There goes my plan to install a lighter fly-wheel, lest the dealer claims any problem with the transmission/clutch is caused by an after-market fly-wheel. (Even though that should not be related.)
My trans rattles in all gears especially when cold then it goes away then it comes back once in a while sometimes I hear a clicking sound when I step on the gas
Do I need new fluid or a new trans :/ |
I only have this noise if I'm taking off in 2nd at a very low speed like 6mph. 47,000 miles so far
I find it some what amazing how quick everyone is to assume the OP is in some fashion or another ignorant. This is common on this forum when involving threads like this. I will give you that we all have different definitions of "Low RPM" vs "High RPM" and can tell you that to me, "Low RPM" is anything below 1000. This is because we have 6 gears and at around 45mph (Typical city speed limit) the vechile sits between 1-2k and is not higher than 2000. This range, to me, is "Light load" or "cruising" range.
I get these are entry level sports cars which have perks and quarks but assuming somone else is completely ignorant isn't effective at all. This is especially true since his 2nd paragraph starts with him announcing he's done research. Now, like another user said, I have 17,8-- on my vehicle. No rattle, thank god. I've had other weird issue occur such as a radiator exploding which resulted in the dealership claiming to pull driving habits from ECU. Weather or not they actually can, I don't care. I knew I was not pushing the car and the vehicle was still just a babe so I wasn't even spirited with her yet. Also, as was stated, the clutch housing is bolted to the flywheel, which sits on the back end of the motor. The clutch disk rides on a splined stub shaft that sticks out from the transmission, this stub shaft is inserted into the clutch assembly, specifically into the disk, and is (when properly installed) done most commonly using a special tool that simulates this shaft to ensure proper fitment and alignment, and in no way should the clutch disk ever be able to "rattle" on the input shaft. If the disk itself is rattling, it was poorly installed in the first place. |
Mine has done it since day one, and I'm up to 22K miles. This was a common noise in the British sports cars I grew up with, so the car sounded normal to me. My Triumph made this sound, even after I had replaced the clutch once and had the engine and transmission out of it twice and had realigned the clutch both times with the proper alignment tool. To be honest, the sound is so normal to me that I didn't even realize the BRZ was making it until I saw people on here complaining about it. Then I listened and realized it had been there there whole time. And then I kept driving. I really do want to know what the techs say is "wrong" with the transmission they're removing and whether the sound returns with the new transmission. If it doesn't come back, I suspect that's more a function of luck than anything to do with parts or installation. |
Apparently the dealerships in livermore are very eager to work on these transmissions. When I was travelling to CA I called up the Livermore subaru dealership and wanted to see if they were interested in checking my clutch out, and they were absolutely cool with it. I never went in there for service however, kept travelling instead. |
How many posts are there on this forum where somebody says "I have a noise, what is wrong?" instead of taking it someplace where they, (A) can actually hear it and (B) do something about it! Granted there are some common problems where if the poster actually gives enough info somebody here might guess right but I bet a whole lot more miss info goes out then any thing with true value. On the other hand there are some truly ignorant posters that only want to reinforce what they already believe and won't listen to anybody else or are just looking to blame somebody else for something they screwed up themselves! |
I tried to take mine to the dealer for it but it stopped chattering when i got there. Epic fail.. They did nothing for me
I was right at home when I got my FRS in hearing the clutch "rattle".
The lack of insulation and the transmission being right there close And personal like lets you hear things you don't in other cars.. Those coming from fwd cars with manuals are isolated from the trans noise As well as cars that are muted with more insulation and more isolation from the engine components. There were threads on the corvette forum about this same sound. Some say the springs on the clutch disc are the culprit as they vibrate.. Other say it's the throw out bearing itself.. Some say gears.. Who knows.. I've had similar sounds under the same conditions in my other cars and never Experienced a problem over years of use.. Quote:
Ya it does suck when you know there is a problem and it won't do it when you try to show them. The only issue I have had at all (8000kms and still no crickets fingers crossed) was the window squeal when it was wet. Took it in the rain, hosed it down when I got there, poured water down the door seal and NOTHIN! Drive 2 blocks away put the window up SQUEEEEEEAL. |
Interested to hear more. I too have the same rattling. I only notice it when starting from a stop and disengaging the clutch below 1K.
Poster asks OP to describe what is meant by 'low rpm' and offers his own experience OP launches into a tirade about his 'experience' I'll bet you every person on the planet has a story where somebody launches into "I know what I'm doing mode" only to be proven wrong at a later date. When you put a claim out there be prepared to answer questions about your claim otherwise you're going to have a bad time on the internet. Nobody here meant to imply the OP is 'ignorant' we're all just trying to understand the car better. :cheers: |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
