10-18-2018, 11:41 AM | #211 |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
that was my original plan too, and I ended up getting a second hood to cut into, but the Texas heat this summer made me change my plans and run the vents full time. Might switch to the uncut hood for winter and see if it makes a difference to help the car warm up faster.
10-18-2018, 11:43 AM | #212 |
ACT SB7-HDSS has been installed, along with the MTEC shift springs and Perrin shifter bushing. Clutch is heavier than I expected, but easy enough to get used to. My commute is 2 miles, so itll take some time to break in. I've just been driving around downtown Dallas to put some more milage on it. The new spring and bushing make shifting feel like bolt action, especially with the FT86 short shifter. I'm falling in love with this car all over again.
10-18-2018, 11:55 AM | #213 | |
Drives: 2017 BRZ (Sold), 2023 GR86
10-18-2018, 11:59 AM | #214 | |
Good Job Subaru!
Drives: '17 BRZ, '24 CX-50
I have the same short shifter with the MTEC springs, the MTEC spring made such a huge difference in the solid feel of the short shifter. Have Gear 300 in the transmission as well. Now you’re making me want to do the shifter bushing as well!
10-18-2018, 12:10 PM | #215 |
Putting the Perrin on while the transmission is still in the car is a PITA. I popped the springs and new bushing on right after we lowered the trans out of the car to do the clutch.
12-29-2018, 02:47 PM | #216 |
Small oil leak on the turbo oil return line, not sure how this happened, but I have now replaced every single fluid line that came with the JDL kit. I'm also getting a flex fuel kit, anyone have recommendations? I'm deciding between Moto-east and Delicious. I already have injectors and a fuel pump.
12-30-2018, 12:51 AM | #217 |
Just spent 20 mins looking threw thread. Alot of the win. Love the car and keep up the good work.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | mjanmohammad (12-30-2018) |
01-09-2019, 10:42 AM | #218 |
Not a ton of updates on the BRZ. I got the Delicious Tuning FF kit, new 550cc injectors, and a Walbro 485 fuel pump, but haven't had a chance to install it and have it retuned. I've been working on the Miata almost every day I've had free.
Miata has tons of new goodies though, Flyin Miata Vmaxx track coils, Advanti Storm S1 wheels with Yokohama AD08R tires, new control arms all around, and a torsen LSD. It sits low enough that I can go under the security gate at my neighborhood. TRack Day Feb8-9 at MSR Cresson.
01-30-2019, 11:51 AM | #219 |
It was looking like I was gonna sell the BRZ for a while to get the new Supra, but decided against it and am going all in on the BRZ. FF kit/injectors/tune are gonna be done next month and then enjoying boost until something pops
The Following User Says Thank You to mjanmohammad For This Useful Post: | Code Monkey (01-30-2019) |
02-08-2019, 12:06 PM | #220 |
Good move. IMO buying a first-gen car is rarely a good idea anyway.
02-08-2019, 12:09 PM | #221 |
I impulse purchased a 2JZ short block.
03-19-2019, 11:25 PM | #222 |
I’m getting a little crazy with the car now. Bumped it to 12 pounds of boost, flex fuel, new 550cc injectors and a Walbro 485 fuel pump. After a few hours of tuning and tweaking she was making 380hp on E70. It is terrifyingly fast now.
03-19-2019, 11:54 PM | #223 |
Now w/ over 400 womprats!
Drives: BRZ LZR
I got some ID1000s, let's get you to 500hp.
- The Ancient BRZ Sacrament by Zaku |
03-20-2019, 12:42 AM | #224 |
Drives: 2018 BRZ
Awesome build!
Similar Threads | ||||
2017 BRZ Performance Package Brembo Brakes Part Numbers | Veloist | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 146 | 04-27-2023 09:36 AM |
Specs for BRZ Performance Package wheels? | ~el~jefe~ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 04-17-2020 06:31 PM |
Performance package first drive review | Psilox | BRZ First-Gen (2012+) -- General Topics | 81 | 03-07-2017 10:12 PM |
Bristecom's 2017 Subaru BRZ Performance Package | Bristecom | Member's Car Journals | 16 | 01-26-2017 09:05 PM |
To get the Performance Package or Not? Thread | Zaku | BRZ First-Gen (2012+) -- General Topics | 141 | 12-06-2016 10:04 PM |
