Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
12-25-2018, 08:51 AM | #1 |
Meow
Drives: GT86, Volvo 996
OBDII 52mm oil temp gauge
Hello Guys,
I'm looking to add an integrated oil temp gauge to my 86. I've seen the P3 vent gauge which is a really elegant solution, but at almost $500 over here in Europe, it's a little steep. There are cheap adapters for 52mm gauges using the driver's side vent (appx. $20), which require a 52mm OBDII gauge capable of displaying oil temp. Is there a go-to gauge for 86 users that does this? Best regards, Alex |
12-25-2018, 09:53 PM | #2 | |
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 12-25-2018 at 10:55 PM. |
12-26-2018, 06:03 AM | #3 |
Drives: Toyota 86
Pivot makes a guage specifically for the twins that shows both water temp and oil or intake temp. There are two models, one with a white backlight for the 86 and one with a red backlight for the BRZ.
https://pivotjp.com/product/dual-gauge/index-e.html https://global.rakuten.com/en/store/cps-mm/item/n22853/ |
The Following User Says Thank You to HRTROB For This Useful Post: | norcalpb (12-26-2018) |
Similar Threads | ||||
FS: CravenSpeed Dual Guage Pod + ATI 52mm Vent Gauge Pod | skylinekin | Interior Parts (Incl. Lighting) | 1 | 05-22-2017 06:43 PM |
FS: 52mm Steering Column Gauge Pod | skylinekin | Interior Parts (Incl. Lighting) | 2 | 02-11-2017 09:35 AM |
Block8head defroster vent gauge pods (all 52mm varieties) with pictures. | Cheeseballs | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 03-20-2016 10:46 AM |
52mm AT temp gauge | rAzEn | Tracking / Autocross / HPDE / Drifting | 2 | 01-03-2016 10:03 PM |
Custom gauge pod (52mm) | Fizz | Australia Classifieds | 2 | 12-01-2015 07:58 AM |
