follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA
CANADA Canada
Old 05-05-2012, 10:23 PM   #23
Khyron686
Khyron686's Avatar
Drives: 2010 V6 Santa Fe, 2013 FR-S Blue
Originally Posted by Rinker View Post
You said there's somewhat of a visibility issue? Would you compare it to as bad as the new Camaros?
Dude, NOTHING is as bad as a Camaro. A submarine has better visibility.
If you set your mirrors properly (pointing OUT not at the back of the car) there are virtually no blind spots. But if you are used to shoulder checking beyond 90 degrees to your left/right then yes there's no visibility. The pillar/down slope of the c pillar is huge.
http://www.linquist.net/motorsports/tech/mirrors/
You should only see the side of your car if you smush your face against the glass on the drivers side, and if you lean over and move your head dead center between the driver/pass seat for the pass mirror. It will take you an hour to get used to it.
Khyron686 is offline   Reply With Quote
Old 05-05-2012, 10:36 PM   #24
Sport-Tech
Sport-Tech's Avatar
Drives: Tiburon
^ Totally agree on the Camaro. The FR-S is a true greenhouse by comparison. Coming from an older car with greater visibility though the dropoff is noticeable.
Sport-Tech is offline   Reply With Quote
Old 05-05-2012, 11:16 PM   #25
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
This is a sports car. Just adjust your mirrors and you will be fine. Visibility should be better than in a 370z.
tripjammer is offline   Reply With Quote
Old 05-05-2012, 11:36 PM   #26
veewonwon
Drives: G37s, FR-S Firestorm 6MT
Yes, the visibility of FR-S is very good indeed, better than or equal to any RWD sports coupe that I've driven, old and late models. The 370z and G37s (my current DD) are no match in this regard.
veewonwon is offline   Reply With Quote
Old 05-05-2012, 11:45 PM   #27
veewonwon
This is great info for those who still haven't adjust/use the side mirrors effectively.
Old 05-06-2012, 12:45 AM   #28
Dr.Science
Drives: Nissan Frontier, Honda Element
Originally Posted by Heero View Post
Interesting to note that the analog speedo is pretty useless. I figured as much considering the fact that the decided to keep it to the left rather then in the middle.
I don't know about other cars, but that's typical of high performance Subaru's. My old WRX had the tach in the center, and so do STI's. The digital speedo is a nice addition, though.
Dr.Science is offline   Reply With Quote
Old 05-06-2012, 01:04 AM   #29
Marloon
Drives: 2012 Hyundai Elantra GLS
Originally Posted by Scion FR-S View Post
Cons:
  • not quite as light or lively feeling as a MX-5 at slower speeds (probably will be much better in this regard on highway)
  • steering feel not quite up to a 70's Porsche - has a more damped feel
  • bad blind spots, even over-the shoulder looks will not be enough - use mirrors!
  • hood level and bottom of windshield quite high relative to older sporty cars like Prelude, Integra, 1st gen Tiburon - a slight feeling you are being swallowed/cocooned in car, visibility not as good. Raising the seat to fully compensate cuts off forward upward vision too much.
  • shifter more notchy than an MX-5, a little too notchy IMO, but I can imagine it would be easy to get used to
  • front hood line has a black rubber gasket that peers through, makes the line too distinct - why did they not put the lid edge further forward at the lights?
I totally agree with this point. I really wanted the old sports car feel again with the low dash, low steering wheel, with GREAT visibility that is cognizant with the older 90' sports cars like the NA/NB Miatas, 1990, 1996 Integra.
Unfortunately, I was sitting in the lowest position possible and still felt cocooned/wrapped in the car. Nevertheless, the car is truly awesome for 2012.
Marloon is offline   Reply With Quote
Old 05-06-2012, 04:12 AM   #30
veewonwon
I was part of this morning test drive, and would like to put in my $0.02.
First off, thanks to the folks in the GB, Kenny Shaw and Mark (Scion), this has been a relatively relax and enjoyable experience. And a chance to meet all the pretty faces from this forum.
Back to the test, it was a beautiful 18C sunny morning, the location is in the city where roads are mainly consists of uneven, but not broken, pavements, no accessible freeway nearby, Sat morning traffic was relatively frequent. Payload was about 230kg (500lb), i.e. me and two passengers, quarter tanked gas. The test was about a 10 mins short run, 1st gear to about 6.5k, 2nd around 5k, 3rd was the top gear driven before getting myself in trouble.
