#3837 |
Drives: 2016 Scion FRS
There are some things that aren't obvious (like bushing content or maybe a feature to a specific part), but the general rule of thumb is that if it doesn't say that you can, then you can't.
#3838 | |
Drives: 2015 Series Blue BRZ WRB
![]() I'd love to run the TRD spoiler (on my BRZ) , but searched and looks like you can't (which is sad and kind of ridiculous lol) Are there any other spoiler options other than just the OEM BRZ one that are STX legal? |
#3839 | ||
#3840 |
& there’s no others, correct? (Other than typical brz spoiler)
#3841 |
Drives: 2017 BRZ
Probably not. TRD one isn't even on an 86...
#3842 |
Drives: 2017 BRZ PP , 2005 Saab 97X
I have the pedestal wing from the later gen BRZ's and its supposed to do something, though what who knows.
whats more interesting is that the lips and stuff from subarus "sti" brand arent really "sti parts" more or less. you can still find it in the standard factory parts inventory, with standard naming convention. even TRD is sort of a show and shine parts list now and true "trd" bits are ultra rare Gazoo Racing stuff. my league down here looked the otherway with the full lip side skirts and rear spat kit on the brz cause it was so common on brz's down here. and because of that a friends 86 is sorta hazed over for his greddy lip. but this again goes back to who wants to contest what. id still argue the sti lip, skirt, and rear spats are standard parts and factory options, and not true " performance part after math bolt ons" |
#3843 |
Drives: 2017 BRZ
They are standard not dealer installed, on the series blue and more. Definitely standard parts.
The Following User Says Thank You to cjd For This Useful Post: | Clutch Dog (02-26-2020) |
#3844 |
As someone who runs national events, my honest personal opinion on things like a TRD spoiler on a BRZ....
I don't care. I probably wouldn't notice. With that said, if you were to bump me down a contingency spot or a points spot at a pro or trophy at nats and I did notice, I can't imagine a scenario where I'd protest or even say anything to you. However... I might look at your car with more scrutiny than someone without it. Again, that's just one opinion. |
The Following 3 Users Say Thank You to steverife For This Useful Post: |
#3845 | |
#3846 | |
Custom User Title
Example: I had an RS 1.0 and if I wanted to run DS when everyone moved from CS to DS I would have had to change the dual climate control and every body piece that was TRD RS 1.0 specific along with the springs just to be class legal.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#3847 |
Drives: 2017 BRZ w/PP
what are my options for front camber if im already maxing my camber plate and bolts out? I got my alignment a few weeks ago and my passenger side can go over 1/2 a degree more than my drivers side. Obviously i bent something but nothing looks bent. im currently at -3.15 since thats as far as the drivers side goes but was looking to go -3.5.
I'm guessing either figure out what i bent and replace it or put another crash bolt in the top too? |
#3848 |
Either the lca is bent or your camber plates are uneven. Lca should bend before the subframe, knuckle or strut, tie rod should be adjustable even if it's tweaked and any issues there would show in toe. What coilovers do you have?
Two camber adjustment mechanisms on the bolts is typical, either a pair of camber bolts in factory sized holes or the upper strut hole is slotted and you stick a camber bolt in the lower hole. Sounds like you have the former, either the small 14mm factory bolt a la crash bolt or grab the 16mm spc camber bolt. Edit I suppose if it was crashed and the subframe was tweaked and just the lca replaced that could be it. Also I'm remembering that you can shift the subframe for a few tenths of a degree shift side to side but most alignment shops are too lazy to do that. |
#3849 | |
looks like something was weird and my old reply was blank. but i have csg flex As and i have the spc crash bolt in the bottom hole on max like the instructions say. last year i was at -2.6 front with my plates being 2 ticks from max. so im guessing i bent my lca |
#3850 |
Drives: 2017 BRZ
K-member often also bends if the arm bends... Though not always.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
