BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
07-26-2022, 08:29 AM | #1 |
New Release: Killer B Motorsport Dual Air Oil Separator
The Killer B Motorsport Dual Catch Can AOS system is designed to remove excess oil vapor from crankcase gasses before they reach your intake. Doing so keeps your intake and valves cleaner and maintains proper octane levels. We do this using a vortex system that is efficient without limiting flowrates, unlike baffled units.
Our Performance Dual AOS configuration places the AOS's infront of and behind the intake manifold. This setup is intended for high performance track use. -Light weight -3D printed from automotive grade reinforced plastic -Comes in Single or Dual configuration -Looks OEM -Easy to drain -Installs in less than 20 minutes Single $129 Dual $249 Last edited by KillerBMotorsport; 07-26-2022 at 01:28 PM. |
The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
07-26-2022, 09:07 AM | #2 |
Rust bucket enthusiast
Might want to fix the " duel" at the bottom to read " dual".
I think emptying is also a consideration people may make with their purchase, are you planning on adding detailed information on what the dual setup looks like, how draining works? OEM looking parts are really awesome, I wish we had more. Sometimes a loud aftermarket piece is great, but I think "HEY, my car blows so much vapor past the rings I need something to catch it!!!" isn't something I'd want to scream
07-26-2022, 09:22 AM | #3 | |
Drives: 22 BRZ limited
The Following User Says Thank You to dragoontwo For This Useful Post: | DarkPira7e (07-26-2022) |
07-26-2022, 09:23 AM | #4 |
Drives: GR86 RC
Can i check what the plastic material is? Especially in relation to high engine bay temps and hydrocarbons (which are actually strong solvents for certain plastics).
07-26-2022, 09:29 AM | #5 |
Drives: 2013 frs base
Dual? Where does the 2nd one go? Valve covers or pvc?
07-26-2022, 01:31 PM | #6 | |
Yes, more pics coming and on our site we have detailed install instructions too. Super easy! |
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | DarkPira7e (07-26-2022), geraldjust (08-01-2022) |
07-26-2022, 01:33 PM | #7 |
07-26-2022, 01:38 PM | #8 | |
Right behind the manifold, between manifold and PCV. pics coming soon! The head vents are off the front port. |
07-26-2022, 07:44 PM | #9 | |
07-27-2022, 06:39 AM | #10 |
07-27-2022, 06:42 AM | #11 |
Fitment has not been verified yet. Looks similar, but from pics I believe the rear hose size is different? The front routing looks a bit different too. I'm sure it can be installed with some hose/coupler adapters and creativity, but I don't think it's 100% plug-n-play as is.
Function wise, both cars have the exact same PCV layout, so this AOS setup will function and perform the same on a 1st gen too. |
07-27-2022, 02:15 PM | #12 |
Drives: zd8 brz
Any testing on how often it has to be drained?
I know it’s somewhat dependent on the vehicle itself, engine health and how the motor is driven, but most catch can/AoS set ups are a bit larger to allowed for less frequent maintenance and draining |
07-27-2022, 08:50 PM | #13 | |
If the car is built loose, worn, or thought to have a decent amount of blowby, sooner than later would be a good place to start. Maybe as often as you check the oil level. Thankfully, the drain valve on the bottom is pretty easy to drain |
07-27-2022, 08:56 PM | #14 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Wally86 (08-04-2022) |
Similar Threads | ||||
Verus Engineering Air Oil Separator - Information and Release | VerusEric | Engine, Exhaust, Transmission | 127 | 07-08-2023 07:40 AM |
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp | KillerBMotorsport | BRZ Second-Gen (2022+) -- General Topics | 50 | 10-29-2022 07:36 AM |
Killer B Motorsport Carbon Fiber Strut Braces | KillerBMotorsport | Groupbuys | 17 | 10-25-2022 10:05 AM |
FREE Delrin Shift Knob - Killer B Motorsport | KillerBMotorsport | BRZ Second-Gen (2022+) -- General Topics | 56 | 04-27-2022 06:32 AM |
High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 09:51 AM |