Though the car appeared small, it is very comfortable in the supportive front seats, outward vision is excellent. Stock ground clearance is quite low, the wheel gaps appeared smaller than most of the pics posted. If I'd to lower it, it'll be about 1-1.5cm, but I don't think I'll do it anytime soon, may be never.
Trunk didn't look smaller than my G37s, and the back seats had more headroom, less for the legs though. After properly adjusted the seating position and mirrors, it felt less claustrophobic than the Lexus IS, yet everything is within reach nicely. Looking through the windshield, the two front fender bulges gave a well defined look, they reminded me of a Elise's front view.
Upon starting the engine, the idle is fairly quiet, but not use to the buzz from a boxer-4: though it rev'd smoothly and no shakes, the sound is rough. Also, there's more of the engine sound than the exhaust. While exhaust sounded like any ordinary coupe, the G37s has significant more weight and throaty sound. May be a cat back system down the road, will see.
Being the first test driver, I'd to back the car out with folks nearby, there was untrammeled view looking through the driver side window. It immediately struck me that it was better than all my last few DDs, namely the E46, G35, RX-8 and G37s. Surprisingly, even the direct rearward view was better than all the honorable mentioned. No one was hurt
The drive-off impression was: lightness, roll easy and smooth. Clutch take up was quick and smooth, more noticeable on a standing start with grade, beat all European's and my DD. The acceleration felt more like the RX-8, smooth and mild mannered, and is fast enough to beat most cars on the road. It doesn't feel as "macho" as the Mustangs, Cameros, Z370. Still not use to the boxer-4 buzz.
Turns were flat, virtually no dive and squat during spirited starts-stops. What I like the most was the well tuned compliant suspension, it suits the uneven city streets really well. Much like the smooth ride of RX-8. But that boxer-4 buzz ...
For the nitpicks: Subaru style MT shifter sucks, it sits too tall for no apparent functional reasoning. Will definitely try out the mentioned SS kit with a shorter stick when it becomes available. What else, hmm... cheap looking HVAC dials, I wanted a rear hatch .... sunroof which I may use in winter, butt unfriendly leather seats, annoying push start button, no subs to shake the ground, and how can I forget the boxer-4 buzz...oh well, whatever.
I still can't get over the fact that this initial test drive impression was very good indeed. Ever since I let go with the Supra Turbo (13.5 yrs, 300k kms), I switched to leasing only mode as all the honorable mentioned was not worth keeping longer than a few years. I'll see if this Toyota will stay with me for another 10+ yr - so this one will be a purchased, not leased.
Other than many pros already mentioned and agreed, my experience on this brief test drive event differs from Scion-FRS' cons as follows:
1. compare to many small hardtop sport coupes, like the FC and RX-8, this car feel as light, nimble and direct. The test drive conditions was unable to test for liveliness
2. steering feel is light, but feedback is as good as many late model coupes, RX-8 and Cayman still lead. At this point, I kind of prefer the lightness in the FR-S, it permits quick action without the fight, time will tell. Btw, the 70s 911s were not power assisted, my faint memory hinted that PS was added from the 964 onwards, which is the 90s.
3. see #26 above
4. the hood line is as low as I can bear, as further lowering will not contribute to better forward vision. The old Honda coupe's hood line was way too low to me (I've driven many Hondas, if not all), felt like sitting in a fish tank. Sorry I was not a Honda fan though I like the DC2-R drive feel, imho, the best fwd sports.
5. the MT shifts smoothly, there was no notchy feel at all. Yes, the MX5 + RX8 have shorter throws and more precise feel.
Thanks for reading this long post. Back to lurk mode.
