04-30-2018, 11:50 PM | #1205 |
Drives: None
http://specfrs.com/Blog/aid/7
Alignment Specs Front Camber: -3 degrees Front Caster: 5.4 degrees Front Toe: 0 inches Rear Camber: –2.25 degrees Rear Toe: 1/8” toe in
'16 FR-S SpecFRS.com
04-30-2018, 11:52 PM | #1206 |
Drives: None
Similar, but different? Doesn't seem to pick up as much rubber, but also doesn't see the traffic that Lincoln does.
I consider it older concrete, it's an old airbase, but I really have no idea the history of Lincoln's surface. Similar to the way Forbes Field used to be. We don't plan on changing anything for Lincoln other than: 1) rotate tires front to back 2) replace OEM brake pads
The Following User Says Thank You to christoc For This Useful Post: | Open Loop (05-01-2018) |
05-10-2018, 11:04 AM | #1207 |
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
It looks like I may have to bow out of the Finger Lakes tour.
Work is not allowing me to drive my personal vehicle on a work trip. I have work the week before in Mechanicsburg PA and was going to drive up Friday afternoon from there. If I drive, I have to take a rental. If I fly, I won't have my car and won't be back until late Friday night (RI). :unamused: --kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
05-10-2018, 11:05 AM | #1208 |
Drives: None
Take a rental towing a trailer.....
05-10-2018, 12:32 PM | #1209 |
Bring out your dead
Can't. Mandatory use of a compact. Because contracts and stuff.
--kC
05-10-2018, 04:32 PM | #1210 |
Custom User Title
Rent the compact. Don't drive it.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
05-12-2018, 08:06 AM | #1211 |
2013 FR-S Whiteout / SSC
05-12-2018, 06:01 PM | #1212 |
Bring out your dead
Lol. That doesn't work either as it's not available from.pur corporate travel system.
05-12-2018, 06:40 PM | #1213 |
Drives: '13 FRS - STX
Why not bum a ride? Spec class so not being in your own car shouldn't be a big deal right? With the Falkens consumable cost should be less than a local event entry fee, last I did the math it was a bit less than $50 in consumables for STX with Bridgestones iirc, good learning opportunity for a data comparison in the exact same car for someone newer who dived in. Or maybe con someone local to you into driving your car out? IDK seems like the best solution is to hook up with another autoxer.
05-12-2018, 07:13 PM | #1214 |
Bring out your dead
Because I have to go.back to Rhode island Friday night after a day of work and then leave from there....
The Following User Says Thank You to Imp For This Useful Post: | strat61caster (05-13-2018) |
05-13-2018, 03:55 AM | #1215 |
Quit?
lol Are you really going to get punished for 'missing your flight'? tort laws man |
05-14-2018, 08:48 AM | #1216 |
Bring out your dead
It's not a matter of tort laws. It's contracting to a certain "non-corporate" entity. While I've been here for 19 years as a contractor, I'm also a little on the older side to just "up and move" into something new, so I get a little more protective of things, like my a) job and b) reputation (with my customer).
--kC
05-14-2018, 07:23 PM | #1217 |
Drives: FRS
Question, I have installed the camber bolts, and put the oem crash bolts from the bottom into the top, yet my alignment guy cannot get camber past ~2.25. Any ideas why? It's a place that does performance alignments all the time but they just can't get it to 3 degrees.
05-14-2018, 09:13 PM | #1218 | |
Drives: 2014 Monogram FR-S
What’s the offset of your wheels? Sent from my iPhone using Tapatalk |
Similar Threads | ||||
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 09:23 PM |
JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 11:20 AM |
