BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
06-14-2013, 04:19 PM | #15 |
Drives: 2006 Evo IX SE
The funny thing is, Tyrese did that in 2 Fast 2 Furious in that race against the musclecars. My guess is that somebody told him what to do but not specifically which part of your foot does what.
10-01-2013, 02:34 PM | #16 |
Drives: brz
This is my first manual car and I've been rev matching every time I downshift. Are you guys saying that rev matching is not required for this car?
10-01-2013, 03:16 PM | #17 |
Drives: SWP BRZ
This car is my first manual transmission as well. From my experience, if I don't rev match, the car will "lunge" forward. But when I do Rev match, it makes the car ride smoother.
10-01-2013, 03:18 PM | #18 |
It's not "required" for any car. It's just a good thing to do without any real drawback. It's smoother, helps speed up downshifting and lengthens the lifespan of the parts involved (i.e. clutch). Luckily now, there are a ton of resources (i.e. a thousand YouTube videos about it) to learn from, so you can probably practice it and more or less figure it out within a week or so.
10-01-2013, 04:15 PM | #19 |
Drives: 2016 WRX Limited
I never rev match. Lazy.
On a similar note, does anyone else get a noticeable grind going into 3rd? It happens in most of the gears honestly from time to time but almost always going into 3rd. Feels like a bad syncro IMO. |
10-01-2013, 05:06 PM | #20 | |
Drives: 2013 FR-S, 2008 Fit
Well maybe, in a way, they were saying that rev matching is not REQUIRED for this car... as in you don't HAVE to do it because like any modern car it has synchros... but it is certainly a very, very good idea to rev match on your downshifts with any manual transmission. |
10-01-2013, 06:07 PM | #21 |
Drives: brz
Thanks for clarification. I will continue to rev match during downshifts. Never got around to learn about double clutch.
10-01-2013, 06:08 PM | #22 |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
Just a stupid question, I've driven a stick for 11 years but when I downshift, I typically go from 6th/5th to 2nd with rev-matching below 60MPH, usually when I hit an offramp. Is that going to be problematic considering we can't skip gears upshifting without damaging synchros?
10-01-2013, 06:28 PM | #23 |
Drives: '13 BRZ, '06 997, Other Things(TM)
I can't make my leg do that either. I'm gonna need to get one of those gas pedal extension plates for my car though, 'cause when I wear normal shoes I can just barely grab both pedals with the sides of my foot, but when I wear my smaller, thinner shoes that I like to use for driving I can't get the right side of my foot to reach the gas
10-01-2013, 06:52 PM | #24 | |
If I am not coming to a stop I'll continue down to 3rd in the initial downshifting sequence and then continue onto the surface streets in 3rd. If I only brought it down to 4th/neutral because I was expecting to stop but then the light turns green then I'll just go from neutral to whatever gear I so choose as appropriate for the current speed of the vehicle and the rate at which I want to accelerate... ie if I'm down at 25 I could go into 3rd to just cruise forward granny style or 2nd if I wanna gun it. I've always been under the impression that if your car is currently in neutral and still travelling forward that you can throw it into whatever gear you want, some gears might need a bit of rev matching to get past the lockout but other than that I thought choosing your proper gear was fair game among all choices and part of the challenge of driving a stick. |
The Following User Says Thank You to mitosis For This Useful Post: | chanomatik (10-02-2013) |
10-01-2013, 07:41 PM | #25 | |
As for heel toe, it's easy to do the left/right rocker with the sides of size 13 shoes, and even easier with combat boots |
10-01-2013, 08:14 PM | #26 |
Drives: 2013 GBS BRZ Limited
You will not hurt the tranny by skipping gears going up or down.
There is noting magical inside that forces you to sequence through the gears in a certain order. You most certainly CAN rev match going both up & down. One thing I have noticed about this car: I cannot shift it without the clutch. On all of my other cars I could rev match, and shift clutchless. This car just does not let you do that. Also, for those talking about heel toeing this car.... I'm not sure they have actually tried it: 1 - the pedals are not set up (very well) for heel & toe 2 - The ECU does some strange things when trying to heel toe (wont let the revs stay up with the clutch in) I believe. |
10-01-2013, 08:25 PM | #27 |
It's not the BEST layout for heel-toeing, but it's not bad at all. It's way more pleasant to do it than in a 370Z, WRX/STI and a few other cars I can't remember.
The Following User Says Thank You to DeeezNuuuts83 For This Useful Post: | Pete156 (10-02-2013) |
10-01-2013, 08:32 PM | #28 |
Drives: '13 FRS - STX
Heel toe, skipping gears, and double clutching have nothing to do with what the OP is looking for: smooth gear changes. It takes finesse and practice and there's no right way to do it, find your own rhythm, watch a couple videos and don't worry about wannabe racecar drivers. Practice, everybody learns in time and the above whinging and ego stroking trying to show off your technique is inconsequential to seat time. KISS: Keep it simple stupid.
The Following User Says Thank You to strat61caster For This Useful Post: | DAEMANO (10-05-2013) |
Similar Threads | ||||
Matching car seat | Yruyur | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 05-05-2013 09:26 AM |
Rev Matching | Selvedge | Engine, Exhaust, Transmission | 17 | 11-11-2012 05:48 PM |
Color matching? | the Red Devil | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-14-2012 12:01 PM |
Matching shocks with springs | Ben_G | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 07-22-2012 09:32 PM |
Color Matching Headlights? | i2ex | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 06-23-2012 08:01 PM |
