Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-28-2020, 09:05 AM | #29 |
Drives: '23 BRZ
Yeah, weird wear pattern but I think you're assessment is correct, lotsa deformation due to flimsy sidewall and smallish treadblocks.
Yeah, car is a lotta fun! You'll really love it at the track on better tires |
The Following User Says Thank You to ZDan For This Useful Post: | gcmak (08-28-2020) |
08-28-2020, 09:24 AM | #31 |
That's just how the edge of the tread looks on the oe tire when it wears, the rubber compounds are different at the edges hence different wear rates.
The Following 2 Users Say Thank You to strat61caster For This Useful Post: | gcmak (08-28-2020), treedodger (08-29-2020) |
08-28-2020, 04:40 PM | #32 |
Drives: GR86
I was thinking I'd try the RT660 tires and keep everything else the same for the time being. I think it should hold up much better overall but not be overly aggressive so I can still learn.
08-28-2020, 04:49 PM | #33 |
Drives: '23 BRZ
FWIW I kinda disagree with the notion that decent tires for the track inhibit learning. With track-appropriate tires you'll have a better time and learn more, quicker, IMO!
08-28-2020, 07:07 PM | #34 |
Drives: GR86
Fair and heard. It's a different kind of learning is what I was getting at, never the less, new tires are in the cards.
08-29-2020, 03:49 PM | #35 |
Drives: 2022 GR86 (was 2013 BRZ)
Depends on your goals and budget.
I generally recommend novices spend more time/$$$ on car control/skid pad/coaching/seat time and less on expensive rubber. Unfortunately, most new track drivers focus more on their lap times than on their car control skills. Learning slide recovery is a critical skill most don’t worry about until after their first scary 4 off.
The Following User Says Thank You to treedodger For This Useful Post: | gcmak (08-30-2020) |
08-29-2020, 03:55 PM | #36 |
GT Radial SX2 are hard to beat for an inexpensive and fun tire (TW260). Stock class record in 86Drive Challenge with this tire is 1:50.xx at Laguna Seca.
The Following 2 Users Say Thank You to treedodger For This Useful Post: | BlueWhelan (08-30-2020), gcmak (08-30-2020) |
08-29-2020, 04:22 PM | #37 |
Drives: 2019 BRZ w/ PP
What alignment settings did you even up going with for the re-alignment?
08-30-2020, 12:57 PM | #38 | |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | treedodger (09-04-2020) |
08-30-2020, 01:02 PM | #39 | |
Drives: GR86
The assumption (and that's all this is) from others here including myself is that the shop may not have touched the toe much/if at all so changing the camber back to negative shouldn't have too large of an impact. I'll get an alignment when I replace these tires / before next track day. The car drives perfectly straight on the roads and aside from abuse on-track there are no visible signs of odd wear from excessive toe in/out. This is NOT my daily driver. I'm very lucky and thankful to be able to have this as a second car to use as a weekend/fun/HPDE vehicle. |
The Following User Says Thank You to gcmak For This Useful Post: | Racecomp Engineering (08-31-2020) |
09-04-2020, 03:11 AM | #40 | |
IMHO, I would suggest that the quickest way to make a novice safe on track is for them to spend enough time on the skidpad so they can catch a slide without having to think about it...and it's a lot of fun! BTW: Ian's blog touches on this. Always entertaining: https://yousuckatracing.wordpress.co...aining-wheels/
09-04-2020, 09:01 AM | #41 |
Drives: Miata
09-04-2020, 09:44 AM | #42 |
Drives: '23 BRZ
How old do you reckon that is? For sure that plot is going to be different for every tire, and IMO it's not necessarily giving an accurate picture of grip vs. slip angle for current race tires vs. extreme perf street tires vs. "normal" street tires.
Most modern "Extreme Performance" tires have *amazing* grip at very high slip angles. This has been the case since at least the Dunlop Z1 *spec (I remember being dumbfounded at the sliding grip those tires had in the wet as I tried to do donuts in a parking lot). Meanwhile the OEM Primacies are kinda known to not have this property. I had a student a couple of years ago who was afraid to even run "sport/track mode" at the track, let alone the 5-second hold on the traction control button, based on how many times he'd looped his car at a skidpad test day with the Primacies. But he soon found the proper Extreme Perf tires he'd gotten for the car to be *way* more confidence-inspiring and was able to drive hard enough (in sport/track mode) that I signed him off for his license after he showed great car control throughout the day (along with excellent awareness of traffic and flags and consistently good clear-headed responses under changing conditions). Regarding noise, some tires make a lot of noise while still providing grip, some tires slide without making much noise at all, I haven't found an absolute correlation between noise and sliding grip. |
The Following User Says Thank You to ZDan For This Useful Post: | Breezio (09-06-2020) |
Tags |
alignment, stock, suspension |
Similar Threads | ||||
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
Vehicle Stability Control | twostroke | BRZ First-Gen (2012+) -- General Topics | 15 | 07-13-2014 11:10 AM |
Contact patch area calculator (and much more) | dsgerbc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-09-2013 01:22 AM |
Traction Control / Vehicle Stability VSC kicking in when not necessary? | WTF | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-15-2012 04:24 PM |
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) -- General Topics | 40 | 04-25-2012 11:20 AM |
