follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission, ECU
Engine, Exhaust, Transmission, ECU Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain.
Old 05-06-2012, 11:10 AM   #1
Afdad120108
Drives: Mr2
Fr-s with subaru turbo?
So as rumors circulate there is talk that subaru is going to make a turbo for the brz while trd is in works for makeing a supercharger. My question is if subaru makes a turbo for the brz would it be a direct bolt on to the FA20 fr-s motor? I want forced induction but would rather have a turbo than a supercharger
Afdad120108 is offline   Reply With Quote
Old 05-06-2012, 11:12 AM   #2
carbonBLUE
Reverse Burnouts
carbonBLUE's Avatar
Drives: 2013 Argento FRS
yup, probably....
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
carbonBLUE is offline   Reply With Quote
Old 05-06-2012, 11:27 AM   #3
Guff
Thanking Meister Mod
Guff's Avatar
Drives: 1994 Toyota Supra-SW-BL/AT-61mm
If they have the exact same engine, why wouldn't the same part fit on both?
- The Ancient BRZ Sacrament
by Zaku
Old 05-06-2012, 11:48 AM   #4
Afdad120108
Drives: Mr2
Thats what i thought. The ECU and everything is made by subaru isnt it? So it should be easy to put it everything in the fr-s
Old 05-06-2012, 12:02 PM   #5
Guff
Guff's Avatar
As easy as it will be for the BRZ...
by Zaku
Old 05-07-2012, 03:44 AM   #6
jkonquer
Drives: 2005 Subaru STI
It all depends how far they go on their turbo. If they release it as a aftermarket kit then yes. But most likely it will be a engine from a wrx.
Understand that impreza na has totally different internals than the wrx or sti. Its not just a turbo, its literaly Everything! There is no way you can directly bolt this on. Probably be easier with engine swap.
Supercharger might be a different story.
jkonquer is offline   Reply With Quote
Old 05-07-2012, 10:56 AM   #7
Draco-REX
Draco-REX's Avatar
Drives: 07 STI, 03 WRX, 13 BRZ
If Subaru comes out with a Turbo BRZ, it's likely the engine won't be left as it is now. The engine would have lower compression pistons most likely, as well as other tweks like bgger injectors.
If you're thinking of bolting a turbo to your N/A FR-S, you'll have problems. Swapping the whole engine, on the other hand, would work.
Old 05-07-2012, 12:15 PM   #8
Dimman
Kuruma Otaku
Dimman's Avatar
Drives: BD Legacy and Mk3 Supra Turbo
Any news on what Subaru is doing with the DI 1.6T they showed off beside the FA20 a while ago?
Impreza? BRZ STI? New car? Base WRX, and the WRX STI gets a 2.0T?
Because titanium.
Dimman is online now   Reply With Quote
Old 05-07-2012, 07:13 PM   #9
bigbird83
Future Owner
bigbird83's Avatar
Drives: Honda Accord Coupe
I read a pretty interesting article in Motor Trend about this. They were implying that, amongst other things, Subie execs were actually leaning toward a supercharged setup sourced from TRD because the car is so light and RWD. Now this was a little blurb in an article talking about marketing the car from both companies(IIRC) but it did raise the question about whether a turbo would be the best option if you wanted a smoother powerband. Now me, I know little about turbo setups muself but I'd assume you could accomplish that somehow.
"You know you are a true car nut when you look forward to something breaking as an excuse to upgrade" - Ed Loh
04 Accord Coupe V6 6m
bigbird83 is offline   Reply With Quote
Old 05-07-2012, 08:06 PM   #10
DIG1992
DIG1992's Avatar
Drives: 2002 Acura TL
even though were talking about the brz here the next WRX is rumored to get a electronic turbo so we might see that in the brz
DIG1992 is offline   Reply With Quote
Old 05-07-2012, 10:50 PM   #11
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: '00 Subaru 2.5RS
If they go w turbo... They have hellova stuff they need to figure out other than internal parts. Intake & exhaust relocation, TMIC or FMIC figuration, if it's FMIC redesign radiator, if it's TMIC they need to move the engine forward, & list just goes on & on
Old 05-08-2012, 12:19 AM   #12
serialk11r
Drives: 2000 MR2 Spyder
Yea, this is why I think they'll stick with NA until not only have next generation forced induction and electronics have matured, but also when they are absolutely required to hit fuel efficiency goals. A very advanced electric turbo system would come with a whole host of power electronics, and to increase fuel efficiency I think they'd first be looking at hybrid systems before turning to downsizing+complex FI.
