Forced Induction Turbo, Supercharger, Methanol, Nitrous |
#29 | |
Drives: brz
If the pumps have check valves the check valve will close when one pump looses pressure(sucks air) so you should still have pressure in the fuel system. This is with teeing the pressure side. You would also need to arrange the jet pump system to work in this configuration to your advantage. As far as burning a pump up running it dry it shouldn't hurt the pump considering it would no longer be under load and drawing very low current. Staged systems have to have check valves on the secondary pump(s) if in parallel. |
#30 | |
Drives: Crapcan
#31 | |
@slothbrz on IG
Drives: Track BRZ - Supercharged
What is your opinion on a 2nd pump being always on, and always feeding fuel into the driver side basket? Basically wiring it up along with the driver side original pump I had planned to use a switch to control it but would simplify my life to have it just be always on, if there were no drawbacks |
#32 | |
Drives: brz
3d print some flapper doors or buy. Best would be build a surge tank that replaced the basket then a factory basket feeding the the surge tank. |
FS: OEM Fuel tank with pumps | MicheleAbbate | Exterior Parts (Aero, Lighting, Etc.) | 3 | 06-02-2016 03:08 PM |
Aeromotive 325 fuel pumps | 1stGenBRZ86 | Forced Induction | 12 | 05-05-2014 06:22 PM |
Please read if swapping fuel pumps | Dipstik-sportech | Forced Induction | 5 | 06-17-2013 02:39 PM |
*** Introducing the SBD290 DROP-IN Fuel Pumps for the BRZ/FRS/GT86 *** | Visconti | Engine, Exhaust, Bolt-Ons | 21 | 03-08-2013 01:50 AM |
SEMA 2012 Coverage - Deatschwerks Fuel Pumps and Injectors *Video Interview* | Circuit Motorsports | Engine, Exhaust, Transmission | 0 | 11-13-2012 07:40 PM |
