Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-01-2019, 10:15 PM | #1 |
Drives: FRS
Check Engine Light after installing HKS drop in air filter
Installed the HKS Super Hybrid Air Filter a few months ago and got codes; P0171 P117B P1170. Redid the install the next day and found out I didn't fit the the air box tightly.
This weekend the codes came back so I checked the air box and everything was snug so I dropped the car off at a shop. The shop tech told me the codes are being caused by my cat-back because "your cat-back is creating back pressure which is causing you to run lean". Can anyone verify if this would be true? Only exhaust mods done to my car are the HKS Hi-Power Spec-L cat-back and the drop if filter if you count that... |
07-01-2019, 11:13 PM | #3 |
[insert cool phrase here]
Drives: BRZ Premium
Car fucked. Burn it. Don't bother selling that pos.
Buy a new Civic Si. Problem solved. Sounds like you got some gunk in either or both throttle body or Mass air flow sensor. I always take off the whole intake box when changing filters. Too much fuckery if I don't. It's only 4 bolts and one connector.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following User Says Thank You to Mr.ac For This Useful Post: | Tristor (07-02-2019) |
07-03-2019, 10:13 PM | #4 |
Damn that's crazy...
Drives: 2015 BRZ
Jesus you know life sucks when the easiest “mod” goes wrong lmao
I would say just take time to triple check if everything is clean and tight. Wouldn’t worry about it too much. Also, wouldn’t listen to the tech...or take your car there again. Too much back pressure? If that’s the case, every single car with an aftermarket catback would have a check engine light lol |
07-04-2019, 02:33 AM | #5 | |
Señor Member
Also check this thread: http://www.ft86club.com/forums/showthread.php?p=2128963
1974 TA22 Celica
2013 86 GT |
Similar Threads | ||||
Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
Changed Air Filter caused check engine light | Buellr | DIY (Do-It-Yourself) Guides | 10 | 01-13-2015 05:55 PM |
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 06:06 AM |
Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
