Software Tuning Discuss all software tuning topics. |
10-29-2014, 05:02 AM | #1 |
Drives: Toyota 86
MatLab log analysis
I've been using MatLab to crunch my logfiles for a while now. Please post script examples that you find useful on this thread if you use MatLab.
Benefits: Fast, I mean properly fast. I can combine multiple scripts for analysis all at once (just loaded 112MB in 20 log files over 24.5 seconds). Drawbacks: Expensive, unless you work/study in an institution that you access the software through. Basic information including .csv loading and data filtering and binning scripts shared by nil5 on the Romraider forum. The scripts that I use are based on these and you'll need these scripts in the same folder that you run other scripts from if you want to use examples that I post: http://www.romraider.com/forum/viewtopic.php?t=7233 Tips: 1. Please note that you will need to make sure that the scripts match your logging parameter names which are case sensitive. 2. Use a revision number at the end of each logfile - it will make it easy to batch analyze a lot of logfiles together. Starting off: The load_csv.m script that I use (I think I found it somewhere on the Romraider forums, I am not smart enough to have written it). Put in the appropriate revision number for the files that you want to analyze before running it: Code:
clear close all filepath = '.\'; filenames = ls([filepath '\*rev_x.xx.csv']); s = size(filenames); tic disp('Loading data...'); for f = 1:s(1) fprintf(1,'(%d) %s\n',f,filenames(f,:)); data_tmp = data_load([ filepath filenames(f,:) ]); if (f == 1) data = data_tmp; else data = data_cat(data,data_tmp); end end toc data0 = data; I'll post examples later on in the thread. |
The Following 5 Users Say Thank You to ztan For This Useful Post: | diodelphi (10-29-2014), Garrett@Openflash (10-30-2014), sato (11-04-2014), SportInjected (11-03-2014), steve99 (10-29-2014) |
10-29-2014, 05:29 AM | #2 |
Drives: 86
please continue
I love matlab, i think will be so helpful for tuners |
10-29-2014, 06:52 AM | #3 |
Drives: Toyota 86
Trims for MAF scaling in CL example
Simple example: closed loop trims for scaling MAF
Load data using load_csv.m script Data needed for analysis: time, STFT, LTFT, MAF_V Data needed for filtering: ECT(Coolant temp), CL_OL status Code:
data = data0; %generate total trim data.tottrim=data.STFT+data.LTFT; %generate dMAF/dt data.dMAF_V=diff(data.MAF_V)./diff(data.time); data.dMAF_V=vertcat(data.MAF_V(1),data.dMAF_V); data.dMAF_V=abs(data.dMAF_V); fn = fieldnames(data); N = length(fn); %make sure engine is up to temp ect_idx=find(data.ECT>80); data=data_filter(data,ect_idx); %discard wide variations in MAF dMAF_V_idx=find(data.dMAF_V<0.2); data=data_filter(data,dMAF_V_idx); %find closed loop operation CL_OL_idx=find(data.CL_OL==2); data=data_filter(data,CL_OL_idx); %MAF_V scale bins MAF_V_Scale = [0.898,0.938,0.977,1.016,1.055,1.094,1.133,1.172,1.211,1.250,1.289,1.328,1.367,1.406,1.445,1.484,1.523,1.563,1.602,1.641,1.680,1.719,1.758,1.797,1.836,1.875,1.914,1.953,1.992,2.031,2.070,2.109,2.148,2.188,2.227,2.266,2.305,2.344,2.383,2.422,2.461,2.500,2.578,2.773,2.969,3.203,3.438,3.711,3.906,4.063,4.297,4.492,4.727,5.000]; MAF_V_Scale = reshape(MAF_V_Scale,54,1); %put trim data in MAF_V bins MAF_bin = data_bin(data,data.MAF_V, MAF_V_Scale); MAF_corr_mean = zeros(length(MAF_bin),1); MAF_corr_mode = zeros(length(MAF_bin),1); MAF_corr_median = zeros(length(MAF_bin),1); MAF_corr_std = zeros(length(MAF_bin),1); %define minimum count number MIN_CNT = 10; for m= 1:length(MAF_bin) tottrim = MAF_bin(m).data.tottrim; MAF_corr_mean(m) = mean(tottrim); MAF_corr_mode(m) = mode(tottrim); MAF_corr_median(m) = median(tottrim); MAF_corr_std(m) = std(tottrim); MAF_corr_cnt(m) = length(tottrim); if (MAF_corr_cnt(m) < MIN_CNT) MAF_corr_mean(m) = 0; MAF_corr_mode(m) = 0; MAF_corr_median(m) = 0; MAF_corr_std(m) = 0; end end %%Plot data figure(1); scatter(data.MAF_V,data.tottrim,2); title('MAF Trims'); hold on; plot(MAF_V_Scale,MAF_corr_mean,'-*r','MarkerSize',4); plot(MAF_V_Scale,MAF_corr_median,'-*g','MarkerSize',4); hold off; Example trim plot: |
The Following User Says Thank You to ztan For This Useful Post: | diodelphi (10-29-2014) |
10-29-2014, 07:30 AM | #4 |
Drives: FT86
Have you seen VGI,s maf scaling utility ?
10-30-2014, 05:34 AM | #5 |
Drives: Toyota 86
Knock analysis - quick and dirty
Script for high level log analysis - display IAM, FLKC, and FBKC in one place over however many logfiles you've loaded:
Code:
figure(1); % engine load subplot(3,1,1); plot(data.IAM,'.-'); title('IAM'); subplot(3,1,2); plot(data.FBKC,'.-'); title('FBKC'); subplot(3,1,3); plot(data.FLKC,'.-'); title('FLKC'); Time to load files: 5.2 sec, plot processed in under a second: |
11-01-2014, 07:19 PM | #6 |
Drives: Toyota 86
Selecting part of a datalog stack
To isolate a part of a log for more detailed analysis, you can use the data filter script that nil5 provided.
For example, to look at the FLKC data in the above example, you could set an index and then filter the data appropriately: Code:
%set index to the frames that you want %example set index to select samples 20000-30000 idx=[2e4:3e4]; %filter data %full stack of logfiles in data0 data=data_filter(data0,idx); |
11-01-2014, 07:26 PM | #7 |
Drives: Toyota 86
Analyzing knock events - FLKC
Example code is for analyzing FLKC decrements.
FLKC as well as FLKC_Offset cell need to be logged with other parameters. The script identifies areas where FLKC has dropped without the offset cell changing, parses the data stack for samples pre and post FLKC decrement and plots whatever data that you want related to the knock event. Average FLKC at each decrement is returned in a matrix that is load and RPM binned appropriately (FLKC_mean in this example). Scripts for analyzing FBKC and IAM are similar but not as complex. Code:
