02-08-2024, 10:28 AM | #253 |
Drives: Subaru BRZ
The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | RedReplicant (02-08-2024), Ultramaroon (02-08-2024) |
02-08-2024, 12:32 PM | #254 |
Drives: Toyota GT86
I haven't seen much negative information out there for the RLCAs. Unlike the Front LCAs
I am running newish rear arms from SPL so what do I need to look out for ? Thanks.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
02-08-2024, 01:32 PM | #255 | |
Drives: None
The Following User Says Thank You to RedReplicant For This Useful Post: | autoracer86 (02-08-2024) |
02-08-2024, 01:43 PM | #256 |
Drives: Toyota GT86
Well damn. I guess I should call SPL. Thanks for posting the picture
02-08-2024, 08:48 PM | #257 | |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
I also don't use all the adjustment it offers, last year I moved the coilovers to the "stock" mount location and I've always kept the swaybar link at OEM position. Also what the rest of the gang said, not that mine suffer (early-mid 2020 batch) it is something to look for on yours (you'll have to copy paste because a filter blocks it)... https:// www (dot) gr*86*(dot) org/threads/potential-safety-issues-from-lightweight-version-spl-rear-lower-control-arm-examine-your-spl-rlca-immediately.10572/ Last edited by villainous_frx; 02-09-2024 at 01:54 AM. |
The Following 2 Users Say Thank You to villainous_frx For This Useful Post: | autoracer86 (02-09-2024), Ultramaroon (02-09-2024) |
02-09-2024, 06:01 AM | #258 |
Drives: Toyota GT86
Got it that is definitely a pain in the ass to deal with. I only had one shop work on my car and I bought them the instructions and an Allen key lol. I also wrote down the tq specs for everything. I have trust issues lol.
Looks like I need to continue to do this ha… also SPL got back to me within minutes and my arms look good. Sorry for the slight thread jack
03-10-2024, 10:25 PM | #259 |
Off to the track!
Pulled the car inside to thaw out and got started on doing a full inspection, also pulled out the front suspension. The good news is that, at one point, fluids were in the right parts inside the engine. The bad news is that they have made their way to the exterior of the engine and oil is leaking from all 4 cam sensors, the timing cover, and the driver side valve cover. To the surprise of no one, the coolant leak has not magically fixed itself through neglect and will be addressed. Other fun surprises, passenger fender liner is dead and missing all clips (autox?), and rubbing on the inner wheel well on both sides.
Time to load up the parts cannon for, hopefully, one last time this winter. On order: -CSF rad -Radiator foam sealing pieces -Passenger fender liner -Bracket for side markers -Lots of RTV Edit: Just ordered all the OEM parts listed above, also have rear endlinks coming with the CSF rad from Subieland. Last edited by villainous_frx; 03-10-2024 at 11:44 PM. |
The Following 2 Users Say Thank You to villainous_frx For This Useful Post: | KMA KiCKz (03-13-2024), Ultramaroon (03-11-2024) |
03-16-2024, 11:07 PM | #260 |
Off to the track!
Status update:
Front crank seal is leaking. New one will be ordered next time I decide to spend money at the dealer :/ Shaftworks on, RLCA on, new acc belt + tensioner, scrubbed engine clean-er, TRD JP short shifter installed, cleaned up gauge panel wiring, fixed gauges reading wonky (pro tip- plug them in properly). Waiting on- rear endlinks, rad foams, misc OEM bits. An alignment (once endlinks arrive). |
03-31-2024, 12:11 AM | #261 |
Off to the track!
Crossed 4 years of ownership this past week. Nothing new to report, the extra pieces I was waiting on are trickling in. Track days are on the calendar and alignment is scheduled. Time to get to work.
The Following 7 Users Say Thank You to villainous_frx For This Useful Post: | autoracer86 (03-31-2024), Code Monkey (03-31-2024), jflogerzi (04-05-2024), Jrdad (03-31-2024), KMA KiCKz (03-31-2024), NoHaveMSG (03-31-2024), Ultramaroon (04-02-2024) |
04-13-2024, 10:38 PM | #262 |
Off to the track!
Updates for April-
Radiator installed & cooling system bled Fixed shifter (it had a comical amount of play in 1/2) Cleaned interior Removed FF kit Rear endlinks installed Fender liner swapped And most importantly an alignment. -4* front -2* rear, zero toe all around. Washed the car today and (re)discovered that the hood bra PPF has finally met its maker after 10 years and needs to be removed. Still to fix is the random clunking from passenger rear coilover, and the lower cam sensor seal. |
The Following 4 Users Say Thank You to villainous_frx For This Useful Post: |
05-09-2024, 11:00 PM | #263 |
Off to the track!
New for 2024...
Car is wrapped (finally lol). Went up to Strato and ran 7 sessions. No grip after a long cold winter, but fun was had. Ran mid 1:11s all day. Car needs front aero, and it is looking like the passenger rear strut will need to be sent out for a rebuild. Edit: also updated parts list in first post. Last edited by villainous_frx; 05-10-2024 at 01:27 AM. |
The Following 9 Users Say Thank You to villainous_frx For This Useful Post: | autoracer86 (05-10-2024), Code Monkey (Yesterday), KMA KiCKz (05-09-2024), Lonewolf (05-13-2024), new2subaru (05-10-2024), RedReplicant (05-10-2024), RToyo86 (05-21-2024), Ultramaroon (05-10-2024), ZC6_STi (05-10-2024) |
05-10-2024, 12:48 AM | #264 |
chicken tonight
Love that pattern. Tasteful and striking.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | villainous_frx (05-10-2024), Wally86 (05-22-2024) |
05-10-2024, 02:09 AM | #265 |
Drives: Toyota GT86
Ah the car looks great. Awesome job
The Following User Says Thank You to autoracer86 For This Useful Post: | villainous_frx (05-10-2024) |
05-21-2024, 02:31 AM | #266 |
Off to the track!
"If you die with the lowest mileage Poorsche, you lose."
Took the car up to Rad Torque (Castrol) for the afternoon. Lots of rain which kept everything cool, felt like playing a game with tire wear disabled. Cross off 275k km and celebrated with 50 minutes of hard driving on track. |
The Following 6 Users Say Thank You to villainous_frx For This Useful Post: | Code Monkey (Yesterday), grippgoat (05-22-2024), KMA KiCKz (05-22-2024), RToyo86 (05-21-2024), Ultramaroon (05-21-2024), Wally86 (05-22-2024) |
Similar Threads | ||||
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
[B is for Build] BRZ resurrection build | im_topher | Member's Car Journals | 49 | 03-05-2018 09:41 AM |
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions | Corradooo | Engine, Exhaust, Transmission | 2 | 11-25-2017 07:16 PM |
Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
No build date on passenger side sticker, how to determine build date? | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-20-2015 10:14 PM |
