Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
02-05-2016, 09:56 AM | #1 |
Drives: Stock Black/metallic flakes
Finally getting some new shoes :)
So getting my tax money soon and some new rims and tires. They are 18x9.75 +20 offset. I realize that there going to poke out out and stuff but im ok with that ha. I want to lower it as well, am i going to need to roll my fenders at all ? or anything that i would need to do to go lower with bigger wheels.
02-05-2016, 09:59 AM | #2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
02-05-2016, 10:13 AM | #3 |
Killed Scion
Drives: 2013 FR-S Whiteout
Alright. Yes, yes you will poke. In order for you to go lower and have enough clearance for your wheels I recomend the Tein Flex Z coils. What kind of tires will you be running?
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
The Following User Says Thank You to MisterSheep For This Useful Post: | go_a_way1 (02-05-2016) |
02-05-2016, 10:16 AM | #4 |
Not Bаnned Anymore
I would recommend JRZ Coilovers or a Penske setup... but that might be more then OP is willing to spend
The Following User Says Thank You to go_a_way1 For This Useful Post: | MisterSheep (02-05-2016) |
02-05-2016, 11:46 AM | #5 |
Drives: 13' Scion FRS
02-05-2016, 11:48 AM | #6 |
Drives: FRS
suspension-wise, you'll clear with stock/lowering springs, but the wheel will poke out and you wont be able to camber it in much even with camber bolts. basically, you'll have what some refer to as "mexi-poke" as for the outside edge near the fender, this really depends on the tire size you choose and suspension choice for how much camber you can dial in, or not.
so basically, you need to know what suspension setup you want to run, and what tire sizes you want to mount and then you can find out how those wheels will end up looking like.
The Following User Says Thank You to 8R6 For This Useful Post: | MisterSheep (02-05-2016) |
02-05-2016, 11:48 AM | #7 |
Not Bаnned Anymore
Figured lol!!! But I like to start by recommending the best and working down from there haha
02-05-2016, 12:32 PM | #8 |
Country Boy 4 Life
I love this pic! You will need coilovers, LCA, camber bolts, and possible UCA.
I do believe this is stock. And some patience to get it dialed in. Oh, and an amazing alignment guy. Member Slicvic, has had these wheels dialed in properly. http://www.ft86club.com/forums/showthread.php?t=39218 |
The Following User Says Thank You to Leonardo For This Useful Post: | MisterSheep (02-05-2016) |
02-05-2016, 12:41 PM | #9 | |
Killed Scion
I currently have 18x8.5 +33 up front with 245/35 tires and they poke a little, I have camber bolts and about -1.3 degrees of camber and the tire pokes from the fender ever so slightly. I need some coils or top hats to get that little extra bit, or another set of camber bolts.
The Following User Says Thank You to MisterSheep For This Useful Post: | 8R6 (02-05-2016) |
02-05-2016, 01:00 PM | #10 | |
Drives: FRS
The Following 3 Users Say Thank You to 8R6 For This Useful Post: |
02-05-2016, 09:08 PM | #11 |
LOL pretty much spot on. with the rims and budget
the tires are 225. but im mostly just looking for a wide stance look and not chew my tire apart |
