Old 05-31-2022, 11:53 PM   #1
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
Changing flex fuel kits
I currently have a Delicious tuning mk1 Flex fuel kit on my 2013 BRZ and it is tuned by them on ECUTek.
I'm look at changing to the PTuning flex fuel kit so that I can have a physical display in the car with the ethenol %. I saw that their kit supports both 0-5v reading as well as 0.0-4.5V reading. If I match the range the Delicious Tuning kit reads, am I correct in believing that I will not need my tune changed?
Also, can anyone confirm what range the Delicious Tuning kit reads at? Both kits use the rear O2 sensor and I think the DT kit reads 0.5-4.5V but I can't find a confirmation.
Sevs753 is offline   Reply With Quote
Old 06-02-2022, 05:41 AM   #2
steve99
Drives: FT86
yes if you match the voltage ranges you can swap kits
unfortunalt some early deliceous kits were 0-5 and then at some point they changed to0.5-4.5 v range
CounterSpace Garage || EcuTek | Flex Fuel Kits | Tuning Options || CounterSpace Garage Engine, Exhaust, Bolt-Ons 2 08-09-2016 02:00 PM
15% Off Flex Fuel Kits & Tunes, Through 4/11/15 DeliciousTuning Announcements, Contests, Giveaways 0 04-09-2015 06:44 PM
Any Flex Fuel kits with OFT compatibility? misooscar Engine, Exhaust, Transmission 2 03-23-2015 09:29 PM
The facts behind Flex Fuel kits available for the 86 Yruyur Engine, Exhaust, Transmission 56 01-23-2015 01:06 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
