Will this exhaust be loud enough?
What can i do to get dat subie rumble? can u summarize the manual? |
"This used to be a great site but it has been ruined by Tcote and his ilk with their stupid, juvenile comments and pictures!"
http://www.thedukesmusic.com/wp-cont...ry-blogger.jpg |
Op: Mar 1st, 2012 - My window won't work
Reply: Mar 1st, 2012 - There is a TSB take it in Last post: Mar 3rd 2012 - All fixed it took them 20 minutes Noob: Feb 12 2015 - I have this problem too! |
I want to cover my car with stickers for products I don't own and race teams I am not part of where are the best places to buy them?
100 posts later How do I delete this thread you guys are all just assholes! |
Heeeeey....wait a second here @Koa! Isn't this thread "clutter"?Not complaining I love it but...
http://s2.quickmeme.com/img/22/22f18...f7b634b25d.jpg |
http://otisblank.com/wp-content/uplo...45-EDIT-RS.jpg And because this is the current "lol n00bs asking for more powah thread" Here's a Lotus forum talking about how overhyped their cars were in 2006... http://www.lotustalk.com/forums/f3/w...rselves-25212/ |
"This car is FAST!"
in the corners |
Stock tires SUCK.
Stock tires are AWESOME. Stock tyres SUCK. Stock tyres are AWESOME. You will frag your gearbox or crash unless you double-clutch and rev match. There is absolutely no reason to double-clutch or rev match. |
OP:
"I am new to driving manual what should I know?" Reply: "The simplest example of a gear train has two gears. The "input gear" (also known as drive gear) transmits power to the "output gear" (also known as driven gear). The input gear will typically be connected to a power source, such as a motor or engine. In such an example, the power output of the output (driven) gear depends on the ratio of the dimensions of the two gears. The teeth on gears are designed so that the gears can roll on each other smoothly (without slipping or jamming). In order for two gears to roll on each other smoothly, they must be designed so that the velocity at the point of contact of the two pitch circles (represented by v) is the same for each gear. Mathematically, if the input gear GA has the radius rA and angular velocity http://upload.wikimedia.org/math/3/0...eae301528e.png, and meshes with output gear GB of radius rB and angular velocity http://upload.wikimedia.org/math/9/c...8fe169433c.png, then: http://upload.wikimedia.org/math/5/3...eee88559f2.pngThe number of teeth on a gear is proportional to the radius of its pitch circle, which means that the ratios of the gears' angular velocities, radii, and number of teeth are equal. Where NA is the number of teeth on the input gear and NB is the number of teeth on the output gear, the following equation is formed: http://upload.wikimedia.org/math/6/2...a4162eeabd.pngThis shows that a simple gear train with two gears has the gear ratio R given by http://upload.wikimedia.org/math/7/7...b09c15d715.pngThis equation shows that if the number of teeth on the output gear GB is larger than the number of teeth on the input gear GA, then the input gear GA must rotate faster than the output gear GB. Gear teeth are distributed along the circumference of the pitch circle so that the thickness t of each tooth and the space between neighboring teeth are the same. The pitch p of a gear, which is the distance between equivalent points on neighboring teeth along the pitch circle, is equal to twice the thickness of a tooth, http://upload.wikimedia.org/math/4/0...9b0dff3aa2.pngThe pitch of a gear GA can be computed from the number of teeth NA and the radius rA of its pitch circle http://upload.wikimedia.org/math/a/e...06459a455d.pngIn order to mesh smoothly two gears GA and GB must have the same sized teeth and therefore they must have the same pitch p, which means http://upload.wikimedia.org/math/c/0...5428cd7370.pngThis equation shows that the ratio of the circumference, the diameters and the radii of two meshing gears is equal to the ratio of their number of teeth, http://upload.wikimedia.org/math/6/0...f5d51eb121.pngThe speed ratio of two gears rolling without slipping on their pitch circles is given by, http://upload.wikimedia.org/math/7/1...62e7bcddb0.pngtherefore http://upload.wikimedia.org/math/7/7...b09c15d715.pngIn other words, the gear ratio, or speed ratio, is inversely proportional to the radius of the pitch circle and the number of teeth of the input gear. A geartraincan be analyzed using the principle of virtual work to show that its torque ratio, which is the ratio of its output torque to its input torque, is equal to the gear ratio, or speed ratio, of the gear train. This means that the input torque ΤA applied to the input gear GA and the output torque ΤB on the output gear GB are related by the ratio http://upload.wikimedia.org/math/d/4...74a6e6cc97.pngwhere R is the gear ratio of the gear