Old 05-08-2012, 01:34 AM   #13
Jimbo
Jimbo's Avatar
Drives: 92 NSX, 08 Accord
Yeah, I'm not understanding how they could release a bolt-on supercharger (or turbo) that would work well with the current high-compression engine. Unless it only had 2 lbs of boost or required thick head gasket spacers.
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ)
2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold)
2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue
Jimbo is offline   Reply With Quote
Old 05-08-2012, 10:12 AM   #14
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Direct injection helps prevent knock. It allows for a higher knock threshold than port injected engines.
uspspro is offline   Reply With Quote
Old 05-08-2012, 10:27 AM   #15
Turbowned
Turbowned's Avatar
Drives: AW11 MR2 20v, E30 BMW 318is
The ECU is made by DENSO, just to clarify. It may have Subaru stamped on it, but it's a DENSO unit.
Personally I think a supercharger is a much better fit for this car, if you want to keep it a smooth and responsive driver's car. While I've owned and driven a few turbocharged sports cars in the past, I can't say they were necessarily driver's cars. Maybe the RX-7 and Mazdaspeed MX-5; those are the only turbocharged driver's cars that come to mind.
/opinions.
Old 05-08-2012, 04:07 PM   #16
Afdad120108
Drives: Mr2
Im well aware that engine internals and such would have to be changed i guess what im wondering is if the ppl that buy the brz are able to go to subaru for an " upgrade" an have the turbo installed tuned etc etc could we with our fr-s got to subaru and do the same thing since the engines are the same?
Old 05-09-2012, 12:57 PM   #17
Bristecom
Bristecom's Avatar
Drives: 99 Mitsubishi Eclipse GSX, Evo X MR
/opinions.
Yeah, small turbos are OK. My 2G Eclipse has a tiny Garrett which is good. But most cars have medium-large sized turbos which have too much lag to be fun and responsive IMO.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 05-16-2012, 11:19 PM   #18
TwinscrollGT35R
Drives: 2006 Subaru
You can put a turbo or S/C on this car in stock form. Yes the injectors will have to get figured out. Since its a direct set up and the pressures are off the roof. But there is plenty of room on the FR-S/ BRZ to add a turbo in the same location as the wrx.
That being said. Once the ECU's are figured out, You would be able to bolt on a low boost turbocharger and run the car. 5-6 psi tops. But you will have to figure out the injector deal 1st.
Direct injection is not like the old days of the wally255 in a tank. These systems run at over 2800psi.
TwinscrollGT35R is offline   Reply With Quote
Old 05-17-2012, 02:09 AM   #19
chulooz
Registered user
chulooz's Avatar
Drives: 99 impreza coupe
So clearly the answer is actually no in a literal sense.
chulooz is offline   Reply With Quote
Old 05-17-2012, 03:30 AM   #20
serialk11r
But the HKS S/C? I suppose they haven't actually told us what's really going on, but somehow I doubt that they developed new injectors and internals to make that thing work. As arghx7 noted, Toyota's dual fan spray injectors are quite unique.
The Following User Says Thank You to serialk11r For This Useful Post:
Saibot (05-17-2012)
Old 05-17-2012, 03:40 AM   #21
Dimman
Kuruma Otaku
Dimman's Avatar
Piggy-back.
Plus the developments parts display that had the headers also had cams, pistons and rods.
Because titanium.
Old 05-17-2012, 04:30 AM   #22
serialk11r
Piggy-back.
Ah. Thanks, didn't realize they were all part of the kit or whatever, 290hp on stock everything would be scary shit.
Report: Subaru Coupe STI Model Possible, But Without Turbo Hachiroku Subaru BRZ General Forum 168 07-28-2011 09:03 PM
Assumption: Subaru=Turbo / Scion=NA ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 159 06-20-2011 02:28 PM
Subaru BRZ Coupe STI turbo charged pictures (renders) brandon Photos, Videos, Wallpapers, Gallery Forum 48 06-13-2011 03:15 PM
Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 Hachiroku Subaru BRZ General Forum 89 11-07-2009 11:59 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
