01-31-2014, 07:00 PM | #127 |
Drives: 2013 BRZ Limited
On my drive home I paid extra close attention to what I was doing:
Tiny blip of the throttle just as I start to lift off the clutch, RPMs up to 1.8-2k As I continue releasing the clutch RPMs are falling from the blip and from the clutch engaging, slowly roll back on the throttle, RPMs dip as low as 1-1.2k. By the time RPMs rise back to 1.5k I'm fully off the clutch. This process takes less than 1.5 seconds. Also, as some reassurance, my first manual was a 98 VW Cabrio with 65k miles. I was completely self-taught, so I applied the clutch liberally. I had no idea about rev. matching so would use the clutch to bring the engine up to speed when downshifting. I'd also start in 2nd or 3rd on accident from time to time and just let the clutch slip until I was up to speed. Then the car was handed down to my little brother who learned to drive stick on it. It just needs a new clutch now at 140k miles. |
02-01-2014, 10:42 AM | #128 |
Trust me, I'm the Doctor
I did that with my 08 WRX & it needed a new clutch kit (disc was almost gone & throw out bearing disintegrated) at 53k miles.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
02-01-2014, 11:10 AM | #129 | |
Drives: Subaru BRZ Sport Tech Satin White
One impressive feature of this high winding boxer engine is just how smoothly it delivers torque at very low rpm. Granted it doesn't produce much but if produces enough. You can quite easily get this car moving by engaging the clutch slowly and smoothly at idle speeds. The car is also quite happy cruising along at under 2,000 rpm around town. Then you can just let 'er rip to 7,400 and no complaints from the valve train, the engine just lunges forward and pulls like a train, a very small train but impressive in its own way. Beautiful engine. |
The Following User Says Thank You to Suberman For This Useful Post: | SirBrass (02-01-2014) |
02-01-2014, 11:49 AM | #130 |
Just DO
NOT RIDE THE CLUTCH PEDAL! This may seem obvious, OP, and I hope it is to you, b/c that'll mean you've been taught correctly. Don't even lightly rest your foot on the clutch pedal b/c you'll wear your clutch prematurely. It's a wear part, but not like brake pads are. When cruising, plant that left foot on the dead pedal (the plate to the left of the clutch pedal) and leave it there. If you already do this, great! If not, start. It'll save you money & clutch performance. Sent from my SCH-I535 using Tapatalk
02-01-2014, 12:25 PM | #131 |
Drives: 2013 BRZ Limited AT
Has anyone been clutchless shifting their BRZ?
If you're interested in trying. Get rolling about 50mph in 5th, let off the throttle and immediately click into neutral with light pressure on 6th (still off the throttle). It'll click into 6th without grinding once you hit the proper RPM. Once it does, go back on the throttle. It's not something for racing, but it works great for light cruising trying to maximize fuel economy and clutch life. Clutchless downshifting works the same way, except you have to give the throttle a blip to get up to the right rpm. Note - DO NOT FORCE THE SHIFTER INTO GEAR. You'll grind. Just give the shifter a nice light pressure on the next gear and it'll click once you hit the right rpm. Let the synchros do the work for you. Also, if you aren't really smooth this CAN cause increased transmission wear over time or damage to gears if you're grinding away like a jackass. Transmissions generally run 3-5k to replace/repair. Clutches are a lot less expensive, but still pricey. Hoon at your own peril. |
02-01-2014, 01:19 PM | #132 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
02-01-2014, 01:50 PM | #133 |
And why overly wear the synchros to save a wear part? The clutch is supposed to be a wearing part in order to extend the life of the synchros & to make shifting smoother and easier.
02-02-2014, 07:53 PM | #134 |
Drives: Toyota Highlander; Subaru BRZ (SWP)
I thought that it would be easier for beginners to know exactly how a manual transmission works. Found a neat video showing an animation of exactly that. Hope it helps.
[ame="http://www.youtube.com/watch?v=8KDuk2-4s6E"]Manual Transmission Animation - YouTube[/ame] |
The Following 2 Users Say Thank You to carma143 For This Useful Post: | starbot (02-07-2014), TheMuffinMan (02-22-2014) |
02-02-2014, 07:54 PM | #135 |
Poor College Kid
Drives: ~.~
Someone teach me how to drive manual well..
02-02-2014, 07:59 PM | #136 |
02-02-2014, 08:03 PM | #137 |
Poor College Kid
Drives: ~.~
Don't get my hopes up like that
02-06-2014, 11:41 PM | #138 |
Are you 20/20?
Drives: Hopes and dreams
Nice initiative, OP (I know I'm late)
That subaruwrxfan is an idiot though lol
The Following User Says Thank You to AznKirby For This Useful Post: | krayzie (03-13-2014) |
02-07-2014, 09:22 PM | #139 | |
Drives: 2014 BRZ, 2008 Impreza
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
02-18-2014, 07:33 PM | #140 |
Drives: 2013 SWP BRZ Premium
Not driving manual for 2 weeks because of the snow has completely ruined me. I was stalling every other stop sign tonight in my neighborhood.
Similar Threads | ||||
Best place to learn how to drive my car | Pneub | Southern California | 1 | 06-07-2013 03:54 PM |
what did you learn to drive on? | 7thgear | Off-Topic Lounge [WARNING: NO POLITICS] | 31 | 08-10-2012 10:39 PM |
Where to learn how to drive manual.... | Saibot | CANADA | 12 | 03-13-2012 06:28 PM |
Who needs to learn how to drive... | RRnold | Other Vehicles & General Automotive Discussions | 14 | 08-27-2011 12:15 AM |
Learn to Drive | MtnDrvr86 | Other Vehicles & General Automotive Discussions | 102 | 03-14-2010 08:46 AM |
