Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-28-2022, 01:04 PM | #1 |
Financial Distress
Drives: 2017 GT86 325WHP
Coilover Ball Joint Bolt
Looking for some insight on this, it's limited to find online as far as I've found:
The singular, main bolt at the top center of the coilover I found to be a tad loose when I checked it (Was diagnoing a clunk noise from the front). I've looked online and found that ~40ft/lbs is an average torque spec for where that top bolt needs to be tightened down to, however I was wondering if there were any coilover gurus here that want to chime in on what the correct process is to get this at proper tightness. Should I just be torquing the bolt as is, or do I need to use a wrench to hold the assembly in place during this? Hoping someone might have some more insight than me, weird subject. Coilovers: HKS Hypermax GTIV Thank you UPDATE: You're all super helpful, appreciate the responses. Last edited by scottryan; 07-30-2022 at 05:13 PM. |
07-28-2022, 01:31 PM | #2 |
Drives: '13 FRS - STX
Yes you will need to hold the damper body to prevent it from rotating.
I do 3 uga-dugas on an impact driver per vorshlags suggestion. |
07-28-2022, 07:41 PM | #3 |
I am sorry but the correct way is to hold it with an alien wrench and torque the nut with a torque wrench.
FYI I did use an impact on mine it is easier. |
The Following User Says Thank You to Grady For This Useful Post: | scottryan (07-30-2022) |
07-28-2022, 08:03 PM | #4 |
Drives: Subaru BRZ
Also, set the compression/rebound adjuster in the middle before you use the impact.
The Following User Says Thank You to Code Monkey For This Useful Post: | scottryan (07-30-2022) |
07-29-2022, 12:54 AM | #5 | |
Drives: 86 GT
DIY stuff at Compelica Works
07-30-2022, 05:12 PM | #6 |
Financial Distress
Had a little clunk, tightened the top nut (I had a hunch because when I had them off, the ball joint felt loose, easy to spin the top) So I tightened to 40ft/lbs and zero clunk now.
The Following User Says Thank You to scottryan For This Useful Post: | Compelica (07-31-2022) |
07-30-2022, 05:30 PM | #7 | |
Drives: Crapcan
It’s pretty common with aftermarket camber plates. That or the sway bar end link is loose. I check mine multiple times a year.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | marco_mc22 (07-30-2022) |
Similar Threads | ||||
ball joint leak | msaikhan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 05-01-2019 11:17 AM |
Tie rod ball joint stuck | Killianti | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 07-19-2015 10:32 PM |
Ball Joint Replacement, The fun way. | FRSPacNW | DIY (Do-It-Yourself) Guides | 2 | 06-28-2014 03:04 AM |
Front ball joint dimensions | J-W | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-02-2013 05:31 PM |
loose ball joint | Grip Ronin | Issues | Warranty | Recalls / TSB | 15 | 07-09-2013 01:16 PM |
