04-10-2024, 03:57 PM | #57 |
Drives: Toyota GT86
Yeah those csg pads are no joke price wise lol.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
04-10-2024, 04:52 PM | #58 | |
There's a lot more to pads than just shopping on specs alone. If you'd like a personalized recommendation specific to your needs, post up exactly what is done to your car, what you are looking to do with your car, and what you are looking for in terms of braking feel, as well as your past experience with other pads (and platforms). |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | NoHaveMSG (04-13-2024), ruturaj001 (04-10-2024) |
04-10-2024, 05:19 PM | #59 | |
Drives: BRZ 2023
Car has -2.5 degree camber in front, might go for -3 degree. currently running stock tires, planning to get SX2 either 215 or 225 as per recommendations here. Plan is to track it 4-10 times a year, 2nd year in to tracking, I am focused on learning to feel the car, so whatever gets me more feedback. Only Ferodo DS2500 till now after few months on stock pads. |
04-10-2024, 05:28 PM | #60 | |
04-10-2024, 06:01 PM | #61 | |
Drives: BRZ 2023
My plan is if CSG CP fade on me after getting it, then I would just get tS with brembos and get CP again (I assume brembos would be improvement over regular). If those fade them going for track pads. |
04-10-2024, 06:42 PM | #62 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | ruturaj001 (04-11-2024) |
04-11-2024, 12:48 AM | #63 | |
Drives: Crapcan
A lot of guys that run with Audi are instructed to drive really odd lines at the Ridge. Pacific is plenty safe and Proformance does a good job with their class. The turn onto the front straight is bumpy but it is more of a problem with higher HP cars and novice drivers. It’s really not much worse then coming onto the straight in the finial section at the Ridge. That back section is fine as long as you are not yeeting the curbs, they are big and unsettle the car quite a bit. It looks intimidating but it is not bad as long as you are within your limits and not pushing it. I’ve talked to far more people who have crashed a car at the Ridge than Pacific. The Ridge has a lot of medium to high speed turns and getting off into the grass it is hard to slow the car down and get it under control again before hitting a tire wall, or a ditch, or a flag station. ORP is far sketchier.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | CSG Mike (04-12-2024), ruturaj001 (04-11-2024) |
04-11-2024, 06:32 AM | #64 | |
Drives: Toyota GT86
CSG pads are definitely up there price wise but you get what you pay for it seems
The Following User Says Thank You to autoracer86 For This Useful Post: | CSG Mike (04-12-2024) |
04-11-2024, 10:25 AM | #65 | |
Drives: 2017 BRZ PP, 2004 WRX
CRC's brake disc quiet was what was recommended by our autocross guys locally. I used the spray version and it quieted them down from April until October. Had to reapply heavily again this year in April after storing the car. I've heard this is the case with any even semi-track oriented pad and the Brembos. OEM pads didn't make any noise at all.
The Following 2 Users Say Thank You to cmiovino For This Useful Post: | CSG Mike (04-12-2024), ruturaj001 (04-11-2024) |
04-11-2024, 01:43 PM | #66 | |
Drives: BRZ 2023
04-11-2024, 01:51 PM | #67 | |
Drives: BRZ 2023
Thanks, I would go to Pacific as well then this summer. I meant Portland raceway, ORP is too far for me but thinking now Portland might be too far of a drive this year. May be when my son gets older I would be able to stay overnight at places. |
The Following User Says Thank You to ruturaj001 For This Useful Post: | NoHaveMSG (04-13-2024) |
04-11-2024, 04:10 PM | #68 |
Yeah, you can easily pull them out. Two pins and a little clip and the pads slide out. You can pull them out, regrease/spray, and pop them back in rather quickly. I just did it when swapping to summer/autocross wheels recently.
04-11-2024, 06:33 PM | #69 | |
Drives: Crapcan
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | ruturaj001 (04-11-2024), Ultramaroon (04-12-2024) |
04-12-2024, 12:53 PM | #70 |
chicken tonight
This summer! I have no excuses left.
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (04-12-2024) |
Similar Threads | ||||
Wheels setup advice to learn drifting | ShadowTS | Tracking / Autocross / HPDE / Drifting | 2 | 03-22-2016 03:26 PM |
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
How does the ECU learn? | boredom.is.me | Software Tuning | 19 | 10-10-2013 08:29 PM |
