Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
09-16-2013, 10:25 PM | #1 | |
Proud of BOXER
Drives: Subaru Boxer
BBS SR - 17x7.5 +48 & 18x8 +48
I stumbled across these on Tire Rack and really like them, despite the conservative offset. Currently trying to decide between 17x7.5 (21.8lbs) ($215 each) or 18x8 (24.6lbs) ($265 each). Thoughts?
The Following User Says Thank You to Clipdat For This Useful Post: | Laika (09-17-2013) |
09-17-2013, 03:20 PM | #2 |
Drives: 2013 SWP BRZ
Wow, great find! I might consider these as they are the perfect specs. Weight will be the deciding factor..
09-17-2013, 03:23 PM | #3 |
Drives: '14 S4
I really liked them too, but I couldn't wait the 6 weeks!
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
09-17-2013, 04:01 PM | #4 |
Drives: FR-S 10 #103 AT
I saw the title and thought you were going with different diameters front and rear.
Like the rims though.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
09-17-2013, 07:32 PM | #5 |
Drives: '15 WRX '13 Legacy '07 Colorado
Holy sex those are nice. Hows the weight?
09-17-2013, 09:18 PM | #6 | |
Proud of BOXER
I'm not sure yet on the weights, I've emailed Tire Rack and BBS and I'll make a post if they reply.
Here's some info about the wheel from BBS' site, they're calling it a winter wheel, hope that doesn't mean it's overly heavy. "The new BBS premium winter wheel combines elegance and sportiness with maximum functionality. True to the BBS company philosophy, it is completely and exclusively produced in Germany, just like all other models of the manufacturer. Soft radii and contours from the hub to the flange enable easy wheel cleaning, which proves itself extremely practical especially during the winter. Nevertheless, the rim design speaks loud and clear and unmistakably identifies the new addition from Schiltach as a distinguished member of the BBS family. Spokes that continue through to the hub bore make the SR model seem bigger. Even in 16 inches, the smallest available size, the wheel makes a significant impression."
09-17-2013, 11:04 PM | #7 |
Whoa... these look fantastic!
I hope the weights are good. |
09-17-2013, 11:27 PM | #8 |
Drives: Some kind of Subaru
Looking at some of the other BBS wheels on tirerack, I'm not sure these wheels will be that light
09-17-2013, 11:29 PM | #9 |
Because Racecar
Drives: 2013 Asphalt FRS
Those look sick! Hadn't seen this style yet! Post some pics if you end up getting them!
09-18-2013, 05:30 PM | #10 |
@G_Ride good point, the other wheels are 21-22lbs for 17x7.5. This will likely be in the same area, that's too bad. If only TSW made a rotory forged split 5 spoke.
09-18-2013, 11:25 PM | #11 | |
Time Traveller
Name|Method|Size|Lbs BBS RV Cast 17x7.5 18.4 lbs **lightest 17 BBS CH Cast 17x7.5 20.2 lbs BBS RK II Cast 17x7.5 20.7 lbs BBS RX Cast 17x7.5 20.9 lbs BBS RX II Cast 17x7.5 21.2 lbs BBS VZ Cast 17x7.5 22 lbs BBS CV Cast 17x7.5 22.5 lbs BBS RW II Cast 17x7.5 22.6 lbs **heaviest 17 BBS RC Cast 18x8 19.5 lbs **lightest 18 BBS CK Cast 18x8 23.5 lbs BBS RX Cast 18x8 23.5 lbs BBS CH Cast 18x8 24 lbs BBS SX Cast 18x8 25 lbs **heaviest 18 BBS VZ Cast 18x8 25 lbs **heaviest 18 Code:
From @DarrenDriven 's wheel weights thread Average Wheel Weights by @coyote I've listed what I'd consider to be average weights. Anything under or over these ranges would be light and heavy, respectively. 16x7 14-18lb 16x8 15-19lb 17x7 16-20lb 17x8 17-21lb 17x9 18-22lb 18x7 18-22lb 18x8 19-23lb 18x9 20-24lb 19x & 20x... Who cares, they are all heavy. |
09-20-2013, 02:22 PM | #12 | |
Proud of BOXER
Straight from BBS-USA:
The 17x7.5, 5x100, et48 (SR025SG) weighs 21.8 lbs. The 18x8, 5x100, et48 (SR024SG) weighs 24.6 lbs
The Following User Says Thank You to Clipdat For This Useful Post: | DAEMANO (09-23-2013) |
09-20-2013, 03:07 PM | #14 | |
Proud of BOXER
Similar Threads | ||||
Wheel Directory: BBS RK 17x7.0 +48 | Laika | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 64 | 05-21-2017 06:31 PM |
18x8.5 with 235x35 on all 4 corners OR 18x8 front + 18x9.5 back 235/35 + 255/35 back | KSpider | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-14-2013 07:06 PM |
18x7.5 +48/18x8 +43 staggered or 18x8 +43 square? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2013 02:56 PM |
Wheel Directory: TSW Nurburgring 18x8.0 +45 / 18x8.0 +35 | mike_ekim1024 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 04-10-2013 06:35 PM |
Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 | xravexboix | Wheels and Tires | 0 | 05-24-2012 08:04 PM |
