Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
11-21-2020, 07:37 PM | #1 |
Drives: 2017 Toyota 86
Drivers window not going up
Weird problem in my 86 - the drivers side window goes down but not back up. Its not the motor - I can jump power to it and make it go up. Not the switch - tried a replacement. It even goes down when the window lock is switched on. Is this in like an emergency mode or something? I have other problems with the car as well.
11-21-2020, 07:53 PM | #2 |
Drives: Subaru BRZ
Common problem. Mine freaked out after i tried to wind it down with a gopro mount attached to the window! Have a look on youtube for videos on how to reset it. Dont stress, its an easy fix.
Sent from my SM-G973F using Tapatalk |
The Following User Says Thank You to Purist For This Useful Post: | Robcokiwi (11-21-2020) |
11-22-2020, 03:02 PM | #3 | |
(well, at least you admitted it - ) |
11-22-2020, 03:05 PM | #4 |
Mine does it about 5 times a year when I am overly optimistic that the ice has melted enough to roll it down at the coffee drive through.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (11-22-2020), soundman98 (11-22-2020) |
11-22-2020, 03:57 PM | #5 |
How could you not tell -
11-22-2020, 04:44 PM | #6 |
Ok what I find on Youtube is the problem with cold. It is still 74 degrees here. I don't have lights flashing on the buttons - I have no lights.
11-22-2020, 04:55 PM | #7 | |
Drives: Subaru BRZ
My lights weren't flashing either, and I had no response from the window at all, neither up nor down. The light on the passenger's side was off. There seem to be a few variations on this theme, depending on what caused the fault, and I've found a few versions of the long hold reset but they all seem to work. Sent from my SM-G973F using Tapatalk Last edited by Purist; 11-22-2020 at 05:13 PM. |
11-22-2020, 06:12 PM | #8 |
If it is not a reset or relearn problem.
I know this sounds stupid but. I hold the switch and hit the inside of the door below the arm rest with my fist. I learned this trick with my Mini. |
The Following 2 Users Say Thank You to ls1ac For This Useful Post: | humfrz (11-22-2020), soundman98 (11-22-2020) |
11-22-2020, 11:56 PM | #9 |
Oh, that trick has been around for many years for many things. If that doesn't work, hit it with a large rubber hammer -
11-24-2020, 10:21 AM | #10 |
Exactly how I fixed the squeaks and creaks in my dash!
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (11-24-2020), soundman98 (11-24-2020) |
11-24-2020, 12:02 PM | #11 |
Reminds me of the time during a really cold winter night in Connecticut. I was leaving a holiday party in my pristine 1970 MGB-GT, pretty well liquored up when the dash started squeaking. I gave it a big ol rap with my cold, drunken fist and it quit squeaking.
The next day I noticed a broken open, long, crack in the dash - |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
11-24-2020, 12:23 PM | #12 | |
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
11-24-2020, 01:29 PM | #13 |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (11-24-2020), Tcoat (11-24-2020) |
11-27-2020, 07:29 PM | #14 |
I think I have tried every method I can find on Youtube and still not fixed. My indicator lights on the window switch buttons are flashing. The drivers side switch only controls the drivers side window, the passenger side switch will work the passenger side window. But they will only work if the doors are closed. Pressing the down button to the first step will take them down, pressing them to the second will take them down but not on the auto function. They will only go up when you pull the button all the way to the second step - and that will not function on auto. I can live with all this but when I open the door to get out the window drops down a little and when I close it it doesn't go back up. Just as an informational note I did change all the wiring looms and switches in the car as it had been flooded, but if the windows go up and down I am pretty sure it is in the programming. An more tips would be appreciated
Similar Threads | ||||
Cant find passenger window wire from drivers side remote.. help? | luv85 | Electronics | Audio | NAV | Infotainment | 2 | 11-03-2020 09:13 AM |
Drivers side window glass | Akuma13 | Want-To-Buy Requests | 2 | 05-23-2017 12:25 AM |
Drivers window grabbing window seal and pushing it up. | stockysnail | Issues | Warranty | Recalls / TSB | 22 | 12-22-2015 01:08 PM |
Drivers window switch flashing - does nothing? | STS-V | Issues | Warranty | Recalls / TSB | 4 | 08-11-2014 08:42 AM |
Drivers Side Window (Not Seal) | Mister | Issues | Warranty | Recalls / TSB | 20 | 12-16-2013 02:56 PM |