% find discrete decreases in FLKC data.flkc_dec=zeros(length(data.time),1); for m=2:1:length(data.time) %note difference if FLKC value is lower than last FLKC if data.FLKC(m)<data.FLKC(m-1) & data.FLKC(m)<0; data.flkc_dec(m)=data.FLKC(m); %discard data if FLKC offset cell has changed if data.FLKC_Offset(m)~=data.FLKC_Offset(m-1) data.flkc_dec(m)=0; else end else end end idx_flkc = find(data.flkc_dec ~= 0); %% Get indices that occurred immediately before and after the knock was detected and plot SAMPLES_PRE = 20; SAMPLES_POST = 19; if (isempty(idx_flkc)) display('FLKC: None.'); else idx_flkc_pre = (idx_flkc*ones(1,(SAMPLES_PRE+1)))-(ones(length(idx_flkc),1)*(0:SAMPLES_PRE)); idx_flkc_post = (idx_flkc*ones(1,(SAMPLES_POST)))+(ones(length(idx_flkc),1)*(1:SAMPLES_POST)); idx_flkc2 = unique(cat(2,idx_flkc_pre,idx_flkc_post)); % generate data sets with pre and post samples data_flkc2 = data_filter(data,idx_flkc2); % Generate some plots figure(1); % RPM subplot(8,1,1); plot(data_flkc2.RPM,'.-'); title('RPM'); grid; % Load subplot(8,1,2); plot(data_flkc2.Load,'.-r'); title('Load'); grid; % timing subplot(8,1,3); plot(data_flkc2.TotTiming,'.-'); hold all; plot(data_flkc2.BaseTiming,'.-r'); title('Timing'); grid; % afr subplot(8,1,4); plot(data_flkc2.AFR,'.-'); hold all; plot(data_flkc2.AFR_command,'.-r'); title('AFR'); grid; % Throttle subplot(8,1,5); plot(data_flkc2.Throttle,'.-'); title('Throttle'); grid; % Trims subplot(8,1,6); plot(data_flkc2.LTFT,'.-'); hold all; plot(data_flkc2.STFT,'.-r'); title('Trims'); grid; % cl_ol subplot(8,1,7); plot(data_flkc2.CL_OL,'.-'); title('CL/OL Status'); grid; % Knock subplot(8,1,8); plot(data_flkc2.FBKC,'.-'); hold all; plot(data_flkc2.FLKC,'.-r'); hold all; plot(data_flkc2.IAM,'.-g'); title('Knock') grid; end %% data binning data_flkc=data_filter(data,idx_flkc); load_bins = [0.15,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1,1.1,1.2,1.3,1.4]; rpm_bins = [800,1000,1200,1600,2000,2200,2400,2600,2800,3200,3600,4000,4400,4600,4800,5200,5600,6000,6400,6800,7000,7200,7400]; % Bin data by Load data_flkc_load_binned = data_bin(data_flkc, data_flkc.Load, load_bins); % Bin the data by RPM flkc_binned = repmat(struct(),1,length(data_flkc_load_binned)); for m=1:length(data_flkc_load_binned) data_tmp = data_flkc_load_binned(m).data; flkc_binned(m).data = data_bin(data_tmp,data_tmp.RPM,rpm_bins); end % Now we have all the data binned!!! % Construct a matrix of the parameter to observe FLKC_mean = zeros(length(rpm_bins),length(load_bins)); % Put parameters in matrix for m= 1:length(load_bins) for n = 1:length(rpm_bins) flkc2 = flkc_binned(m).data(n).data.flkc_dec; if (isempty(flkc2)) FLKC_mean(n,m) = 0; else FLKC_mean(n,m) = mean(flkc2); end end end %Average FLKC for each FLKC decrement incident returned in FLKC_mean %% Histogram plot figure(100) surf(load_bins,rpm_bins,FLKC_mean); xlabel('load'); ylabel('rpm'); zlabel('FLKC decrements'); title('FLKC histogram'); |
11-03-2014, 05:16 PM | #8 |
Canada Eh!
Drives: '13 FRS
This makes me want to learn matlab some more
11-04-2014, 03:30 PM | #9 | |
Canada Eh!
Drives: '13 FRS
11-05-2014, 06:54 AM | #10 | |
Drives: Toyota 86
My logfiles are quite big and if you string a few drives together, you might need to be crunching many, many MB all together. |
11-11-2014, 03:56 PM | #11 |
Drives: Toyota 86
Examining trims and DI flow
This example looks at adjustment of DI fuelling using the GDI flow table. Other tables can be used including GDI pressure target and GDI pressure multiplier.
