follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 4
1
2
3
4
Showing results 1 to 30 of 103
Search took
0.77
seconds.
Search:
Posts Made By:
lazyluka
Forum:
Engine, Exhaust, Transmission
10-25-2017, 04:57 AM
439
Jackson Racing Dual Radiator/Oil Cooler
184,633
Posted By
lazyluka
Try as I might I could not get oil past 111C. I...
Try as I might I could not get oil past 111C. I gave up after 30 minutes as it wasn't really going anywhere.
I would say that my driving style is to over drive the car. This track is fairly...
Forum:
09-18-2017, 04:58 PM
17
upgrading final drive on AT...
6,110
Posted By
lazyluka
I have a 4.55 final drive in my manual and we...
I have a 4.55 final drive in my manual and we recently installed the same unit in my friends automatic.
We used Toyota Part 41201-19557, it's a 4.556 Final Drive Kit and ours contained all the...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
09-10-2017, 12:42 AM
9
SPC Camber bolt install issue
3,396
Posted By
lazyluka
Silly question I know, but you have the top bolt...
Silly question I know, but you have the top bolt loose while trying to insert the bottom camber bolt, right?
The only other thing I can suggest from memory is don't try to set the camber when...
Forum:
08-14-2017, 10:58 PM
36
Melted Bushings
7,463
Posted By
lazyluka
I think someone on here had issues with...
I think someone on here had issues with aftermarket poly engine mounts.
One of the comments on that post went along the lines of:
The aftermarket poly mounts couldn't handle the heat, but the...
Forum:
08-01-2017, 04:47 PM
19
Radiator ducting
5,302
Posted By
lazyluka
Have you looked at the ACE solution? Link...
Link (http://www.ft86club.com/forums/showpost.php?p=2898436&postcount=1143)
Forum:
07-31-2017, 04:59 PM
77
Why delete the sound tube?
47,369
Posted By
lazyluka
I had the motivation, only because I remembered...
I had the motivation, only because I remembered reading about it while researching intakes:
http://www.ft86club.com/forums/showpost.php?p=1748895&postcount=4
Forum:
07-13-2017, 03:44 PM
872
OFFICIAL Torque Android app PID/Misc Thread
577,275
Posted By
lazyluka
Also, try the * instead of the x for...
Also, try the * instead of the x for multiplication.
Forum:
07-12-2017, 10:45 PM
872
577,275
Posted By
lazyluka
Have you tried to change the unit type and...
Have you tried to change the unit type and equation part in Torque?
From post #2:
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
Try:
Unit...
Forum:
DIY (Do-It-Yourself) Guides
07-02-2017, 04:52 AM
27
DIY: Whiteline Roll Center Adjustment Kit Install
22,032
Posted By
lazyluka
Thanks. Just installed mine today, went...
Thanks.
Just installed mine today, went straight for the polyboots you ordered.
Looking at the Whiteline ones I took off you could almost say they are identical on both the tie rod and the...
Forum:
06-18-2017, 06:27 PM
13
Oil and water cooling
4,147
Posted By
lazyluka
0) NA - Factory tune 1) Cusco Oil Cooler 2) -...
1) Cusco Oil Cooler
2) - No data -
3) 201 F / 255 F (Converted from C) 15min session
Bonus: I managed to get the temps up to 208 F / 266 F on a 30 minute session.
Forum:
06-08-2017, 05:42 PM
439
184,633
Posted By
lazyluka
I am not really knowledgeable enough to answer...
I am not really knowledgeable enough to answer this, I will give it a go tho. I don't have anything to back up what I write so hopefully Jackson Racing or CSG Mike can chime in and correct me.
Forum:
06-07-2017, 05:16 PM
439
184,633
Posted By
lazyluka
Most of the questions asked have already been...
Most of the questions asked have already been answered..... Please consider reading the full thread.
See posts above (#155/#156). You don't need to drain the oil during oil change. This is...
Forum:
Tracking / Autocross / HPDE / Drifting
05-21-2017, 05:19 PM
176
Track Builds Picture Thread
87,530
Posted By
lazyluka
Bump.
Bump.
Forum:
07-16-2016, 05:11 PM
18
modifying undertray?
6,740
Posted By
lazyluka
Not sure if you are actually data logging, but...
Not sure if you are actually data logging, but removing that rubber makes the problem worse, it may cool down faster when you are going slow/in the pits but on track you will effectively make your...
Forum:
Issues | Warranty | Recalls / TSB
07-03-2016, 04:17 PM
38
Trac cntrl light supposed to blink when off?
5,036
Posted By
lazyluka
Still be active in the background unless you use...
Still be active in the background unless you use the "Pedal Dance" or disconnect the ABS fuse (no ABS then).
