Tracking / Autocross / HPDE / Drifting What these cars were built for! |
Drives: 2016 Scion FRS Release Series 2#439
Wheel hub bearing life expectancy?
Any insights regarding front &/or rear wheel hub durability in track driven 86’s using 200 tw tires and improved suspension with high camber (-5,-2)?
And, is there a hub which would be better than an OEM replacement?
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#2 |
Drives: 2023 BRZ
Mine all lasted more than 100,000 mi.
Sent from my Pixel 7a using Tapatalk
Director of Rocky Mountain 86CUP
#3 |
AutoX-10/10ths every run
I preemptively replaced my rears about 110K, need to check my fronts for slop at some point, at about 128K on those.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
#4 |
Drives: Crapcan
OEM worked best for me. I tried a couple off brands I’ve been through a handful of fronts and one rear.
#5 |
Drives: None
I lost the front left at like 33k miles on the chassis so I replaced it with a Timken. That one lasted about ten events before making the tell-tale marbles in hollow can noise when spinning so I replaced it with a Centric. Centric has been fine for about 30 events now.
I got a good deal on OEM fronts so I currently carry an OEM front and an OEM rear as spares.
#6 |
Thanks, and keep the info coming folks!
I’m only at ~86,000 kl (~53,000 miles) mostly DD so may be good for some time.
#7 |
Drives: 2017 BRZ PP, 2004 WRX
I don't want to jinx myself, but I'm at ~43k miles on a 2017 with mainly heavy autocross usage. Probably about 665 autocross runs from my records (about 110 events). 200TW tires, stock suspension, stock wheels/offset. Wheel bearings appear to be still just fine.
#8 |
Drives: Awesome
lost my rear hub at 33k miles and replaced it.
#9 |
Drives: Crapcan
I’ve had a bad front sitting on my bench as a paperweight I have been meaning to cut in half for years. I am kind of curious what the bearing size is and if the grease just isn’t up to snuff. It seems like track cars kill them a lot faster.
#10 |
Drives: '23 BRZ
The fronts on my 2017 only lasted one track season, 12 track days! Had them replaced under warranty
#11 |
Drives: '13 BRZ Limited
I got 50k and 30+ track weekends on my 2013 before the fronts needed replacing. The 2020 only went 11k and maybe 8 weekends before a rear was done, and both fronts followed shortly after at about 15k and maybe 3 additional weekends. Friend went ~5 years and 40+ (?) weekends on a 2019 before needing a rear. So, it it's pretty variable.
I think with lots of camber, 200tw tires, and driving to the limits of the car -- 8 weekends is unexpectedly early, but 30 or 40 weekends is overly optimistic. Those were all OEM and street-driven as well as track. How many hard hits from curbs/potholes/etc each took is sort of impossible to know. |
#12 |
Drives: None
Dropping wheels hard has been the number one killer of wheel bearings across track cars for me. Not the normal curb hits, the ones that make you wonder if half the car broke off.
The Following User Says Thank You to RedReplicant For This Useful Post: | CSG Mike (02-08-2024) |
#13 |
Wheel bearings are not a normal replacement item for this platform, and strictly "as needed". It's not common without reason.
#14 |
90k 3rd owner on a modified 2013 only driven on track now. all seem good so far
![]() Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
TOB life expectancy | Sniepster | Issues | Warranty | Recalls / TSB | 48 | 10-23-2022 11:36 PM |
front wheel bearing life | ZDan | Tracking / Autocross / HPDE / Drifting | 18 | 06-18-2019 11:38 AM |
Average life expectancy from Tein Basics? | HatchirokuV2.0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 12-11-2015 08:24 PM |
Wheel bearing? | Nylander | Issues | Warranty | Recalls / TSB | 20 | 06-08-2015 04:57 PM |
Wheel Bearing Woes | jwstaton | Issues | Warranty | Recalls / TSB | 16 | 01-24-2014 08:06 PM |
