08-16-2013, 09:51 AM | #225 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
The Following User Says Thank You to shiumai For This Useful Post: | white_knight (08-16-2013) |
09-03-2013, 09:59 PM | #226 | |
Quick question. Stock/lowered handling won't be affected with these correct? I'm planning on dropping the car an inch and wanted to double check! Also, where did you pick these up from? |
09-03-2013, 10:52 PM | #227 |
any time you change anything, handling will be affected - depends on what you want. these are wider wheels and tires; it does change the handling. for me, i wanted more grip over the stock setup, at the possible expense of some acceleration (which i have not really noticed), or understeer (which i also haven't noticed). i like the way this set up handles vs. stock, but YMMV.
09-04-2013, 12:46 PM | #228 | |
09-04-2013, 02:43 PM | #229 |
no rubbing so far, and i've driven on some pretty curvy/bumpy mountain roads. with only a 1" drop, there's still quite a lot of clearance to the fender. i got everything from evasive.
09-04-2013, 08:14 PM | #230 |
Just a dude
Drives: Scion FR-S 2013
The 57s and the TE37s are the two that never get boring on this car, for me at least. They look good in almost in any color on any color.
10-20-2013, 06:02 PM | #231 |
Drives: 2014 BRZ Limited (World Rally Blue)
Anyone have comparison pics between Matte Graphite and SG Black on WRB?
I can't decide on a colour. Also, what's the full lineup of colours anyway? |
10-20-2013, 07:29 PM | #232 |
Drives: SWP BRZ Limited MT
10-20-2013, 07:45 PM | #233 |
10-22-2013, 02:29 PM | #234 |
Drives: Raven FR-S
Gram Lights
Thoughts on 18x8.5 semi gloss black 57xtreme gram lights with 245/35R18 tires on raven frs?
The Following User Says Thank You to nosi9frs For This Useful Post: | TONYpepperon1 (02-11-2014) |
10-22-2013, 04:13 PM | #235 |
Drives: I own an FR-S. . . whatelse!
I think these are some of the best looking wheels on this car. So you have made an excellent choice. I would see if you can find pictures of the face 2 design which apparently look more concave...
10-22-2013, 04:28 PM | #236 |
Drives: Subaru BRZ - GBS
Agreed, also another option for a concave look is going wider, which leaves you with a 18x9.5. However to do this you need coil-overs or spacers.
10-22-2013, 04:50 PM | #237 |
Drives: Raven FR-S
will the 8.5x18's fit without issues on stock setup?
10-22-2013, 05:49 PM | #238 |
Similar Threads | ||||
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 | L8Apex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 71 | 08-05-2023 09:20 PM |
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 | WorkoArt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 02-18-2017 06:46 PM |
Candy Red Gram Light 57Xtreme 18X9.5 +40 | ugadogs_11 | Wheels and Tires | 8 | 10-03-2013 09:04 AM |
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 | funcheung | Canada Classifieds | 7 | 09-16-2013 05:01 PM |