The Following 4 Users Say Thank You to veewonwon For This Useful Post:
Dr.Science (05-06-2012), Grateful Dave (05-06-2012), normancw (05-12-2012), Sport-Tech (05-06-2012)
Old 05-06-2012, 04:26 AM   #31
veewonwon
Mazda RX-8 has no analog speedo, similar to the FR-S, a large center tech with digital speedo only.
http://l.yimg.com/dv/izp/mazda_rx_8_...entcluster.jpg
Old 05-06-2012, 05:15 AM   #32
Sport-Tech
Sport-Tech's Avatar
Drives: Tiburon
Thanks for the writeup veewonwon, I really enjoyed reading your perspectives - certainly broadened my own. Probably 3/4 of the differences in view we took from the drives is a result of our different prior experiences, mine being far more limited than yours (other than the Tiburon, a week with an Integra GS, and one parent's current-gen Corolla XR-S, just memories of Porsche, GTO, Fiat 124, 300ZX from my teens, plus a few more recent test drives). Very interesting to see how the FR-S compared to your past vehicles.
On your specific comments: I too found the wheel gap quite reasonable IRL, would not see a need to change it. Personally, I much prefer fish tank views to bunker-slit views (although I would not say the FR-S goes to the latter extreme) - it's one thing I have always liked about Hondas. Also, while the shifter may be no notchier than other RWD coupes, if you are coming from a FWD manual as I am, the tranny is going to feel notchy for sure.
Three years ago that portion of St. Clair the dealership is on looked like it was flown in from Afghanistan, it was so bombed out. And Jane St. was just as bad, it's all been repaved.
Old 05-06-2012, 10:39 AM   #33
carbonBLUE
Reverse Burnouts
carbonBLUE's Avatar
Drives: 2013 Argento FRS
A Whiteout MT was made available at Ken Shaw for a quick test drive this morning for those who pre-ordered. Drives were basically glorified around-the-block excursions lasting 7-8 minutes but were enough to get some initial impressions. As I live fairly near the dealership I was able to drive roads I know well and assess how the FR-S handled and rode them in comparison to my 1st-gen Tiburon. My first thoughts:
Pros:
  • solid solid solid. Car feels like it has been carved out of a big block of
    granite, vault-like rigidity and incredibly well planted.
  • Whiteout is an absolute knockout on this car.
  • steering weight seems just right, as does steering ratio
  • turn-in is immediate and responsive, no nose-heavy ploughing
  • brakes were simply outstanding on panic stop test - feel, smoothness, control
  • clutch has just the right weight, quick take-up
  • no lag in throttle response, and no throttle hanging
  • power is solid throughout the torque range in my view, no noticeable hole, certainly more than enough there to get you in serious trouble with the law very, very quickly.
  • engine note surprisingly quiet at idle, pleasant and not too intrusive at low /part throttle, really livens up at higher rpm, sounds strong even though the tone does not have the nth degree of refinement - Porsche still wins here. But definitely not blatty or ricey.
  • perfect size for its mission
  • great driving ergonomics for all controls; seat wonderfully body hugging (5'11", 150 lbs)
  • tail can cut loose a little bit even with full TC/VSC on
  • fabulous balance between handling and suspension compliance requirements, rides smoother than the current Corolla XR-S over irregularities. An Integra GS is a kidney masher by comparison.
Cons:
steering feel is going to be better than any other electronic steering you use today... LFA is better but the tech came form there, many have said the electric steering is better than Porsche and thats a lot to say.... i still have yet to take the car on an auto x track...
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
carbonBLUE is offline   Reply With Quote
Old 05-06-2012, 12:10 PM   #34
Sleeperz
Sleeperz's Avatar
Drives: 1982 Toyota Corolla Coupe SR5
Is the steering is electric power steering?
If the steering feels damp, Most likely, nothing will ever beat a manual rack and pinion steering since the steering control is directly from your hands to the tires. Unless someone develops an advanced control steering system using feedforward predictive algorithms to predict the steering before you even move the steering wheel.
Originally Posted by My first thoughts:
Pros:[LIST
[*]steering weight seems just right, as does steering ratio[*]turn-in is immediate and responsive, no nose-heavy ploughing [*]brakes were simply outstanding on panic stop test - feel, smoothness, control
Cons:
[*]steering feel not quite up to a 70's Porsche - has a more damped feel[*]bad blind spots, even over-the shoulder looks will not be enough - use mirrors!
[*]shifter more notchy than an MX-5, a little too notchy IMO, but I can imagine it would be easy to get used to[*]front hood line has a black rubber gasket that peers through, makes the line too distinct - why did they not put the lid edge further forward at the lights?[/LIST]
Sleeperz is offline   Reply With Quote
Old 05-06-2012, 12:23 PM   #35
pastuch
pastuch's Avatar
3. see #26 above
Having driven and/or owned most of the same vehicles you have I can't wait to compare notes.
