05-06-2019, 09:56 AM | #197 | |
Good Job Subaru!
Drives: '17 BRZ, '24 CX-50
What makes this cheap mic bearable even when outside on the rear bumper is that I can adjust the microphone sensitivity on the input of my DSLR as to not sail it into clipping under WOT. In that video it was just starting to clip at the top RPM range, so next time I record I can knock down the sensitivity by one more notch and I'll be good to go. Glad to hear your tune is consistently improving! I look forward to seeing the numbers.
The Following User Says Thank You to JBezugs For This Useful Post: | TMF (05-06-2019) |
05-06-2019, 10:39 AM | #198 |
Drives: 2013 Raven FR-S
Anybody know when JDL might have these on sale again? I really want to swap out my JDL UEL for the 4-2-1 but I'm also a cheapskate
05-06-2019, 02:01 PM | #199 |
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Black Friday is normally their best sale of the year. I’ve seen Jesse post some pretty good deals in the Facebook sale groups as well.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8 |
The Following User Says Thank You to the new guy For This Useful Post: | smg1138 (05-06-2019) |
05-07-2019, 01:42 PM | #200 |
If I end up switching to the JDL 4-2-1, would it be worth upgrading my overpipe too? Wasn't sure how much gains could be had by changing it, but it seems like removing the stock piece is a PITA.
Current exhaust setup: JDL UEL catless header > stock overpipe > stock frontpipe > Perrin resonated catback |
The Following User Says Thank You to smg1138 For This Useful Post: | mgarcia707 (05-08-2019) |
05-07-2019, 01:44 PM | #201 |
No not imo.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
05-07-2019, 01:50 PM | #202 | |
Removing the overpipe is much easier if the header is out already.
05-08-2019, 12:46 AM | #203 | |
Drives: '14 FRS TT5
1. Which front pipe would you recommend for the most power in an NA application? 2.5" or 3" test pipe? There's really no difference in power between the "Test" pipe and any resonated version. However the resonator(s) will add some weight. I personally haven't seen much of a difference in power levels between the 2.5" and 3" on na testing. The 3" makes slightly more top end while the 2.5" is stronger in the mid range. Nothing major though. 2. Any idea roughly what the power gain difference is between the test pipe and catted front pipe? Or are there any gains with the catted front pipe? No cat is worth 3-4 horsepower from what I've seen. To be honest the cat that comes in our front pipe isn't recommended for track or autox use. I do have an option for a motorsports use cat that is rated for high heat and horsepower however it is quite a bit more expensive. If you can run without a cat it's what I would suggest. 3. Over pipe - any idea of power gains with this, or about the same as stock? Definite gains with a header, especially ones where the merge collector is located near the overpipe connection. The overpipe essentially becomes an extension of the merge collector at that point so making sure the diameters are match and flow is smooth is important .
Follow my NASA TT5 build here: JHill Motorsports
The Following 4 Users Say Thank You to TMF For This Useful Post: |
05-30-2019, 11:32 AM | #204 |
Has anyone come up with a specific OFT tune for this header? I'm guessing due to the 4-2-1 design the standard OFT Stage 2+ tune isn't going to be optimal.
05-30-2019, 11:47 AM | #205 | |
The Following User Says Thank You to jflogerzi For This Useful Post: | smg1138 (05-30-2019) |
05-30-2019, 12:02 PM | #206 |
Drives: 2014 GT86
I'd try OFT tune changes for longtube headers that was floating around for nameless/plm/ace alikes as starting point .. eg. search for nameless in OP of this thread.
The Following User Says Thank You to churchx For This Useful Post: | smg1138 (05-30-2019) |
05-30-2019, 12:09 PM | #207 | |
StreetKart
Drives: 2014 Scion FR-S Monogram
Sent from my Pixel 2 XL using Tapatalk
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
The Following User Says Thank You to Roadcone For This Useful Post: | smg1138 (05-30-2019) |
05-31-2019, 01:40 AM | #208 |
Señor Member
Mine should be arriving in a few weeks. Who has everyone used for their tune?
1974 TA22 Celica
2013 86 GT |
05-31-2019, 01:44 AM | #209 | |
StreetKart
05-31-2019, 05:31 AM | #210 | |
Because compromise ®
Drives: Red Herring
Sent from my PC.
Similar Threads | ||||
JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
