Bill |
Alrighty... Now that I'm getting serious abt starting the real prep of the car--I completely forgot abt one area that'll affect my tire choice--contingency!
I've been very fortunate to have won many pairs (no sets though! :bonk:) of Hoosiers, so I'd like to run a tire that pays. Without going to the SCCA site--what are the top choices? I don't think the Hankooks pay? |
It changes every year, so I don't think the full list of who is renewing/not renewing/adding has not been published yet... but in 2012 there was tire contingency for:
ProSolo: Toyo Hoosier Kumho National Tour: BFG Toyo Hoosier Kumho National Championships: BFG Hankook Toyo Goodyear Hoosier Kumho I have not seen mention yet if they have any sponsorship and who those may be for the Match Tours. |
http://www.scca.com/solo/content.cfm?cid=44518
Toyo is the only real one that does for us these days and in our sizes, they suck. EDIT: Hankook did play nicely for Nationals though. |
Clarify for me on strut tower braces:
What is the stock setup considered, 2 point or 3 point? If I replaced the stock setup with a set of bars that mounted in the same way (like on Perrin's SEMA car), I would be okay? What about a bar like the Hotchkis one? http://www.hotchkis.net/scion-frs-su...wer-brace.html Would that not be okay? |
Allowed/Recommended?:
- Suspension bushings, particularly offset bushes? - Roll centre correction bushings? - 16 inch rims, given that the car comes with 16s in other markets? - Lightweight battery? - Camber plates? - Camber asjustable a-arms? Also curious to see how these cars stack up in STX as wellmas time-wise versus the S2Ks and Miatas in other non-Mod classes given that STX seems to allow the tires and suspension limitations on the ZN6 to be 'fixed' (if not the power). Disclaimer: I don't autoX in the US, I simply use you guys to R&D effective stuff to help get an edge in AutoX where I am. |
I believe all you have listed above is ST legal except the A-arms, but the ST* competitors should be the ones to answer, as I don't know the ST* rule set as well as I do SP* and Stock. |
You can only have one camber adjustment I believe so the top hats AND a-arms would not be legal on front and frankly there is no need. You could do the LCA on the rear for camber adjustment which is fine and preferred IMO. The Roll center correction is likely not legal I believe below SM as geometry changes of that type are not allowed in ST if I remember correctly. Basically KW's with -.5 top hats I was able to get -3 camber easily which should be about all you would need if you get the spring rate and front sway bar right. rear I was at -1.8 and it seemed about right for starters though time would tell on that one.
Bill |
It looks to me like a direct bolt-on replacement like the Hotchkiss bar is legal, bolt-on mount in original mounting location. Others may work if they mount in the same place as stock, but you can make new bolt holes to attach them. That is my read. Interested to hear others interpretations.
Just stimulating thought.. Bill |
Technically the Hotchkis is a 4-point bar. |
I would say that the replacement of the stock locations would be okay no matter what, i.e. stiffer bars that are after market, just replacing the stock locations. The addition of a cross-bar is the real decision, and I don't know what to think. |
My 2c, I think there are better ways to spend your money.
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
