
Drives: NA8, WRX, BRZ 6MT Limited
My dealer didn't install them either. Too me 4 seconds to find the hole, 2 seconds to install. 2nd side took only 2 seconds.
Hole is located about a foot in front of rear tire, right behind the pinch weld. Easier to feel for than to see, but is visible. |
| The Following User Says Thank You to ashtray For This Useful Post: | poudre (07-02-2012) |
| Hard compound street rubber? | slaxx | Wheels | Tires | Spacers | Hub | 10 | 05-01-2012 06:47 AM |
