#15 | |
My S2000 bearing died at 116k miles. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Irace86.2.0 (07-02-2018) |
#16 | |
Drives: Q5 + BRZ + M796
The thing is I am thinking of replacing the snout too. It was kinda worn down so I don’t know if the snout will be a problem for future failures.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | CSG Mike (07-03-2018) |
#17 |
not playing cards
Can't quote you. Very good idea to replace the transmission front cover. Before you apply the sealant, make sure the mating surfaces are completely de-greased, and that the transmission is oriented so oil doesn't seep down into the face you just cleaned.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | CSG Mike (07-03-2018), Irace86.2.0 (07-03-2018) |
#18 | |
I figure for $80 it is good insurance to just replace it.
#19 | ||
Also, I emailed Exedy and got this in less than 24 hours: Quote:
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | RallySTI (07-03-2018), Ultramaroon (07-03-2018) |
#20 |
Drives: 2016 White Pearl BRZ Premium
I just went through the whole same thing you're going through. New Flywheel, pilot bearing, New input shaft cover/snout casting, Exedy "Stage 1" clutch (looks OEM to me). I read about the bearings, and found the new revised TOB part number cheapest from Olathe Toyota so I went the new bearing route (ordered 2 of em). I even replaced the $5 a piece, green thread locker coated cover/snout bolts that the service manual designates as "one time use".
The TOB that came in the Stage 1 clutch kit looked IDENTICAL to the revised Toyota PN bearing, minus the white dot. It'll be the last one I use as a spare I used Permatex Optimum Grey for the snout/cover surface. It's high heat resistance was a bonus, as I figure it gets HOT in there. Also lightly greased the new snout with Amsoil high temp resistant synthetic grease. 30 street miles and then straight to the track for 8 30 min run sessions. Seems to be fine so far... |
| The Following 2 Users Say Thank You to Joesurf79 For This Useful Post: | Irace86.2.0 (07-03-2018), Ultramaroon (07-03-2018) |
#21 |
Drives: 2013 Subaru BRZ
| The Following 2 Users Say Thank You to RallySTI For This Useful Post: | Irace86.2.0 (07-03-2018), Ultramaroon (07-03-2018) |
#22 | |
not playing cards
![]() I made a false assumption some time ago after seeing this.
#23 |
Drives: 2005 Toyota Camry
The only way you are guaranteed the "latest" throwout bearing is if you ordered the genuine Toyota or Subaru part number that supercedes the older one.
Some clutch kits do not have TOBs included. Some clutch kits give you "OE replacement" which is anything that meets/exceeds the standard genuine OEM in terms of quality/warranty.... which is 12000 miles or 12 months if you buy it new (and installed by certified mechanic). Some clutch kits give you aftermarket OE replacement TOBs. Some clutch kits give you aftermarket performance replacement TOBs (either in OE configuration or their own design, such as OS Giken or Exedy Hyper or ORC) Good luck. |
| The Following User Says Thank You to mav1178 For This Useful Post: | Irace86.2.0 (07-03-2018) |
#24 | |
| The Following User Says Thank You to RallySTI For This Useful Post: | Ultramaroon (07-03-2018) |
#25 |
not playing cards
I wonder who specified the grease. o.O
#26 |
The release bearing used in the Twins is the same bearing that has been used since the 90's for the 2.5L non turbo and now the FB25 and FB20 ( is that the right engine code for the Impreza 2.0l ??) non turbo equipped Subaru's Those cars use a 225mm clutch which has a higher release load (force required to move the diaphragm spring) than the OEM pressure plate assembly used in the twins. The other cars have very rare instances where the bearing wears out like we regularly see with these cars.
The updated bearing only applies to the BRZ in the Subaru line according to their parts network. Subaru also updated the release bearing for the WRX due to a chirping noise complaint. This update was a redesign not just an grease change. |
#27 | |
to share the info from our follow up emails, when replacing the bearing sleeve/support I would use the OEM specified RTV (Threebond 128)as it is designed to be used with transmission oil. The Toyota part number is 00295-01281. |
| The Following User Says Thank You to RallySTI For This Useful Post: | Irace86.2.0 (07-03-2018) |
#28 | |
| ACT Clutch Kits Scion FR-S/BRZ 2013+ Now In Stock, Free Shipping! at SubiPower.com | SubiPower.Com | Transmission and Driveline | 36 | 11-10-2015 10:51 AM |
| ACT CLUTCH Introduces New FRS / BRZ Clutch Kits & Flywheels !!! | Zerolift | Transmission and Driveline | 3 | 12-09-2013 12:05 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 11:01 AM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