Search forums for "Pedal Dance" and read up about it.
Forum:
06-29-2016, 04:06 PM
87
I can no longer recommend Fumoto for the twins.
23,710
Posted By
lazyluka
Have had my Fumoto valve on since my first oil...
Have had my Fumoto valve on since my first oil change (3+ years). No nipple version. Seems like it's well protected under the car.
No issues whatsoever and I took the car off road, on track....
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
04-02-2016, 06:10 PM
276
Modular Hood Louver Kit - Verus Engineering
128,309
Posted By
lazyluka
VeloxEric The more I think about it, the...
VeloxEric
The more I think about it, the more I like your design because I feel it still maintains the hood's crumple zones. Unlike another vent design that I have seen, I don't feel like there...
Forum:
04-02-2016, 06:06 PM
276
128,309
Posted By
lazyluka
PitViper Thanks. I did my own budget photoshop...
PitViper
Thanks. I did my own budget photoshop attempt, but decided against it as the two smaller vents have a sharper leading edge so it would end up looking funny (pic doesn't really show this)....
Forum:
04-01-2016, 03:46 AM
276
128,309
Posted By
lazyluka
Really interested. May have to get some. Out...
Out of curiosity, if one were to move the two smaller vents to the middle, would you be able to install the larger vents on the outside so that they go...
Forum:
NEW ZEALAND
02-01-2016, 05:13 AM
4
Canadian in NZ
8,310
Posted By
lazyluka
I should be able to spare at least a day to show...
I should be able to spare at least a day to show you around Auckland. Pm me for my email and phone as I don't check this forum regularly.
Forum:
Forced Induction
02-16-2015, 03:42 AM
126
Cusco Oil Cooler
63,517
Posted By
lazyluka
I data logged some temps with this cooler on...
I data logged some temps with this cooler on track. As I mentioned in the post it cooled oil down faster than without it when you go off throttle.
This was also on 0W20 oil, so may be better with...
Forum:
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
11-11-2014, 03:13 AM
12
So I finally met Tada-San...
4,614
Posted By
lazyluka
My speedo now has a "Tada" zone (above 140km/h) :D
Forum:
05-21-2014, 04:36 PM
41
Tony Angelo breaking in his new FRS
23,567
Posted By
lazyluka
I'm suggesting that the car loves a thrashing for...
I'm suggesting that the car loves a thrashing for a break in. I have broken in two of them now. One by the book and one a bit more subtle than above.
Thrashing it during break in makes the car...
Forum:
05-20-2014, 03:48 PM
41
23,567
Posted By
lazyluka
Hope they toss it on the dyno in a few 100 miles,...
Hope they toss it on the dyno in a few 100 miles, that should yield some nice figures with that kind of break in :)
Forum:
04-13-2014, 01:17 AM
3,085
WHITEOUT FR-S Compilation
1,549,131
Posted By
lazyluka
Some more pics:
Some more pics:
Forum:
04-13-2014, 01:08 AM
3,085
1,549,131
Posted By
lazyluka
Just a few pics from a very wet track day. Dried...
Just a few pics from a very wet track day. Dried up during the afternoon.
First time out with the Essex sprint kit and Ohlins R&T suspension, car was stock till a week ago.
Forum:
04-06-2014, 10:01 PM
39
Ohlins Road & Track - settings (clicks) for street/track/ax
24,921
Posted By
lazyluka
Just bought some from a NZ distributor a few...
Just bought some from a NZ distributor a few weeks ago. Installed in the car over the weekend.
Wheel alignment on Thursday. :)
Will provide feedback on settings when I have driven on them for...
Forum:
12-09-2013, 01:55 PM
7
Oil coolers = lower temps + oil starvation?
5,942
Posted By
lazyluka
Semi slicks, or slicks will possibly make you...
Semi slicks, or slicks will possibly make you experience an oil surge. I know Toyota NZ has developed a baffled sump for the TR86 race cars to help prevent the issue.
The TR86 car's all run oil...
Forum:
11-25-2013, 02:10 PM
14
Very Smokey Exhaust at Track Day
3,872
Posted By
lazyluka
Same thing happened to me at my track day a while...
Same thing happened to me at my track day a while ago. Car had under 1000 miles on it.
I just kept driving though, didn't bother ending the day early. Smoke went away after that first instance and...
Forum:
10-28-2013, 04:27 PM
13
Running Temperature?
6,127
Posted By
lazyluka
normancw See picture attached. Hit 126C...
normancw
Hit 126C after 3 full on laps (first peak).
Then I cooled off the brakes a bit, then went for it again...
The biggest advantage is the rate at which it cools...
Page 1 of 4
1
2
3
4
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
08:18 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
