follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Members List
Calendar
Search
Today's Posts
Mark Forums Read
Search Forums
Search Results
Page 1 of 5
1
2
3
4
5
Showing results 1 to 30 of 128
Search took
0.31
seconds.
Search:
Posts Made By:
Draco-REX
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
05-18-2017, 06:29 PM
350
New Gram Lights 57CR!! *5-Spoke*
244,714
Posted By
Trudat02
Yep. I got some 18x9.5 with a +38 offset and they...
Yep. I got some 18x9.5 with a +38 offset and they fit over the brembo's that came on my 17 BRZ PP.
Forum:
Forced Induction
12-18-2015, 11:59 AM
433
F/I Blowing motors facts
102,369
Posted By
Jaden
If that had been what you said....
If that had actually been what you said, then there wouldn't be umpteen pages here.
No what you said was, rods suck, tunes don't matter...rods are gonna fail...shut up about bad tunes...
When...
Forum:
Forced Induction
12-04-2015, 11:40 AM
123
Pop goes the BRZ. Advice please. UPDATE
50,394
Posted By
kch
http://fullblownmotorsports.com/full-blown-scion-f...
http://fullblownmotorsports.com/full-blown-scion-frs-subaru-brz-fa20-stage-2-head-package
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
11-26-2015, 03:19 PM
23
Brake Upgrade, Advice needed!
9,736
Posted By
ryoma
if you want better brakes for the street, just...
if you want better brakes for the street, just pads and fluid will be fine. there is no need to change out the rotors unless you want to. same with stainless steel lines. however, I think the most...
Forum:
Forced Induction
10-19-2015, 04:29 PM
123
50,394
Posted By
Xero-Limit
The cheaper one is the standard kit, the more...
The cheaper one is the standard kit, the more expensive one (400-500) is what Dai got below and includes the beehive springs. Beehive spring setups are superior in racing use where you are prolonged...
Forum:
Forced Induction
10-16-2015, 12:18 PM
123
50,394
Posted By
DaiTT500
http://www.power-division.com/product.php?producti...
http://www.power-division.com/product.php?productid=16400&cat=414&page=1
These are the GSC springs I got.
Forum:
Forced Induction
10-15-2015, 10:12 PM
123
50,394
Posted By
Xero-Limit
Just springs should be enough. If you're going...
Just springs should be enough. If you're going that route go for the beehive version of GSC. They are lighter and stronger and should help keep those rockers from getting banged up to 8k+.
Forum:
Forced Induction
10-13-2015, 08:19 PM
123
50,394
Posted By
DaiTT500
I've talk to the big engine builders for FA20 and they said stock does fine. It's the springs that aren't tensioner enough that lets this all happen. Replacing it with a set of better valve springs...
Forum:
Forced Induction
10-13-2015, 08:09 PM
123
50,394
Posted By
DaiTT500
Similar destruction but not as bad as yours. My...
Similar destruction but not as bad as yours. My lifter shot out of the valve cover I think. I could not find it. ...
Forum:
Forced Induction
09-15-2015, 09:40 PM
70
heat management, CF hood alternative
38,855
Posted By
plucas
Fluid flow around a vehicle is very dependent on...
Fluid flow around a vehicle is very dependent on the car's design. Just because it works for one, doesn't mean it can be used as a blanket term for all vehicles. You also cannot always trust CFD or...
Forum:
Forced Induction
07-18-2015, 07:00 PM
9,139
Innovate (Sprintex) Supercharger Owners Topic
2,785,116
Posted By
vaderbloke
I used the larger (76mm) idler pulley for my 69mm...
I used the larger (76mm) idler pulley for my 69mm drive - fits perfectly, and less chance of the tensioner bottoming out :)
Amazon.com: Gates 38015 Idler Pulley: Automotive
Forum:
Forced Induction
07-16-2015, 08:55 PM
123
50,394
Posted By
WHITE
Draco-REX Here's were element tuning first...
Draco-REX
Here's were element tuning first encountered the problem:
http://www.ft86club.com/forums/showthread.php?t=73858
And if you scroll down a little on this page it talks about it...
Forum:
Forced Induction
07-16-2015, 08:25 PM
123
50,394
Posted By
WHITE
Draco-REX oil starvation might not have been the...
Draco-REX oil starvation might not have been the culprit. there's an, as of right now, uncommon factory defect of the "pin" that holds the rocker arm failing and backing out of the rocker arm. This...
Forum:
Forced Induction
07-14-2015, 11:06 AM
123
50,394
Posted By
xkalelx
Wow, so much speculation and attacks in here....
Wow, so much speculation and attacks in here. Keep calm and wait until further information comes in.
OP: It doesn't take a master mechanic to determine if you blew out a rocker cover, leaking from...
