help on ZA1JK00D 2017
dear
plz i need help to install stage2 oft rom throw tactric openport 2.0 (ecuflash) i need defination files and xml for ecuflash thnx |
CLID : ZA1JK00D
K00D is not defined ie no definitions. Use K01I as a substitute rom Or just create a flash only definiton for the K00D or K01I |
Creating a bare bones definition for flashing a ROM with no existing definition
Useful if your car has old ROM not defined and you want to try update and be able to flash back to old ROM or you have pulled really new ROM from a car and no definition yet. Open the rom with no definition in Ecuflash, it will tell you it does not have a definition, do you want to create one. You press yes, and then click on from scratch. Then you choose SH72531 under memory module, and Subarubrz flashing method. The unique identifier is at 8000 and 8 bytes long. Fill the rom info in with the year, model etc. - not critical that this is accurate if you're just using it to flash. Click Finish, and when you're back in Ecuflash, click on file, and 'Save Models'. This should allow you to flash ROM but not edit as no tables defined. |
thnx steve can u send me xml K01I? thnx |
2 Attachment(s)
see attached flash only defs need to be unzipped and placed in C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\subaru\BRZ\2017 folder |
dear its open by ecuflash but no tables can i download it now to the car ?? https://imgur.com/viKcYfG https://imgur.com/viKcYfG https://imgur.com/viKcYfG |
I cannot see images
Those definition for ecuflash are flash only definitions. You cannpt see tune tavles, jist allows flashing of file to ecu. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
