Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: Built FA20
Possible vacuum leak? (Running lean and high fuel trims)
Hi guys. So to preface, I was at a drifting event last weekend when this issue first appeared. After I spun out once the car had trouble starting again (this is kinda normal, so I wasn't worried about it). However, after I exited the track and was looking at some stats like AFR and fuel trims, they went crazy.
Now, almost a week later, the issue has still not resolved itself. My AFR is consistently between ~18 and 20:1 and my fuel trims are +35%. I flashed the stock tune back and the car won't even run right. It will start and then die almost immediately unless I give it gas to keep the RPM's up. I took it to the dealership today but they told me they couldn't do anything until tomorrow morning. So I figured I would ask you guys before actually taking it to them to see if I can figure it out myself. Notes: The car is NOT boosted Using an edited OFT tune MAF is scaled properly |
#2 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Check the Evap line under the intake manifold. I know your not boosted. but my car acted the exact same way when the line popped off.(I am boosted) the line is on very loose from the factory.
797Performance.com
#3 |
Drives: Built FA20
#4 |
Ned flanders
Noo reach your hand under the intake manifold behind the ac compressor and feel around
Sent from my SPH-L720T using Tapatalk
797Performance.com
#5 |
Drives: Built FA20
#6 | |
Ned flanders
Sweet glad I can help...Look out NA guys! everyone needs to clamp them now..I still need to put hose clamps on mine. they come off often.
797Performance.com
#7 |
Drives: 2020 Subaru BRZ (Edelbrock SC)
I apologize for reviving this post but where are each of the locations a vacuum leak can occur? I am going to check the hose behind the AC compressor later today to see if it is my issue. I hear the noise but can't locate where its coming from over the sound of the engine.
My setup has the Edelbrock Supercharger. |
Running a bit lean on WOT pull | Phantobe | Software Tuning | 16 | 06-26-2015 01:41 PM |
Negative Short term fuel trims at idle w/ no obvi leak | IBill4You | Forced Induction | 21 | 05-29-2015 09:49 AM |
Vacuum Leak?? | woode | Forced Induction | 31 | 05-25-2014 04:09 AM |
running lean | EZWood | Engine, Exhaust, Transmission | 26 | 10-18-2013 12:53 PM |
FA20 Fuel lean at high boost fix | cf6mech | Forced Induction | 15 | 05-20-2013 03:33 PM |
