Old 05-16-2013, 05:56 PM   #1
Sniper2606
Sniper2606's Avatar
Q300 v-clamp issue
So not sure if im doing this correct or my v-clamp skills are shit
First i put the clamp like this
Covering the side openings, then i noticed some air was trying to get out but instead it becomes water and residue as you can see on the pic.
So then i tried the clamp like this
This time no water coming out, but tiny air leak coming out, not sure whats the proper way of using this or there is something wrong with the clamp or pipe. The clamp is very very tight.
Any ideas?
I also tried putting the clamp in the middle, but air leak comes out from the side
Sniper2606 is offline   Reply With Quote
Old 05-16-2013, 07:00 PM   #2
TheSlickOne17
Drives: 07 scion tc 06 Evo 9 mr 10 4runner
Maybe try to loosen all the bolts holding the exhaust and re line everything up..
Pipes may have been shifted not lining everything up when you bolted them on tight.
TheSlickOne17 is offline   Reply With Quote
Old 05-16-2013, 07:03 PM   #3
Sniper2606
Sniper2606's Avatar
Tried that, exhaust is perfectly line up.
Old 05-16-2013, 07:15 PM   #4
TheSlickOne17
Did your exhaust come with the lil tube of sealant?
Old 05-16-2013, 07:19 PM   #5
zoomzoomers
zoomzoomers's Avatar
Those don't look like v-bands. They look more like sleeve clamps? Is there a gasket that you're missing?
Old 05-16-2013, 07:44 PM   #6
Sniper2606
Sniper2606's Avatar
This is all i got
No gasket need for that end, the exhaust pipe goes inside that other pipe in the second pic
Old 05-16-2013, 07:47 PM   #7
Sniper2606
Sniper2606's Avatar
Sure didnt
Old 05-16-2013, 08:14 PM   #8
zoomzoomers
Originally Posted by Sniper2606 View Post
This is all i got
Then I suggest applying that sleeve clamp at the very end of the tip you have in the picture above. If you're applying the clamp forward of the end then you might not get a proper seal. Good luck.
Old 05-16-2013, 08:18 PM   #9
TheSlickOne17
Yea that's what was thinkin too.
Hope it works out.
Old 05-16-2013, 08:21 PM   #10
Sniper2606
Sniper2606's Avatar
I did what you suggested, no air leak anymore but, i do still have water coming out when i go WOT or accelerating, not sure if this is normal
Old 05-16-2013, 08:46 PM   #11
mrk1
Drives: Sterling BRZ Ltd
This is a problem with slip fits. Try a longer clamp, something with more surface area. NAPA carries easy seal clamps in various sizes.
A small trickle of water now and them is pretty common. Even with no noticeable exhaust leak.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-16-2013, 09:03 PM   #12
Mikem53
Drives: FR-S 6MT
I used to get water marks from aftermarket exhausts at the connections.. as long as you dont hear any leaks you should be fine..
Mikem53 is offline   Reply With Quote
Old 05-16-2013, 09:31 PM   #13
Sniper2606
Sniper2606's Avatar
I made a video of the exhaust sounds
As you can see there are drips of water.
click on 1080p to see it
[ame="http://www.youtube.com/watch?v=PTn6_Bttt6U&list=UUwpPOt3Y2bj6Fbb2o1UiNag& index=1"]Brz q300 - YouTube[/ame]
Old 05-16-2013, 11:38 PM   #14
zoomzoomers
From what I can see/hear you're solid. As others have said as long as you don't hear an exhaust leak you should be ok. Nice sounding system BTW.
Owners of Invidia Q300 lxsedan Engine, Exhaust, Transmission 59 08-24-2020 11:49 AM
Invidia Q300 vs. Perrin Catback (Non-resonated) Taylor13 Engine, Exhaust, Transmission 26 02-06-2014 07:26 PM
Installing the q300 myself hunter3232792 Engine, Exhaust, Transmission 16 12-08-2013 09:24 AM
Invidia Q300 with Ti Tips seven Engine, Exhaust, Bolt-Ons 23 03-09-2013 01:39 AM
FS: Invidia Q300 Burnt TI Version FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 0 01-16-2013 01:46 AM
