Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
#29 | |
Drives: '23 BRZ
#30 | ||
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Hmm... Need to do some thinking. |
#31 |
i'm sorry, what?
Drives: Canada
ALso, here is a MacPherson design used in a Lotus racing car.
I can guarantee you that under compression these thigns gain an ample amount of camber ![]() i'd say pre-aero days this would have been a fantastic design. ![]()
#32 |
Drives: Mazda 3
I only drive around on the street but even then I can appreciate a better setup suspension than stock. optimal static camber for maximum lateral grip level of the stock tires; more front roll stiffness from springs and less from sway bars will make steering response more linear and feel more supple. Having more bump travel in the rear will make taking bumpy corners so much more confidence inspiring. I've had quite a few instances on the street where the rear momentarily lost traction in the middle of a corner when hitting a bump, not to mention when the rear hits the bumpstops full-on, the chassis bounces off the bump stops and the whole car wiggles left to right.
there is so much I can improve on the stock setup that will make the car better without upsetting the balance and I only drive on the street... I see most bad setups start at very low ride height with not stiff enough spring rates or the use of too big sway bars... |
#33 |
Drives: Some rust bucket
Excellent gif. It took me a second to realize what I was looking at. I think the pause in the animation threw me off a little because it looks like I'm looking at the rebound effect rather than the compression effect.
Based on this animation, one can infer that macpherson struts gain negative camber under rebound when the LCA and strut are past the perpendicular point. Not really useful when you're cornering since you want the outside wheel to gain negative camber and not the inside wheel. |
#34 |
So all else equal, if you lower the front of the car, you'd want to increase spring rate to minimize the LCA and the strut from being perpendicular under compression.
Assuming @ZDan's suspension model is accurate, the front keeps gaining negative camber up until 4'' of compression. However, that doesn't take into account body roll, which changes the angle of the strut. That 4'' of bump travel is actually less when you take into account body roll, right? Then you also have to take into account caster, which can change the amount of camber when cornering. More caster equals more negative camber under bump. I'm sure there are other variables as well. Correct me if I'm wrong, but it appears you want the front to be as stiff as possible when tuning macpherson struts (ignoring all other factors). From a pure performance standpoint (ignoring cost, packaging, etc), double wishbone appears to be the superior design. I guess that's why Formula One still uses it. |
#35 | ||
i'm sorry, what?
Drives: Canada
but otherwise, F1 suspension design laughs and farts and throws beer bottles in the general director of production vehicle suspension theory. so you should NEVER draw any conclusions of F1 design and production cars. If you want to immitate a racing body.. watch what the rally guys do.
#36 |
So by adding camber plates and adding negative camber, you're essentially changing the angle of the strut. This means you increased the negative camber bump travel to greater than 4", right? Let's assume zdan's model is accurate.
#37 |
i'm sorry, what?
Drives: Canada
yes, but do it too much and wonky things start happening during steering
#38 |
There's some debate about whether it's better to add camber at the topmounts (camber plates) or at the lower strut mounting point (camber bolts). Using plates pushed in gives you a higher roll center and can improve camber curve. However, it also increases the SAI which has a negative effect on camber when you turn the steering wheel.
- Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | CSG Mike (03-28-2014) |
#39 |
Drives: 2016 Scion FR-S
Wow, this thread was very informative and exactly what I needed!
So since FR-S engineers added less negative camber to the front, this helps break out of a slide easier? (harder to oversteer?) |
Advice on negative rear camber | Thongpocket | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 09-27-2013 10:38 PM |
Camber Question | Ryeong86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-12-2013 12:05 PM |
Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
Camber Question | subaruatheart | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-24-2013 01:49 PM |
Excessive negative camber? | MTeator | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-22-2012 10:30 AM |
