Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 05-13-2014, 01:48 PM   #1
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Tyre/Wheel rotation and wheel alignment for the 86?
Hi,
I have reached 10,000km with my 86, looking to go in for wheel alignment and wheel rotation? Has anyone did this at 10,000km?
If so, do I rotate the current rear 2 tires with the front 2?(Ie. Left Rear to Left Front) (and Right Rear to Right Front)
Or do I cross tires over? (Ie. Right Rear to Left Front)(and Left Rear to Right Front)
Not sure how it works with rear wheel drive cars and the 86...
Also, any recommendations of quality service to do the above in the Gauteng area?
Thanking you in advance for your advise and help
SM
FT_86_SM_GP is offline   Reply With Quote
Old 05-14-2014, 04:12 AM   #2
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
For alignment I can almost guarantee you won't find better then Hein at Autoquip in Centurion.
That being said, I'm on 30k and haven't bothered with alignment or rotation. Tyres are wearing evenly but I will take it to them to double check the alignment.
If the tyres allow(not directional, etc) then cross rotation would be a good idea.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
The Following 2 Users Say Thank You to sav For This Useful Post:
DrSUTRA (05-17-2014), FT_86_SM_GP (05-14-2014)
Old 05-14-2014, 10:57 AM   #3
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
Originally Posted by FT_86_SM_GP View Post
Hi,
SM
From the BRZ Manual 2014
Freedom is offline   Reply With Quote
The Following User Says Thank You to Freedom For This Useful Post:
Old 05-16-2014, 02:57 AM   #4
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
My 2c worth :
- Only rotate tyres to address uneven wear patterns.
- Inspect tyres frequently, especially before and after track sessions, and rotate when necessary.
- Always buy tyres that can be fitted either side, so that you can rotate worn shoulders from outside to inside. Unidirectional is OK, but asymmetrical isn't.
- Some folks don't like rotating from front to back and vice-versa. I don't have a problem with that at all. Just takes a bit of bedding in, and getting used to a different feel.
- If you fit aftermarket wheels, don't go staggered. It's a PITA when it comes to rotation.
YMMV...
After 36000kms of abuse, and camber bolts, my alignment (toe-in) is still perfect - never had to change it.
Fish Eagle is offline   Reply With Quote
The Following 2 Users Say Thank You to Fish Eagle For This Useful Post:
BentAnat (05-16-2014), DrSUTRA (05-17-2014)
Old 05-16-2014, 03:50 AM   #5
sav
sav's Avatar
Originally Posted by Fish Eagle View Post
My 2c worth :
YMMV...
Wise words!
95RON SAV Tuned
The Following User Says Thank You to sav For This Useful Post:
Fish Eagle (05-16-2014)
Old 10-26-2015, 11:44 AM   #6
FT_86_SM_GP
Drives: Lawn moweR
Whiteline Camber bolts install
Installed Whiteline Camberbolts today at Autoquip Fourways
Time:
30mins install
15-30mins wheel alignment
Cost: R450 (Incl VAT) - cost of labor for install and wheel alignment
Camber bolts cost approx R650
Toyota camber bolts cost approx R100 to R200
Purchased from: Pyroperformance CPT
info@pyroperformance.co.za
Summary:
Install went smooth, but after actually reading my alignment, both the manager and myself were confused.
The manager ended up calling @sav for advice on how to install/wheel alignment,
as Sav has a pretty successful set up on his 86,
My wheel alignment went from approx 0 Deg Camber to -1.24 Deg Camber at the FRONT
(Zero Toe)
And (This is where the surprise is) REAR -0.5 Deg on the left and -1.24 Deg right
(Zero Toe)
That's pretty fu$kd up lol
Due to time limitations, I had to leave, but the manager assured me that this difference at the back is negligible, and that the only way they can adjust it is if they shim it.
He said that shimming is not the best long term solution, and they tend to wear out...he recommended I buy an adjustable LCA.
Sav got pretty good results, with -1.4 deg camber at the front and -1 deg camber at the back.
Thanks for the help and advice Sav!
