Forced Induction Turbo, Supercharger, Methanol, Nitrous |
Drives: gts 86
My Borg Warner Treadstone turbo build
Hey gents,
After running open flash headers, CAI and and a 2.5inch header back for a year I decided I wanted more. I chose the treadstone kit for a couple of reasons . The first being that it kept the crash beam in tact. This was needed to get the car engineered after the turbo install. The second being it was at the time, the only kit offering a BorgWarner EFR with my first requirement. My power goals are fairly modest for what the kit is capable of. I'm aiming for 220-230 rwKw on E85 Tuning via Ecutek My tuner is away atm, he only managed to finish the 98 side of my tune and currently at around 50% ethanol on the e85. I'll post official results when the tune is completed in a couple of weeks. But for now it's making 200rwKw on 98 at 14psi.( 14psi was the base setting) Current list of relevant mods: -DBA -5000 rotors on the front and 4000's on the rear. -Exedy stage 1 clutch. -Delicious flex fuel -Crawford AOS -Deatschwerks 900cc injectors -Forged performance oil cooler( yet to be installed) sandwich plate and adapter in one Yay no leaks -Treadstone Turbo kit( Borg Warner 6758) - ceramic coated all hot and cold parts. Last edited by scarfo; 08-06-2015 at 02:35 AM. |
The Following User Says Thank You to scarfo For This Useful Post: | cdrazic93 (08-06-2015) |
#2 |
Drives: gts 86
The prototype of the oil cooler |
#3 |
Drives: gts 86
#4 |
Drives: 2015 FRS Hot Lava 2014 CT200H
I want so baddd... Nice build
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
The Following User Says Thank You to duke_FRS For This Useful Post: | scarfo (08-06-2015) |
#5 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Looks solid!
The Following User Says Thank You to Cockatoo For This Useful Post: | scarfo (08-06-2015) |
#6 |
Drives: 2013 BRZ black
Looks awesome! What MAP sensor did you select? Running the EBCS that's integrated on the EFR?
The Following User Says Thank You to xkalelx For This Useful Post: | scarfo (08-09-2015) |
#7 |
Drives: gts 86
Hey mate,
I'm running an Omni 4 bar coupled with the 900cc deatschwerks was a real pita to tune. And yeah I'm using a boost solenoid from the integrated unit on the turbo to Evap solenoid under the manifold |
The Following User Says Thank You to scarfo For This Useful Post: | xkalelx (08-22-2015) |
#8 |
Drives: Toyota GT86
Looks very clean and nicely done. We have similar looking setups ; manifold and downpipe wrapped with titanium wrap, and same flex fuel kit
![]() When do you hit full boost with that turbo so far on 98? Aren't you worried with running 14psi with this stock motor and CR?
#9 |
Drives: gts 86
I haven't look at a dyno sheet yet just have had chats to the tuner, he said it was around the 4-4.2k rpm range. I think the 6258 is around 3.8k.
I'm not to worried I have faith in the tuner. I'll be looking to rebuild the bottom end over the next 6-12 months. |
The Following User Says Thank You to scarfo For This Useful Post: | wnt3d (08-21-2015) |
#10 |
Drives: gts 86
Tuning is complete.
This as much power as I wanted to put through the engine with stock internals. I am very happy with the kit and tune. I'll write up a review in a couple of weeks after I put some km's into it |
#11 |
Drives: white out project fr-s
interested to see with that fast of a ramp speed in boost, how longevity of powertrain with that kind of shock in power will be. looks nice tho!!
#12 |
Drives: gts 86
my end goal will be a t56 or something of that nature along with a custom rear axel( I'm not launching the car from standstill), but it actually drives really smooth
#13 |
Did you pull the coolant from the throttle body line or the block? What about oil lines?
#14 |
Drives: gts 86
Oil from the block, unsure abut the coolant when I pop the hood next I'll you know
Borg Warner S256sx T3, SOLD | mrk1 | Engine, Exhaust, Bolt-Ons | 10 | 08-07-2015 01:04 PM |
First ever FR-S Borg Warner 7670 EFR turbo by JDL | texasbound972 | Forced Induction | 0 | 10-29-2014 11:19 PM |
Borg Warner S255-RS .48 | FAER | Forced Induction | 39 | 05-16-2014 01:27 PM |
Borg Warner Vs Garrett | DeBiase | Forced Induction | 12 | 12-02-2013 11:17 PM |
Borg Warner Match Bot | diss7 | Forced Induction | 15 | 09-28-2013 10:13 AM |