When looking at the ROM disassimbly, a lot is indirectly referenced and quite difficult to pick apart. For the GDI flow table in the A01G ROM: X-axis is Fuel Pressure, FFF8936C is the RAM address for data used in the GDI Flow table Y-axis looks like a Direct Injector Pulse Width value, FFF887E8 is the RAM address for data used in the GDI Flow table (I log this as Direct_IPW_0). The return from the GDI flow lookup gets stored in FFF887EC and logs very closely with FFF887F0 (I believe this is Direct IPW). This script can be run in 2 states, I've only shown the first: 1. Combined PI : DI operation 2. Full DI Similar to MAF scaling with trims, this script only looks at closed loop operation. An error between the two can be calculated to see if PI activation skews anything, but I have not found that particularly useful. Code:
%reset dataset data = data0; %generate total trim data.tottrim=data.STFT+data.LTFT; %generate dMAF/dt data.dMAF_V=diff(data.MAF_V)./diff(data.time); %add first dMAF/dt value - expand dMAF_V by one data.dMAF_V=vertcat(data.MAF_V(1),data.dMAF_V); %make absolute value data.dMAF_V=abs(data.dMAF_V); %engine up to temp ect_idx=find(data.ECT>80); data=data_filter(data,ect_idx); %dMAF_V/dt<0.2 dMAF_V_idx=find(data.dMAF_V<0.2); data=data_filter(data,dMAF_V_idx); %CL operation CL_OL_idx=find(data.CL_OL==2); data=data_filter(data,CL_OL_idx); %set minimum count for matrix MIN_CNT = 30; %set plot limit ZLIM = [-10,10 ]; %% Data binning to GDI flow table %set fuel pressure and direct_ipw bins fuelpress_bins = [2.0,4.0,8.0,12.0,16.0,20.0]; direct_ipw_bins = [0.6,0.7,0.8,0.9,1.0,1.1,1.2,1.3,1.4,1.5,2.0,3.0,4.0,5.0]; data_comb_fuelpress_binned = data_bin(data, data.FuelPress, fuelpress_bins); data_comb_binned = repmat(struct(),1,length(data_comb_fuelpress_binned)); for m = 1:length(data_comb_fuelpress_binned) data_comb_tmp = data_comb_fuelpress_binned(m).data; data_comb_binned(m).data = data_bin(data_comb_tmp,data_comb_tmp.Direct_IPW_0,direct_ipw_bins); end % construct a matrix of the total trim comb_trim_mean = zeros(length(direct_ipw_bins),length(fuelpress_bins)); comb_trim_median = zeros(length(direct_ipw_bins),length(fuelpress_bins)); comb_trim_cnt = zeros(length(direct_ipw_bins),length(fuelpress_bins)); %corr_matrix_std = corr_matrix_mean; for m= 1:length(fuelpress_bins) for n = 1:length(direct_ipw_bins) comb_trim = data_comb_binned(m).data(n).data.tottrim; if (isempty(comb_trim)) comb_trim_mean(n,m) = 0; comb_trim_median(n,m) = 0; comb_trim_cnt(n,m) = 0; else comb_trim_mean(n,m) = mean(comb_trim); comb_trim_median(n,m) = median (comb_trim); comb_trim_cnt(n,m) = length (comb_trim); end if (comb_trim_cnt(n,m) < MIN_CNT) comb_trim_mean(n,m) = 0; comb_trim_median(n,m) = 0; end end end %%plot data figure(1); surf(fuelpress_bins,direct_ipw_bins,comb_trim_mean); xlabel('FuelPress'); ylabel('Direct_IPW'); zlabel('TotalTrim'); zlim(ZLIM); title('GDI Flow Rate Combined Trims'); |
The Following User Says Thank You to ztan For This Useful Post: | SportInjected (11-11-2014) |
11-28-2014, 10:45 PM | #12 |
Drives: Toyota 86
Calculating Volumetric Efficiency
This is a script to calculate your volumetric efficiency. Can be used to tune AVCS if you have a lot of time on your hands to maximize the amount of air running through your engine at a given rpm/load point.
