Old 02-06-2023, 01:23 PM   #1
norcalpb
norcalpb's Avatar
Vented sway bar bushing shield
I’m currently swapping over 2022 GR86 front crossmember/ skid plate parts to my 2013 and discovered that there is a new passenger sway bar bushing shield that has vents in it. I imagine this is because the exhaust is so close to the bushing. Direct fit for all my models looks like, but have not yet confirmed. Will do once I get home from work today.
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
DarkPira7e (02-06-2023), gpvecchi (02-06-2023), NoHaveMSG (02-08-2023)
Old 02-06-2023, 03:56 PM   #2
gpvecchi
gpvecchi's Avatar
SU003-09172? Is it plastic made?
Old 02-06-2023, 04:42 PM   #3
norcalpb
norcalpb's Avatar
Yes it is plastic and is indeed part #SU00309172 but also 56440CC010 from Subaru. Like $10 or so.
The Following User Says Thank You to norcalpb For This Useful Post:
gpvecchi (02-07-2023)
Old 02-07-2023, 10:34 PM   #4
norcalpb
norcalpb's Avatar
Before and After.
After taking a look at it installed, the vents seem to be facing the direction of airflow so they are probably intake holes for the secondary cat. For some reason I also thought this piece completely covered the bushing but it sits just below them.
The Following 9 Users Say Thank You to norcalpb For This Useful Post:
Capt Spaulding (02-08-2023), DarkPira7e (02-08-2023), femaledog (02-08-2023), gpvecchi (02-08-2023), Jdmjunkie (02-08-2023), makinen (02-08-2023), NoHaveMSG (02-08-2023), RedReplicant (02-08-2023), x808drifter (02-09-2023)
Old 02-08-2023, 04:15 PM   #5
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Originally Posted by norcalpb View Post
Before and After.
tomorrow i use my dremel, speed holes!
Ruben_86_ is offline   Reply With Quote
The Following 3 Users Say Thank You to Ruben_86_ For This Useful Post:
DarkPira7e (02-08-2023), gpvecchi (02-09-2023), norcalpb (02-08-2023)
Old 03-04-2024, 04:21 PM   #6
abyssFT86
Drives: 2020 BRZ Limited
Interesting, I have a related thread here:https://www.ft86club.com/forums/showthread.php?t=154522
Does this venting actually help with overpipe temps and sway bar bushing melting issues? I feel like the venting seems like it wouldn't do a lot for the bushing which sits at the side of the overpipe which is closer to the engine and well ahead of the vents
abyssFT86 is offline   Reply With Quote
Failing Sway Bar Bushing? jkost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-20-2021 04:14 PM
Rear sway bar bushing T0rt0r0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 11-10-2018 02:41 AM
Is this a busted sway arm bushing? ironsurfer129 Issues | Warranty | Recalls / TSB 9 08-26-2017 01:09 AM
Whiteline Front and Rear Sway Bar + Bushing Kit $550 MicheleAbbate Brakes, Suspension, Chassis 1 01-28-2015 11:23 AM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
