View Single Post
Old 11-05-2012, 12:02 AM
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Stock Mud Guard Install DIY (BRZ & FR-S)
This DIY guide will walk you through installing the stock mud guards on your BRZ/FR-S. These can be purchased @ any Scion dealer for around $65. The part number is PU060-18013-P1
Proceed at your own risk, I'm not responsible for any harm to yourself or your car that occurs while following this guide. Always be careful when under a motor vehicle, ensure it is properly supported at all times.
HERE IS THE STOCK PDF: BRZ Mudguard Installation Guide.pdf
Equipment required:
19mm socket for lug nuts (lug key if needed)
Breaker bar with 3" extension
Torque wrench
Bone tool (or flat head screwdriver for prying)
#2 Phillips screwdriver
5/16" drill bit (or 8mm)
Electric drill
Floor jack
Jack stands (x2)
Wheel Chocks
What's included w/the Mud Guards
FRONT INSTALL PROCEDURE
NOTE:
- Ensure the car is in gear and parking brake engaged.
- The first step is to break loose the lug nuts on the front wheels. Use a breaker bar, as most torque wrenches should not be used to untorque nuts.
- Next, jack up the front of the car.
NOTE:
- I recommend using a set of jack pads like these, got them @ Harbor Freight for $8
NOTE:
- Ensure all tools have been removed from underneath vehicle
- Install the lug nuts to finger tightness while wheel is in the air
- Once on the ground, torque lugs in a star pattern to 89 ft-lbs
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
The Following 23 Users Say Thank You to JonnyRocket For This Useful Post:
Anthonytpt (01-30-2013), BareZ (01-15-2016), Ben_G (11-12-2012), BirdTRD (10-26-2013), bpracer (12-24-2012), CA2 (01-14-2013), cheesesteak (04-16-2014), chenshuo (03-04-2013), ChiefG (03-31-2014), chimmay (11-06-2012), CoolBReeZe (01-08-2014), CoRi J (11-22-2012), evil_1998 (04-13-2013), FRSGT86 (09-15-2013), jcw99 (03-06-2016), JPxM0Dz (11-05-2012), Khyron686 (05-05-2013), Overdrive (01-10-2017), shyong (02-13-2013), Stierzy34 (08-16-2013), Suberman (08-24-2013), tanner (06-09-2014), tk1138 (03-04-2016)