train The torque ratio of a gear train is also known as its mechanical advantage http://upload.wikimedia.org/math/3/b...a866c0ae53.pngIn a sequence of gears chained together, the ratio depends only on the number of teeth on the first and last gear. The intermediate gears, regardless of their size, do not alter the overall gear ratio of the chain. However, the addition of each intermediate gear reverses the direction of rotation of the final gear. An intermediate gear which does not drive a shaft to perform any work is called an idler gear. Sometimes, a single idler gear is used to reverse the direction, in which case it may be referred to as a reverse idler. For instance, the typical automobile manual transmission engages reverse gear by means of inserting a reverse idler between two gears. Idler gears can also transmit rotation among distant shafts in situations where it would be impractical to simply make the distant gears larger to bring them together. Not only do larger gears occupy more space, the mass and rotational inertia of a gear is proportional to the square of its radius. Instead of idler gears, a toothed belt or chain can be used to transmit torque over distance. If a simple gear train has three gears, such that the input gear GA meshes with an intermediate gear GI which in turn meshes with the output gear GB, then the pitch circle of the intermediate gear rolls without slipping on both the pitch circles of the input and output gears. This yields the two relations http://upload.wikimedia.org/math/f/0...fd905ba3c4.pngThe speed ratio of this gear train is obtained by multiplying these two equations to obtain http://upload.wikimedia.org/math/7/7...b09c15d715.pngNotice that this gear ratio is exactly the same as for the case when the gears GA and GB engaged directly. The intermediate gear provides spacing but does not affect the gear ratio. For this reason it is called an idler gear. The same gear ratio is obtained for a sequence of idler gears and hence an idler gear is used to provide the same direction to rotate the driver and driven gear, if the driver gear moves in clockwise direction, then the driven gear also moves in the clockwise direction with the help of the idler gear. Assuming that smallest gear is connected to the motor, it is the driver gear. The somewhat larger gear on the upper left is called an idler gear. It is not connected directly to either the motor or the output shaft and only transmits power between the input and output gears. There is a third gear in the upper-right corner of the photo. Assuming that that gear is connected to the machine's output shaft, it is the output or driven gear. The input gear in this gear train has 13 teeth and the idler gear has 21 teeth. Considering only these gears, the gear ratio between the idler and the input gear can be calculated as if the idler gear was the output gear. Therefore, the gear ratio is driven/driver = 21/13 ≈1.62 or 1.62:1. This ratio means that the driver gear must make 1.62 revolutions to turn the driven gear once. It also means that for every one revolution of the driver, the driven gear has made 1/1.62, or 0.62, revolutions. Essentially, the larger gear turns more slowly. The third gear in the picture has 42 teeth. The gear ratio between the idler and third gear is thus 42/21, or 2:1, and hence the final gear ratio is 1.62x2≈3.23. For every 3.23 revolutions of the smallest gear, the largest gear turns one revolution, or for every one revolution of the smallest gear, the largest gear turns 0.31 (1/3.23) revolution, a total reduction of about 1:3.23 (Gear Reduction Ratio (GRR) = 1/Gear Ratio (GR)). Since the idler gear contacts directly both the smaller and the larger gear, it can be removed from the calculation, also giving a ratio of 42/13≈3.23. The idler gear serves to make both the drive gear and the driven gear rotate in the same direction, but confers no mechanical advantage. Automobile drivetrains generally have two or more major areas where gearing is used. Gearing is employed in the transmission which contains a number of different sets of gears that can be changed to allow a wide range of vehicle speeds, and also in the differential, which contains the final drive to provide further speed reduction at the wheels. In addition, the differential contains further gearing that splits torque equally between the two wheels while permitting them to have different speeds when travelling in a curved path. The transmission and final drive might be separate and connected by a driveshaft or they might be combined into one unit called a transaxle. The gear ratios in transmission and final drive are important because different gear ratios will change the characteristics of a vehicle's performance. A 2004 Corvette with a six-speed manual transmission has the following gear ratios in the transmission: GearRatio1st gear2.97:12nd gear2.07:13rd gear1.43:14th gear1.00:15th gear0.84:16th gear0.56:1reverse3.38:1In 1st gear, the engine makes 2.97 revolutions for every revolution of the transmission’s output. In 4th gear, the gear ratio of 1:1 means that the engine and the transmission's output rotate at the same speed. 