DIY (Do-It-Yourself) Guides For all DIYs. |
04-16-2013, 03:26 PM | #15 | |
Drives: 2014 Widebody Cosworth FR-S
Hope this helps Thanks, Rick |
The Following 2 Users Say Thank You to RallySport Direct For This Useful Post: | MemphisR (05-02-2017), norsamerican (04-16-2013) |
04-16-2013, 05:11 PM | #16 | |||
Thanks for all the input guys! Rick |
04-18-2013, 07:42 PM | #17 |
Figured I would drop by and leave this here
[ame="https://www.youtube.com/watch?v=0bdeV3fZ-U8"]https://www.youtube.com/watch?v=0bdeV3fZ-U8[/ame] Thanks, Rick |
07-06-2013, 01:31 PM | #18 |
Drives: White 2013 BRZ Limited 6MT
So I'm still trying to figure out how to post pix, but I snagged a set of these, and actually cut my fenders as well to make a functional vent. I've noticed a decent drop in over all temp on track days.
07-06-2013, 04:03 PM | #19 |
Drives: subaru legacy
Great install thread.
I like how how it's pre-painted, and subtle change (big on stockish look things). Surprised for that price they couldn't have duplicated the factory mounting points, or have the double sided tape installed, or how you have to stick on the emblem yourself. |
07-06-2013, 05:52 PM | #20 | ||
You can upload them to a free hosting site like Photobucket, smugmug etc.. and then copy the .jpg link over here between 2 IMG tags so it will look like this: [IMG] PictureURL.JPG [/IMG] I would love to see pictures of the mods you did to make them functional, that is super cool! Quote:
Yeah they look amazing, and fit very well. I also wished they had replicated the OEM mounting, and they did to a degree, just with studs and nuts and not plastic clips. Also the OEM uses some double sided tape, but not as much as these Prova's, still very impressed with fit and finish Thanks, Rick |
07-07-2013, 02:08 PM | #21 |
Since I only needed the two original holes for the posts on the Prova vents, I used a thin blue painters tape, and just kept going trial-and-error of placing the tape right where I needed it by placing the vents in place, and looking through the mesh. I also used the old holes as guides to create a nice line for my tape. Then I used cutting discs and a Dremmel. I realize there are better tools that could be used, but it's what I've got, and it worked. Last edited by omegared19; 07-07-2013 at 02:21 PM. |
The Following 2 Users Say Thank You to omegared19 For This Useful Post: | chaoskaze (03-02-2015), mike_ekim1024 (12-10-2013) |
07-08-2013, 09:49 PM | #22 | |
Thanks, Rick |
07-10-2013, 03:10 AM | #23 |
On track/auto-x days, I noticed about a 10 degree engine temp drop. I kept testing it, and it varies based on ambient temp, but cold foggy days, about a 8 degree drop. Hot, track days about a 11-13 degree drop
The Following User Says Thank You to omegared19 For This Useful Post: | chaoskaze (03-02-2015) |
07-12-2013, 08:50 PM | #24 | |
Thanks, Rick |
08-01-2013, 01:44 PM | #25 |
Drives: Scion FR-S
I too modified the fender to make this functional. Overall impression is that the quality of the piece is good. Fitment is good, but could be just slightly better (tends to stick out a bit near the door). It's quite a bit 'whiter' than the rest of the car and has quite a bit less yellow in the paint, so the match isn't perfect. Overall I'm fairly happy. Painted the mesh black as well.
08-01-2013, 04:18 PM | #26 | |
Thanks for your post Rick |
08-08-2013, 05:38 PM | #27 | |
08-08-2013, 07:35 PM | #28 |
Drives: Scion FR-S
Silver wasn't for me. It's simple mesh that is held in with one screw, so you're probably better off buying similar mesh that is already anodized.
The Following User Says Thank You to Gen For This Useful Post: | omegared19 (08-09-2013) |
Similar Threads | ||||
question about brz/fr-s front fender vents | nmullin11 | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 03-20-2013 05:01 AM |
FS: OEM FR-S "86" fender emblems | Trojan_SC | Exterior Parts (Aero, Lighting, Etc.) | 2 | 02-25-2013 08:13 PM |
FS: Toyota 86 Front And Rear Emblems | hayleybeaners | Exterior Parts (Aero, Lighting, Etc.) | 2 | 01-30-2013 08:21 AM |
Functional front fender vents | JohnATL | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 01-25-2013 11:58 AM |
WTB: Stock Scion front & rear emblems | JoeBoxer | Exterior Parts (Aero, Lighting, Etc.) | 9 | 10-01-2012 10:52 PM |