Are you comparing the transmission from an NB miata or NA to the FRS?
pastuch is offline   Reply With Quote
Old 05-07-2012, 07:10 AM   #36
nathanR
Drives: 1993 Nissan NX2000
@Scion FR-S and @veewonwon
Thanks a bunch for the reviews. You two addressed a couple of my largest concerns with this car: visibility and drive-view. My most recent vehicle experiences include a MY04 STi, MazdaSpeed Protege, NX2000, and MazdaSpeed 3; all of which have decent to excellent visibility and I've never had to soley rely on the mirrors. If I elect to purchase this car, I'm going to have to get accustomed to using them.
Also, my personal preference is to be able to see the top of the hood when in a normal driving position. I'm around 5'10" and can't wait to sit in the car to see what kind of view I get.
nathanR is offline   Reply With Quote
Old 05-07-2012, 10:27 AM   #37
normancw
Drives: Raven FR-S, 2006 330i
^ I agree - thanks Scion-RFS, veewonwon, and Heero for the detailed reviews and photos.
I'm glad to hear the rearward view is good and that the front seat is height adjustable - I have an FR-S on order (for my wife and she's quite short).
normancw is online now   Reply With Quote
Old 05-07-2012, 11:26 AM   #38
veewonwon
NC, specifically MY07.
Old 05-07-2012, 11:45 AM   #39
veewonwon
Ditto.
I'd RX-8 & Yaris RS hatch as DDs before, they both use EPS that felt direct, quick, and responsive. I was very impressed and looking forward to have EPS on the FR-S.
One advantage of the EPS system on those cars was - assisted steering is available even when the engine is not running, this is great for rolling the car without starting the engine, e.g. get it out the garage to get washed.
With the brief test drive, I didn't get any bad feeling about the FR-S version, not something I worry the least bit at this point.
No experience on the Porsche and LFA versions, so no comment on them.
Old 05-07-2012, 12:42 PM   #40
veewonwon
I normally lurk on forums, due to busy work schedules. However, thanks to the folks here, and of course Scion Canada + Kenny, I felt it only be fair that I share my thoughts here.
Probably 3/4 of the differences in view we took from the drives is a result of our different prior experiences, mine being far more limited than yours ... Very interesting to see how the FR-S compared to your past vehicles.
Even someone had driven similar vehicles may have different opinions, it is more important that we value and respect the in-differences.
To me, my passion on driving is how to improve my own skill and make the best out of any vehicle. I've very busy work schedules, driving behind the wheel is one way of taking my focus away from work, hence, I'm a very focus driver.
Certainly, that's why Honda was very popular amongst its supporters.
Just a tidbit about the low hoodline (and windowsill) design - Honda can sell more cars to those that were unable to see out properly due to physical limitations. This is not an issue in the western world, but very apparent in Asia. Have you ever experienced catching up to a ghost vehicle in front - one you couldn't see the driver from behind?
The bunker-slit type? I thought only those who afraid of being shot buy them . Our humble FR-S is just a great tofu delivery machine.
Did you experience problem on shifting during the test drive, like hard to get it in 2nd or 3rd gears? B'cos my run was smooth as silk, upshifts were slick, downshifts were rev-matched, heel-n-toe from 3rd to 2nd on a couple of turns, even once from 2nd to 1st.
Guess some of our tax money was put to good use.
Old 05-07-2012, 04:56 PM   #41
Sport-Tech
Sport-Tech's Avatar
Drives: Tiburon
I did find getting into 2nd a bit tricky a few times; I think it's because I was trying to move the shifter too far towards me as I went for that gear though.
Old 05-09-2012, 08:19 PM   #42
Klinn
Drives: Firestorm FR-S, Black C6
Originally Posted by Klinn
One question regarding seating position: if you brace yourself in a brisk corner by putting your left knee against the door panel, do you recall if it rests against a soft piece of trim or a hard bit of plastic?
Sorry, forgot to check that. There are nice soft-touch plastics on the upper door and dash, felt very good. Not sure if it extends far enough down the door for knee protection.
Just got to sit in an FR-S for the first time, test drive tomorrow, but I noticed that unfortunately your left knee ends up against a hard plastic trim piece, on the side of the arm rest towards the front of it.