5th and 6th gears are known as overdrive gears, in which the output of the transmission is revolving faster than the engine's output. The Corvette above has an axle ratio of 3.42:1, meaning that for every 3.42 revolutions of the transmission’s output, the wheels make one revolution. The differential ratio multiplies with the transmission ratio, so in 1st gear, the engine makes 10.16 revolutions for every revolution of the wheels. The car’s tires can almost be thought of as a third type of gearing. This car is equipped with 295/35-18 tires, which have a circumference of 82.1 inches. This means that for every complete revolution of the wheel, the car travels 82.1 inches (209 cm). If the Corvette had larger tires, it would travel farther with each revolution of the wheel, which would be like a higher gear. If the car had smaller tires, it would be like a lower gear. With the gear ratios of the transmission and differential, and the size of the tires, it becomes possible to calculate the speed of the car for a particular gear at a particular engine RPM For example, it is possible to determine the distance the car will travel for one revolution of the engine by dividing the circumference of the tire by the combined gear ratio of the transmission and differential. http://upload.wikimedia.org/math/6/f...ae7c304178.png It is also possible to determine a car's speed from the engine speed by multiplying the circumference of the tire by the engine speed and dividing by the combined gear ratio. http://upload.wikimedia.org/math/3/1...982ceac61a.png GearDistance per engine revolutionSpeed per 1000 RPM1st gear8.1 in (210 mm)7.7 mph (12.4 km/h)2nd gear11.6 in (290 mm)11.0 mph (17.7 km/h)3rd gear16.8 in (430 mm)15.9 mph (25.6 km/h)4th gear24.0 in (610 mm)22.7 mph (36.5 km/h)5th gear28.6 in (730 mm)27.1 mph (43.6 km/h)6th gear42.9 in (1,090 mm)40.6 mph (65.3 km/h) Close-ratio transmissions are generally offered in sports car, motorcycles, and especially in race vehicles, where the engine is tuned for maximum power in a narrow range of operating speeds, and the driver or rider can be expected to shift often to keep the engine in its power band Factory 4-speed or 5-speed transmission ratios generally have a greater difference between gear ratios and tend to be effective for ordinary driving and moderate performance use. Wider gaps between ratios allow a higher 1st gear ratio for better manners in traffic, but cause engine speed to decrease more when shifting. Narrowing the gaps will increase acceleration at speed, and potentially improve top speed under certain conditions, but acceleration from a stopped position and operation in daily driving will suffer. Range is the torque multiplication difference between 1st and 4th gears; wider-ratio gear-sets have more, typically between 2.8 and 3.2. This is the single most important determinant of low-speed acceleration from stopped. Progression is the reduction or decay in the percentage drop in engine speed in the next gear, for example after shifting from 1st to 2nd gear. Most transmissions have some degree of progression in that the RPM drop on the 1-2 shift is larger than the RPM drop on the 2-3 shift, which is in turn larger than the RPM drop on the 3-4 shift. The progression may not be linear (continuously reduced) or done in proportionate stages for various reasons, including a special need for a gear to reach a specific speed or RPM for passing, racing and so on, or simply economic necessity that the parts were available. Range and progression are not mutually exclusive, but each limits the number of options for the other. A wide range, which gives a strong torque multiplication in 1st gear for excellent manners in low-speed traffic, especially with a smaller motor, heavy vehicle, or numerically low axle ratio such as 2.50, means that the progression percentages must be high. The amount of engine speed, and therefore power, lost on each up-shift is greater than would be the case in a transmission with less range, but less power in 1st gear. A numerically low 1st gear, such as 2:1, reduces available torque in 1st gear, but allows more choices of progression. There is no optimal choice of transmission gear ratios or a final drive ratio for best performance at all speeds, as gear ratios are compromises, and not necessarily better than the original ratios for certain purposes. __________________ Racecar spelled backwards is Racecar, because Racecar. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
