follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 23 of 23
Search took
0.34
seconds.
Search:
Posts Made By:
Brzerker
Forum:
Issues | Warranty | Recalls / TSB
09-22-2020, 12:17 AM
6
P0010 CEL - Finding the issue
2,032
Posted By
Don't do it. This is an electrical problem. If...
Don't do it. This is an electrical problem. If it's not the OCV solenoid, then it's wiring or the ECU.
https://demos.starbase7.net/t3Portal/document/rm/RM20S0U/xhtml/RM000000PDW0MSX.html
Forum:
Engine, Exhaust, Transmission
05-11-2018, 04:06 AM
106
pulley kit and other basic mods comparison
18,273
Posted By
Subsonic
I quite disagree, this is much, much worse than...
I quite disagree, this is much, much worse than nothing, if only for the following mod list:
Most agree that a pulley change will only offer a very slight benefit to acceleration times, so...
Forum:
04-01-2018, 02:18 PM
10
Catback Exhaust Broke My Car!
1,983
Posted By
Williampreza
Sorry in advance for the long description, but I feel you guys need the whole story before you can help me.
As you recall, I recently replaced my OEM catback exhaust with a Corsa system. I...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
10-23-2017, 09:09 PM
14
How is it possible to lose coolant, if the coolant system in a car is a closed loop,
4,238
Posted By
mav1178
Your statement can only be accurate if you assume...
Your statement can only be accurate if you assume it is a closed loop.
In reality, it is not a closed loop.
You can seep moisture via any of the gaskets, bad seal, head gaskets. You also have...
Forum:
10-02-2017, 06:11 PM
48
Pad fell out?
6,206
Posted By
Jyn
Considering I am a male by birth, I've never...
Considering I am a male by birth, I've never really had the need for pads so I can't say it's happened to me.
Forum:
Tracking / Autocross / HPDE / Drifting
09-18-2017, 10:11 PM
50
Individual Racing Parts (IRP) V3 Short Shifter Rattle Thread
22,445
Posted By
Shadow_
On the front of the shifter, around the halfway...
On the front of the shifter, around the halfway point, there is a small allen screw inside of the silver cylinder. Simply loosen it, and turn the button counter clockwise. You may need to use...
Forum:
09-12-2017, 12:00 PM
161
New RACING short shifter from Individual Racing Parts
70,781
Posted By
nav
Installed the shifter rattle fix, and it does not...
Installed the shifter rattle fix, and it does not improve the situation that much. Maybe slightly less rattle below 5,500 rpm, but that's it.
Anyone else have a solution?
Forum:
08-01-2017, 11:35 AM
21
Oil Temp Monitor Set Up (Stacking Sandwich Plates)
10,016
Posted By
avishenoy1
My current setup is TRD Sensor plate, Racerx...
My current setup is TRD Sensor plate, Racerx stacking plate, Racerx Thermostatic oil cooler sandwich plate, Oil filter.
Yes it does clear the hood.
You will not get a good oil pressure reading...
Forum:
06-28-2017, 07:50 PM
125
New battery, worse handling
25,234
Posted By
jvincent
I had Baconator combo for dinner in the car on...
I had Baconator combo for dinner in the car on the way home.
I was full lock right to keep the damn car going straight.
Forum:
06-28-2017, 03:15 PM
125
25,234
Posted By
JD001
Sounds like the poles have been reversed, the...
Sounds like the poles have been reversed, the symptoms are obvious. Going round left hand corners it is repelling whilst right hand it attracts. It has been magnetised, I suggest you rub the roof a...
Forum:
03-07-2017, 01:30 PM
71
Boosted Auto Trans Owners.
28,073
Posted By
liquidsky44
ATF oil cooler does help with the slippage, but...
ATF oil cooler does help with the slippage, but the oem clutch pack would not hold the high torque for long. Either way all the parts mentioned above should be replaced for it to hold 300torque.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
03-07-2017, 12:24 PM
19
RACER X FRONT LOWER CONTROL ARM FAILURE WHILE DRIVING ON HIGHWAY: UPDATE WITH MORE D
12,517
Posted By
Jeff@Racer X Fab
Before we provide our formal response, we would...