This means that after a long day of autocross runs, your knee is probably going to be sore. I've got this problem in the current summer toy. I think I need to invest in some gardening knee pads.
Klinn is offline   Reply With Quote
Old 05-09-2012, 09:10 PM   #43
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
I was going to suggest a knee pad while reading your post. Get a construction type one from home depot so that your knees will not hurt.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 05-09-2012, 09:24 PM   #44
Saibot
Saibot's Avatar
Drives: 01 Toyota Corolla / Porsche 911 C2
Just thought id add some insight into my test drive with the AUTO FR-S in st catharines today. It was a Silver A/T with Scion stickers all around it. odo had 2.2k on it.
The "scion rep" that brought it was the same guy who was at Kennedy Commons earlier in april. When he saw me, he instantly recoginsied me and said "WHAT are you doing here!?!?!" LOL.
I had a full hour with the auto for myself because the dealership didn't have any other test drives for 1hr15 min. The sales guy guided me to some craazy twisty back country niagara roads, and on the highway (QEW). The only catch was we were not allowed to turn off traction control. I did brake the back wheels lose (for like 2 seconds, even with TC still on) when doing a left turn though.
Paddle shifters were fine. Very natural feeling. Exhaust was OK. Its a bit too quiet for me, and so is the engine noise inside the cabin. Doesnt sound agressive at all when at low RPMs. When you bring it up above 5000, still doesnt sound that great. At idle, it sounds like my 2001 corolla when its in need of an oil change lol ( i guess this is how the boxer is supposed to sound o_O).
I was taking small twisty back country niagara roads with a limit of 10kmph at 50 and 60 with this car. Felt VERY solid, planted and literally no body roll. Not once did i feel like i needed to brake or was going to not make it through the turn or flip or even slide. Balance on this car is great as every other review says. Feels like im riding on rollercoaster tracks when taking really tight corners at high speeds.
amazingly, bumps were not a problem at all! we went over quite afew train tracks and i have no complaints whatsoever.
I do have a slight complaint about throttle response and power for the auto. Accelleration and the "suck you into the seat" factor simply was not there. Maybe because im used to riding in my buddy's M3's. Hopefully the manual feels better in terms of acceleration. (hence why i said feels like im on rollercoaster tracks when taking turns. Acceleration kinda sucks, its more momentum vs power that will push you through corners at high speeds). Throughout the entire test drive, every time i stopped at a stop sign or light, i kept wanting to dump the clutch at 4krpm to feel more power... but then realized it was auto T_T
If the manual ends up with dissapointing acceleration as well, bring on the mods! as it stands now, i feel like it deff needs more power. It is possible though that the stiff suspension is what makes me feel like i want more power. My hunch is with the subaru, since it has softer rear spring rates, the car raises its front more when accelerating, making the passengers feel like they're gaining speed alot faster?
Space in the back: I sat there. It was fine. I have no complaints. But then again; im 5' 7", 135lbs. I could sit there for hours and not complain. not too much of a hassle to get in or out like some other 2+2's.
Cupholders were moveable to accomdate people in the front or people in the back. I see huge potential for an after market armrest that also keeps the cupholders useful.
Windows seem really thin and lightweight; but were ok. Audio was nothing spectacular. Same as what Id expect in any other stock compact car. HVAC knobs were absolute crap though.
Visibility wise I had no problems. Sure i had less visibility than the civic i usually drive, but bleh; I didnt expect to be looking out of a fish tank. There was a huge blindspot as everyone else has mentioned in the rear corners but I just solved that by going 20-30km faster than everyone else when changing lanes LOL.
- Toby
Saibot is offline   Reply With Quote
Test Drive brzmass12 Subaru BRZ General Forum 8 04-12-2012 10:16 AM
Test Drive Impressions and MSRP confirmation engee Subaru BRZ General Forum 19 04-09-2012 10:37 PM
BRZ test drive invite aloretoc Subaru BRZ General Forum 32 03-25-2012 08:13 AM
Car Business test drive Sport-Tech CANADA 14 03-19-2012 12:09 PM
FT-86 Test Drive knoxviue Photos, Videos, Wallpapers, Gallery Forum 36 11-30-2011 12:43 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
