Forced Induction Turbo, Supercharger, Methanol, Nitrous |
12-02-2015, 07:11 PM | #113 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
On that note, I have a nice set of springs I can't use now.. |
12-04-2015, 07:09 AM | #114 |
Drives: Supercharged GT86
Any link to where you bought these bud? I'd be interested to see more detail on what exactly they've upgraded Cheers |
12-04-2015, 11:40 AM | #115 | |
Senior Misanthrope
12-04-2015, 08:15 PM | #116 | |
Corner Junkie
- FBM Competition port and Polish intake and exhaust ports - Competition Valve Job - Resurfaced and Clean and assembly - Ferrea Comp Plus Valves - Ferrea Dual Valve Springs - Ferrea Titanium Retainers - Ferrea Seat locators and new valve stem seals I called FBM directly and ordered the heads rather than via the web. I don't know if they tweaked my order or if the web site needs updating. But I definitely have double valve springs, not single. |
The Following User Says Thank You to Draco-REX For This Useful Post: | smudge (12-05-2015) |
12-04-2015, 09:39 PM | #117 |
Drives: 2016 frs
I got a 2016 frs about a month ago. After reading this thread about his motor issue. My turbo build seems like it's going to cost alot more then I had thought. Did any of there motor issues get fixed in the 2016 models. I plan on having between 325 - 350whp and I'm thinking an internal overhaul is now needed.
12-04-2015, 10:46 PM | #118 | |
Corner Junkie
The Following User Says Thank You to Draco-REX For This Useful Post: | Lonewolf (12-06-2015) |
12-12-2015, 11:43 PM | #119 |
Corner Junkie
The rebuild has begun!
Tear down: A peek at the cylinder with the rocker failure: No impact from the valve! Though that bubble in the cylinder wall casting is unexpected. But I think if it were an issue, it would have caused a problem by now. And the new heads are on! Tear down to rebuild in one working day. ZB's the man. Can't wait to get this back on the road. I just hope the salt holds off long enough to burn off the tank of E85 before I put it in storage. |
The Following User Says Thank You to Draco-REX For This Useful Post: | Lonewolf (12-14-2015) |
12-14-2015, 02:24 AM | #120 |
Drives: GT 86
Check the valve clearances now that it's back together as some of mine were out of spec once assembled.
12-18-2015, 07:45 PM | #121 |
Corner Junkie
IT'S ALIVE!!
Unfortunately I can't pick it up until Monday. And I won't be able to get any real impressions before I have to park it Tuesday as I'll have to do some logging first. And then I'm away visiting family starting Wednesday. Sigh. |
12-23-2015, 03:09 PM | #122 | |
Ridge Racerrrrrrrrr
12-23-2015, 03:09 PM | #123 |
Ridge Racerrrrrrrrr
Very excited for you Draco!
Similar Threads | ||||
I Need Advice About An Fr-s! | DViper0020 | Issues | Warranty | Recalls / TSB | 13 | 05-09-2014 10:15 AM |
Some advice | zoomzoomers | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-22-2013 05:16 PM |
Advice | EDCOVEY | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 12-10-2012 08:16 AM |
Need advice | Ikmv | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-23-2012 12:17 AM |
Need advice | FRSMAK86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-06-2012 05:39 PM |