Forum:
Forced Induction
07-13-2015, 07:48 PM
123
50,394
Posted By
WHITE
I'm going to go out on a limb here and venture my...
I'm going to go out on a limb here and venture my guess to be that you ate a rocker and shot it out of the valve cover. Just a guess. I'm interested to see what the actual verdict is.
Forum:
Forced Induction
07-12-2015, 08:22 PM
123
50,394
Posted By
WHITE
Might have to call and find out. They might make...
Might have to call and find out. They might make them, but dont advertise as theyre not popular since most people reduce compression ratio.
I'd like to tell you that you wont notice a difference...
Forum:
Forced Induction
07-12-2015, 07:44 PM
123
50,394
Posted By
WHITE
What you want is 4032 forged pistons, they'll be...
What you want is 4032 forged pistons, they'll be more then strong enough for you. And they wont slap and burn oil like 2618's.
Off the top of my head, you can get arias through full blown in 4032,...
Forum:
Forced Induction
07-12-2015, 07:23 PM
123
50,394
Posted By
TurboBRZ
According to some other members who have...
According to some other members who have commented on one of my threads, what likely happened is that your cam seal plate sprung a pretty massive leak - which has been reported to be an issue on our...
Forum:
Forced Induction
07-12-2015, 07:21 PM
123
50,394
Posted By
WHITE
I'm not sure what happened, I'm not here to...
I'm not sure what happened, I'm not here to answer that.
But in response to your building dilemma....you want safety, and reliability...then you want forged internals, OR you want to just go...
Forum:
Forced Induction
07-08-2015, 10:03 PM
9,139
2,785,116
Posted By
whataboutbob
I was only getting about 7K miles out of the...
I was only getting about 7K miles out of the gates pulleys. I upgraded to one of these and I've got 35K out of it and it is still going strong:...
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
07-02-2015, 04:51 PM
251
Would you prefer that the FRS had a "real" engine?
69,155
Posted By
billyk
"Real" engine?? "Non-Boxter"?? Can't speak...
"Real" engine??
"Non-Boxter"??
Can't speak for others, but I love this engine.
Forum:
BRZ First-Gen (2012+) -- General Topics
04-20-2015, 07:54 PM
85
BRZ STI Comfirmed !
28,092
Posted By
That "article" doesn't confirm shit! Yet another...
That "article" doesn't confirm shit! Yet another click bait blog quoting another click bait blog that the over eager want to believe. They just took some parts of quotes on the New York concept and...
Forum:
03-30-2015, 11:37 PM
184
No front anti-sway bar=a better ride
47,430
Posted By
Racecomp Engineering
I do not recommend simply removing your front...
I do not recommend simply removing your front swaybar and then driving quickly.
- Andrew
Forum:
Engine, Exhaust, Transmission
03-22-2015, 06:13 PM
6
Torsen diff
2,220
Posted By
Kodename47
http://www.toyota.co.uk/new-cars/gt86-specs-prices
Forum:
03-22-2015, 05:54 PM
6
Torsen diff
2,220
Posted By
sstfnv
All US spec cars have torsen diff, not sure if...
All US spec cars have torsen diff, not sure if all version of the UK spec cars have that.
Forum:
03-21-2015, 08:20 PM
143
FA20 Stock Capacity
58,604
Posted By
spitfire481
Once I get to beat on it for a little and we make...
Once I get to beat on it for a little and we make sure it's all good it will be marketed. I'll be testing it at 600whp with mickey Thompson et street radials
Forum:
03-21-2015, 04:34 PM
143
FA20 Stock Capacity
58,604
Posted By
spitfire481
I have a set being built. Along with a bunch of...
I have a set being built. Along with a bunch of other fixes for weak spots and poor high rpm shifting. I'd like to think I'll be testing it by summer, but there is really no timeframe on when it'll...
Forum:
02-16-2015, 06:26 PM
112
This car scares the hell out of me in snow
27,112
Posted By
was385
Snow tires. Get them or leave the car at home...
Snow tires. Get them or leave the car at home when it snows.
Forum:
06-06-2014, 10:08 AM
17
Tarmac 2 recommended damper setup
8,722
Posted By
ATL BRZ
http://racecompengineering.com/instructions/rcet2s...
http://racecompengineering.com/instructions/rcet2settingsbrzfrs.pdf
Forum:
Forced Induction
06-04-2014, 11:45 PM
9,139
2,785,116
Posted By
DeliciousTuning
There is a very specific scenario...
There is a very specific scenario (hiccup/missfire) we are seeing with a few select customers. You will need this configuration and meet these certain scenarios for this aspect to happen. (This does...
Page 1 of 5
1
2
3
4
5
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
06:53 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
