05-19-2017, 07:50 PM | #1 |
Drives: 2013 pearl white FR-S
just wow
called up 2 places to see how much it'll cost to change the tranny and diff fluid.. one quoted me $195 with fluid and the other $135 labor only...
guess i'm gonna DIY it |
05-19-2017, 08:26 PM | #2 |
Weight Weenie
Drives: 15 FR-S
05-19-2017, 08:48 PM | #3 |
Drives: 2017 manual BRZ
Damn. That for a 30 minute job. DIY it up.
Sent from my Pixel XL using Tapatalk |
05-19-2017, 09:02 PM | #4 |
I just did this today. It's not a 30min DIY.
In the shop, with a lift, I can see it taking 30 min if the tech is fast. |
05-20-2017, 12:37 AM | #5 |
Drives: Scion FR-S Series 10 #2462
That's the first thing I did to my car, tranny & diff fluid. It's not hard to do but don't forget new crush washers, and I just used Subaru fluid for the diff and AMSOIL for the tranny. You need a way to get the fluid into the fill holes, so some kind of fluid pump is required. Can't just pour it in. I have one of these:
05-20-2017, 02:31 AM | #6 |
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
Thats nothing. The fluid flush is done in such a specific way on the AT that it costs about 400 and a few hours of your life at the dealer for the change.
05-20-2017, 02:38 AM | #7 |
Off Topic
Do you have a jack, jack stands, and a drain pan? It isn't a difficult DIY. There are threads in the DIY section for it. Motul bottles have a spout; other bottles will need a pump of some sort.
Cost breakdown: 4 qts Motul 300: $80 2 diff crush washers: ~$5 1 hour labor If you already have all the tools, that's it. Also, the trans fluid comes out sideways. If you aren't prepared it can get messy. |
05-21-2017, 10:46 PM | #8 |
Drives: 2013 Supercharged BRZ, E85, Ohlins
FYI Mine took ~1.5h on a garage floor w/ jackstands. Hardest part was getting the car level front to back and side to side in a non-level garage.
This is not a hard DIY - Just follow the steps. You will be proud of yourself when you are done |
05-22-2017, 11:59 AM | #9 |
yeah, i was already planning on working on it myself after reading thru the DIY... it's basically a drain and fill... i didn't think shops would be charging that much to remove 4 bolts haha
