Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-14-2017, 09:27 PM | #1 |
Drives: Many
Fuel pump assembly: Fuel pressure regulator popping out
The fuel pressure regulator is popping out of the fuel pump assembly, which is in the tank. It is just a push in device.
It pops out after I prime the fuel system. You can hear the pump priming, and after the third prime, BANG, it's now sitting in the bottom of the fuel canister and I have no fuel pressure. Has anyone experienced this before or know why it could be happening? |
09-15-2017, 08:29 PM | #2 |
Drives: Many
There is a small plastic brackets that holds the pressure regulator in place. It also is the piece that holds the stock fuel pump filter. I cut off the piece from the stock filter assembly and now the regulator is staying in place.
09-15-2017, 09:39 PM | #3 |
Yes.... you're supposed to do that.
Similar Threads | ||||
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu | ndreim | Engine, Exhaust, Bolt-Ons | 5 | 11-23-2016 11:36 PM |
high pressure fuel pump = 5 years / 100 000 km ? | jefars | Issues | Warranty | Recalls / TSB | 7 | 09-16-2016 01:26 PM |
Adding in line fuel pressure regulator | KGZ86 | Engine, Exhaust, Transmission | 13 | 07-07-2016 05:15 PM |
stronger pump increasing fuel pressure? | Crunk81us | Engine, Exhaust, Transmission | 37 | 06-26-2016 05:03 AM |
Fuel pump hanger assembly | slicktop | Want-To-Buy Requests | 1 | 12-09-2014 03:23 AM |
