Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-17-2020, 10:27 PM | #1 |
Drives: 2019 Toyota 86
How would I get more than -2 deg camber with SPC RLCAs?
So the SPC RLCAs can net me -2 deg camber at most. Is it possible to get more than -2 deg camber to get something like -2.2 deg camber?
04-17-2020, 10:54 PM | #2 |
Drives: '13 FRS - STX
Go to a better alignment shop, sounds like they're being lazy or your car is broken. You shouldn't have any problems going up to as much as -3 degrees.
Unless you mean the part description which states +/-2.0°, that typically means you have 4° of adjustment range from where your car sits on the OEM parts, the factory car is usually around -1.5°-ish so you could have as much as -3.5° or as little as +0.5° |
The Following User Says Thank You to strat61caster For This Useful Post: | CSG Mike (04-19-2020) |
04-18-2020, 04:30 AM | #3 |
Drives: 2014 GT86
My guess is that you need to install differently included in SPC rear LCAs set eccentric bushings, so that you can get wished camber while still able to dial toe right too. Other similar stamped steel LCAs of such design IIRC don't have that bushing in set. With OEM bushing and at stock height with wished slight toe-in rear my rear camber is -2.4dg.
04-20-2020, 03:58 PM | #4 |
Drives: 2013 FR-S Series 10
Are you lowered at all? My rear is at -2.5 with those LCAs, lowered 1 inch.. with even more range if i wanted it.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
Similar Threads | ||||
SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 01:43 PM |
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