Based on the romraider derivation at http://www.romraider.com/forum/viewtopic.php?t=8054 but using metric units that I log with. Code:
data = data0; %calculate VE %VE=100*((MAF g/s * R L.kPa/K.mol * IAT K)/(MAP kPa * MMA g/mol))/(Disp cycle/L * RPM rev/min / (60 s/min * 2 rev/cycle)) %R = 1.205912 (MAP in psi), R = 0.08314472 (MAP in bar), R= 8.314472 (MAP in kPa), R = 62.363669 (MAP in mmHg). %MMA = Molar Mass of Air Constant =28.97 g/mol data.VE=100.*((data.MAF).*8.314472.*(data.IAT+273.15))./((data.MAP).*28.97)./(1.998.*(data.RPM)./(60*2)); MIN_CNT = 30; ZLIM = [0,120]; %% load_bins = [0.15,0.20,0.30,0.40,0.50,0.60,0.70,0.80,0.85,0.90,0.95,1.00,1.10,1.20,1.30,1.40]; rpm_bins = [800,1000,1200,1600,2000,2200,2400,2800,3200,3600,3800,4000,4200,4400,4600,4800,5200,5600,6000,6400,6800,7000,7200,7400]; %% data_VE_load_binned = data_bin(data, data.Load, load_bins); data_VE_binned = repmat(struct(),1,length(data_VE_load_binned)); for m = 1:length(data_VE_load_binned) data_VE_tmp = data_VE_load_binned(m).data; data_VE_binned(m).data = data_bin(data_VE_tmp,data_VE_tmp.RPM,rpm_bins); end %% % now we have all the data binned!!! % construct a matrix of the parameter to observe VE_mean = zeros(length(rpm_bins),length(load_bins)); VE_median = zeros(length(rpm_bins),length(load_bins)); VE_cnt = zeros(length(rpm_bins),length(load_bins)); %% %corr_matrix_std = corr_matrix_mean; for m = 1:length(load_bins) for n = 1:length(rpm_bins) VE_tmp = data_VE_binned(m).data(n).data.VE; if (isempty(VE_tmp)) VE_mean(n,m) = 0; VE_median(n,m) = 0; VE_cnt(n,m) = 0; else VE_mean(n,m) = mean(VE_tmp); VE_median(n,m) = median (VE_tmp); VE_cnt(n,m) = length (VE_tmp); end if (VE_cnt(n,m) < MIN_CNT) VE_mean(n,m) = 0; VE_median(n,m) = 0; end end end %% figure(1); surf(load_bins,rpm_bins,VE_mean); xlabel('Load'); ylabel('RPM'); zlabel('VE'); zlim(ZLIM); title('Volumetric Efficiency'); Attached is stock intake and exhaust with Shiv's AVCS timing, you can see the torque dip in the VE plot. You can also see at low RPM when the throttle is cracked open, the MAF sensor reads air coming into the intake, but the engine speed hasn't responded by the time the line is logged leading to a falsely high VE. |
12-02-2014, 07:19 PM | #13 |
Drives: Toyota 86
Port and DI duty cycles
There are a few assumptions made here.
See Kodename47's PI : DI thread for the assumptions I have made and formula derivations. Port injector duty cycle: Code:
%calculate Port IDC %IDC = 100 % * Port_IPW msec / ((6000 msec/min * 2 rev/cycle)/ RPM rev/min) data.Port_IDC=(data.Port_IPW).*(data.RPM)./1200; Code:
%calculate DI IDC %max DI_IPW = 5ms, max FuelPressure = 20MPa data.DI_IDC=(data.Direct_IPW).*(data.FuelPress); Figures are Port and DI duty using stock Port injectors and stock PI : DI map (23% port duty, 65% DI duty at redline and 1.2-1.3 g/rev load): |
Similar Threads | ||||
Oil Analysis - 1st oil change | R L Newb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 375 | 11-19-2021 09:24 AM |
Used Oil Analysis Results | Captain Snooze | Engine, Exhaust, Transmission | 2 | 11-21-2013 12:59 PM |
ECUTek DTC/Readyness Analysis.... | 2forme | Software Tuning | 41 | 10-08-2013 06:49 PM |
Used Oil Analysis - Factory break-in oil | CSG Mike | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 11-10-2012 01:06 AM |
