Forced Induction Turbo, Supercharger, Methanol, Nitrous |
06-14-2016, 09:44 PM | #1 |
3 BAR Map Sensor Scaling
Can anyone can tell me step by step how to scale in a 3 bar map sensor? I can't find any on how to do it. Thanks
06-15-2016, 10:39 AM | #2 |
Drives: 85 corolla gts
I assume you are using something other then ecutek? As in the help files with ecutek there is a walk through for rescaling a map sensor.
The Following User Says Thank You to Ross For This Useful Post: | tonytduc (06-15-2016) |
06-15-2016, 10:53 PM | #3 |
I am using ecutek. Did not know about the walk through. thanks
06-16-2016, 08:52 AM | #4 |
If this is your first time using the software I would recommend reading all the info they provide in terms to this application. It will make life much easier for you.
The Following User Says Thank You to Ross For This Useful Post: | tonytduc (06-16-2016) |
06-17-2016, 12:28 PM | #5 |
Road-hole
Drives: 2013 Whiteout FR-S
Anyone know off hand?
Anyone know the omni 3 bar map scaling for V/PSI, versus bar?
I've done the calculation of what it should be, just want to make sure it's right. Jaden |
06-17-2016, 12:53 PM | #6 |
Drives: '13 BRZ
For Google / future searches.
Omni 3 bar: Multiplier 0.617 / Offset 0.03 Omni 4 bar: Multiplier 0.825 / Offset 0.031 |
The Following User Says Thank You to BRZoomTX For This Useful Post: | tonytduc (06-20-2016) |
06-19-2016, 01:22 PM | #7 | |
Road-hole
that is for bar...
that is bar/V. I'm looking for psi/V... I've done a manual conversion, just making sure that that is correct... Jaden Last edited by Jaden; 06-20-2016 at 07:58 PM. |
06-20-2016, 07:44 PM | #8 |
Got it working thanks
The Following User Says Thank You to tonytduc For This Useful Post: | BRZoomTX (06-24-2016) |
06-24-2016, 02:10 PM | #9 | |
Drives: '13 BRZ
As for your question, I'd recommend making a new topic since its not related to OP's question at all. |
06-24-2016, 02:24 PM | #10 | |
Road-hole
Are you serious?
Do you know them? If you do that was ridiculous because you could've more easily just posted them than your stupid request that I start a new thread requesting the SAME thing in a slightly different format. Jaden |
Similar Threads | ||||
Omni 2.5Bar MAP sensor scaling | luckykevin | Software Tuning | 9 | 11-05-2020 11:51 AM |
Front O2 Denso Planar sensor scaling | ztan | Software Tuning | 21 | 05-17-2017 02:32 AM |
3 bar omni map sensor scaling | Hachiroku.86 | Software Tuning | 3 | 04-30-2016 01:51 AM |
OMNI 2.5Bar MAP sensor scaling | luckykevin | Forced Induction | 0 | 04-02-2016 10:56 AM |
Scaling for vortech 2.5 bar map sensor? | Frs32907 | Software Tuning | 2 | 11-08-2015 05:41 PM |