Before we provide our formal response, we would like to state the following:
In the original email we received from the customer on Feb 21st, 2017, the customer states he “hit a small seam in the...
Forum:
01-18-2017, 06:25 PM
139
Stock motor started knocking... (shortblock + more replaced, 1/18) resolved
27,050
Posted By
MarkR171
Happy to say the car is back home and seems to be...
Happy to say the car is back home and seems to be sorted. Read the description in the picture of my invoice to see what was wrong. The issue should be sorted for good this time, unless excess sealant...
Forum:
12-20-2016, 04:18 PM
5
Window Shatter / Fracture - passenger small triangular window
3,980
Posted By
btune
3yrs later, it was just brought to my attention...
3yrs later, it was just brought to my attention that I did not follow up on this...it was fixed under warranty by the dealership (similar to the case in the link I referenced).
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
09-20-2016, 02:11 PM
5
Porsche 911R steering wheel
1,447
Posted By
wbradley
It's included free if you buy the car.
Forum:
09-15-2016, 02:47 AM
38
Pads and fluid for next year
5,714
Posted By
ryoma
Torque RT700 has a lot of great reviews. it's...
Torque RT700 has a lot of great reviews. it's what I use, but be warned that it is slightly expensive but it might be more worth it for you since you won't be bleeding it after every event.
Forum:
07-11-2016, 06:03 PM
46
Front Splitter Endplates - Verus Engineering
29,068
Posted By
G-awesome
man....how much products are you guys developing...
man....how much products are you guys developing atm? I heard of a few but it seems like the list keeps growing! Now I wish I didn't get the sard cf wing yet...I may sell it in the future then. :D
Forum:
05-18-2016, 03:06 PM
218
Verus Engineering Billet Clutch Fork and Pivot
87,321
Posted By
VerusEric
Snagged a few photos from my machinist on the...
Snagged a few photos from my machinist on the first article that is headed to me.
http://i.imgur.com/ZZG8Neb.jpg?1
http://i.imgur.com/5naNZCD.jpg
http://i.imgur.com/xdYDf6q.jpg
We will...
Forum:
03-20-2016, 10:37 PM
15
UEL headers sound level (volume)
6,270
Posted By
jawn
Gruppe-S UEL Header and Stock Catback on Subaru...
Gruppe-S UEL Header and Stock Catback on Subaru BRZ - YouTube
There's much burble.
Forum:
09-30-2015, 08:48 AM
50
3" exhaust questions
10,584
Posted By
cjd
I have a JDL over-frontpipe and D2 exhaust. Fit...
I have a JDL over-frontpipe and D2 exhaust. Fit is great. Quality is their usual.
Only header I know that's 3" is Nameless.
I'd be surprised if a good 2.5" system is much of a bottleneck. I'm...
Forum:
09-01-2015, 08:42 AM
43
Scrothe Rallye 3 Harness - Pictures Installed
20,135
Posted By
TMF
Here are the torque specs for the bolts that you...
Here are the torque specs for the bolts that you need to remove for install and re-torque:
Front seat belt receiver (attached to the seat): 31 ft-lb
Front seat outer belt assembly (both the top...
Forum:
07-30-2015, 11:02 AM
27
Project BRZ Intake Manifold Development
7,527
Posted By
TurboBRZ
Last night a member from the So Flo BRZ/FR-S group came by and left me with a beautiful little present:
Forum:
02-19-2015, 01:11 PM
81
Header+front/overpipe(stock catback) enter yours
28,897
Posted By
edeekeos
Fitment was absolutely perfect, everything lined...
Fitment was absolutely perfect, everything lined up, and it came with all hardware and gaskets. I can't recommend it enough! I plan on buying their catted version in the near future to help cut out...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
10:31 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