I am going to do some research on shimming to get camber and probably go in the weekend to get my right rear camber sorted.(From -0.5 to -1.1)
Take away from my experience today: Our 86's are bloody skew
Here are some pics:
1) Wheel alignment results AFTER camber bolts Vs BEFORE camber bolts
2) Wheel alignment reading of REAR skew camber
Name:  Monitor Wheel Alignment.JPG
3) How the FRONT looks with -1.2deg camber
4) Pics compliments of @sav and @LostSalad who installed these Camberbolts themselves, Respect
Last edited by FT_86_SM_GP; 10-26-2015 at 12:03 PM. Reason: Added more accurate pricing
The Following 4 Users Say Thank You to FT_86_SM_GP For This Useful Post:
Alang (10-27-2015), Dammod (10-27-2015), LostSalad (10-26-2015), sav (10-27-2015)
Old 10-26-2015, 12:16 PM   #7
LostSalad
Drives: Toyota 86 - Charcoal Grey
@FT_86_SM_GP
Thanks for the in depth writeup man! This is actually really useful for other guys that want to do camber bolts.
I haven't actually done mine yet - but I've gone and made sure I have all the right sockets. It's a touch nerve wracking because I'm new to the game and haven't ever touched suspension components before. But, like the brake discs, whether it's your arm tightening the wrench or some other guy's, the result still ends up the same. Also 160 Nm is hella tight, so if I torque it down according to spec, I really doubt the wheels will come off.
EDIT: wanted to add - how does it feel? Anything noticeable on the roads?
LostSalad is offline   Reply With Quote
Old 10-26-2015, 01:54 PM   #8
FT_86_SM_GP
Drives: Lawn moweR
Originally Posted by LostSalad View Post
@FT_86_SM_GP
Yeah agreed, this 'mod' is def worth it, if guys buy it for +-R100 from Toyota, its one of those mods like Upgrading brake fluid which is simple, but benefits out weighs cost.
Didn't really notice any difference at the moment, planning on either Zwartkops or Midvaal this weekend, so will test out the handling there and provide feedback
Old 10-26-2015, 02:12 PM   #9
Fish Eagle
Platinum Member
Fish Eagle's Avatar
It should help a bit with turn-in, should reduce understeer a bit, should drive a bit worse on the highway (different feel), but the most important thing is that it will save you a lot of money with tyres if you track your car. Some negative camber up front dramatically reduces shoulder scrubbing and wear.
Did I see Midvaal in your post?
The Following User Says Thank You to Fish Eagle For This Useful Post:
FT_86_SM_GP (10-26-2015)
Old 10-26-2015, 02:27 PM   #10
FT_86_SM_GP
Drives: Lawn moweR
Lol Yes Sir,
Would be great to try out Midvaal before the year ends
Just need to sort out some logistics and check if the trip will be possible
Old 10-27-2015, 03:01 AM   #11
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Lol Yes Sir,
Midvaal is available on Saturday 31st, but the circuit will be closed on Sunday 1st due to a drag racing meet. Pity...
Old 10-27-2015, 03:41 AM   #12
sav
sav's Avatar
Cool stuff FT_86_SM_GP , glad I could help.
Turn in definitely feels better/sharper.
95RON SAV Tuned
Old 11-04-2015, 02:46 AM   #13
Fish Eagle
Platinum Member
Fish Eagle's Avatar
The most economic method of rotating tyres:
Old 11-04-2015, 02:50 AM   #14
sav
sav's Avatar
Cool, just make sure your tyres are not directional, inside/outside.
95RON SAV Tuned
WTB: GTS wheel and tyre SYDNEY Toyota 86 GT Australia Classifieds 0 03-29-2014 12:15 AM
Wheel + tyre weight diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-30-2013 12:16 PM
WTB - GTS / BRZ 17" Genuine wheel & tyre in Melbourne VIC ZZT86 Australia Classifieds 5 06-20-2013 09:10 PM
LIST: Non-rubbing 17" wheel & tyre packages ft_sjo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-28-2013 06:56 AM
16" Spare wheel and tyre MACCAA Australia Classifieds 1 02-02-2013 05:35 PM
